ANTI-CORROSION JOINT STRIP
mjobrien
Does anyone know what the following is from Moss?
858-205 $62.95 ANTI-CORROSION JOINT STRIP
I'm looking to start putting the body back on the 100 and I noticed this. Is this a gasket of sorts?
Thanks,
Michael.
55 BN1
Dave Russell
Yoda - R.I.P
I'm not really sure what Moss is selling.
When two metals that are far apart on the electromotive series such as steel fenders & aluminum shrouds are in contact and have an electrolyte such as water, (salt water is especially bad) between them, a current flows & galvanic corrosion results.
One way to reduce the corrosion problem is to place a sacrificial material between the two metals. Zinc or magnesium will both corrode before the aluminum.
Another way is to electrically insulate the two metals so that the destructive current does not flow. Some folks have tried insulating strips of tape in the joints.
I think it's generally agreed that a very good protective coat of paint on the mating shroud & fender flanges will do a pretty good job of insulating & preventing corrosion.
Dave Russell said:
...<span style="font-weight: bold">I think it's generally agreed that a very good protective coat of paint on the mating shroud & fender flanges will do a pretty good job of insulating & preventing corrosion.</span>
That is what I'm relying on...
PPG DP40/401 epoxy-chromate primer
PPG Delstar Acrylic Enamel/DXR-80 Polyurethane hardener
PPG Delclear/DXR-80
mjobrien
mjobrien
Great, I was wondering what this was, two well painted surfaces on a car that will not see a lot of rain should be good enough!
Michael.
AUSMHLY
Another name for the strip that Moss is selling is known as dum-dum. Kinda like silly putty, but sort of sticky. It is also black in color. Body shops and windshield (sorry windscreen) guys use it.
I also passed on using it. The stainless steel bead is hard enough to get in as it is, without adding the dum-dum to the mix. Just wait till you try to get to some of those screws/bolts and clips. (What are those things anyway. They have a bolt head with a screw shank).
Cheers,
Roger
mjobrien
mjobrien
Yea, I really liked getting the one screw at the top of the rear wings in.... just enough room to make you believe it's possible.
Thanks,
Michael.
J Anti corrosion joint strip. Austin Healey 24
J Anti corrosion strips - Worth it? Austin Healey 8
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
T Need an Anti-Tramp Bar? Austin Healey 6
S TR6 Anti Run-On Valve question. Triumph 4
FlyingCat Spitfire Anti-Roll Bar Triumph 6
Bob_Spidell Healey Anti-Theft Device Austin Healey 0
steveg Anti-run on solution Austin Healey 10
JimLaney Anti-seize or Thread locker ? Spridgets 2
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
J Healey BJ8 anti roll bar bushes Austin Healey 2
F Fitting anti-squeal kit to front calipers on BT7? Austin Healey 7
Got_All_4 TR2/3/3A anti rattle pin Triumph 6
D TR4/4A shifter anti rattle pin Triumph 2
L Sway Bar / Anti Roll bar bush replacement 100/6 Austin Healey 7
B Anti-sway bar for a earlier BJ7 Austin Healey 3
bugedd Front anti roll bar Spridgets 11
Steve P. Info: removing anti-theft column lock on later cars Spridgets 0
J Bypassing battery cutoff switch, using is as anti-theft only? Austin Healey 20
tomshobby Have you checked your anti-freeze? Spridgets 1
tahoe healey disc brake anti squel pads Austin Healey 5
D TR6 Anti run-on valve Triumph 3
R TR4/4A Tr4a new anti sway bar, maybe almost perfect! Triumph 5
S Spitfire Question on anti run on valve 73 spitfire Triumph 5
K TR2/3/3A TR3 Gear Shift Anti Rattle Spring ##%&*rikerfrats Triumph 8
K No luck.. Gear Lever Anti-rattle Spring Install? Triumph 1
Ed_K Installing new anti-sway arm bushings Austin Healey 3
H Anti-Frezze expandtion thru overflow @ Shutdown Austin Healey 35
Darrell_Walker Ratco anti-sway bars and coil-over rear shock Triumph 6
S TR2/3/3A shifter anti rattle spring tr3 Triumph 4
K TR2/3/3A TR3 Gearlever Anti-rattle spring&plunger Install? Triumph 6
I Bugeye anti-rattle plunger questions Spridgets 6
H Anti run on valve MG 6
ecurie_ecosse T-Series Anti run on switch. MG 11
G Anti-sway bar question Spridgets 1
HAN8L1965 CounterAct electronic anti rust system? Spridgets 22
Got_All_4 TR5/TR250 ADCO Anti sway bar installation on the Tr250 Triumph 4
jerrybny Anti-Rattle Spring and Plunger Triumph 4
roofman Spitfire Anti run on valve ? spitfire 1500 Triumph 3
jerrybny Anti-Rattle Spring Triumph 1
Hairyone Anti-roll bar Spridgets 13
M Teves Anti-Lock Brakes, All Models up to year 1992 Jaguar 4
tahoe healey Anti-freeze Austin Healey 10
2wrench Pics showing repair to anti-run-on valve. Triumph 1
bigjones Sway bar [anti-roll bar] question Spridgets 8
