Universal Wire Harness question
JPSmit
I just found out that the company I had hoped could make me a new wire harness for the Vauxhall (Autosparks) can't. The old harnesses are too butchered. In a sense I don't mind as I have suspected one of the Hot Rod universal systems might be easier and definitely more economical. So, questions.
1. Anyone have any experience with these? Any input?
2. When I look at the websites, (in addition to the number of fuses) the kits seem to be divided into GM and non-GM kits. I presume this has to do with connectors and "plug and play." I also presume that I am being wildly optimistic that because I have a Vauxhall (UK GM) it will fit a GM harness?
thanks all
Bayless
Yep, sounds pretty optimistic to me. On a more serious note though, have you tried Rhode Island Wiring? Not cheap but they do excellent work and may have the specs for your car.
JPSmit
JPSmit
Thanks for the lead- they don't even list Vauxhall in their catalogue. I may contact them anyway but I suspect the cost may outstrip the benefit.
Platinum
Rhode Island has been around for forever, they have furnished us with a BUNCH of harnesses for weird stuff. CALL 'em, JP. They may surprise ya.
OZ_BN1 Drive Shaft Universal Joints Austin Healey 2
KVH General Tech Universal Joint—Driveshaft Triumph 20
C Bugeye propeller/drive shaft- universal joint Spridgets 1
T TR2/3/3A 30a 5 pin universal relay Triumph 12
Bugeyze Universal joints Spridgets 6
Griz Universal joint let go Austin Healey 15
Foura TR4/4A Universal joint diameter Triumph 9
Scotsman TR4/4A Lower steering flex joint upgrade to TR6 Universal joint Triumph 2
D TR2/3/3A Universal Joint Lube Question Triumph 8
R Drive shaft universal joint bear cap modification Austin Healey 7
TulsaFred Universal Joint problems Spridgets 9
Foura TR4/4A Steering column Universal Joints Triumph 10
sd80mac7204 Universal Joints Triumph 3
1 Hardtop AH 100/4 Universal Laminations Austin Healey 16
1 Hardtop AH 100/4 Universal Laminations FORUM Navigation Questions 1
wkilleffer Broken universal joint MG 11
TR4 TR4/4A Changing universal joints in a TR4???? Triumph 5
K TR2/3/3A head gasket repair wire Randall Triumph 1
Todd78d Wire wheel cleaner Spridgets 1
scottkilpatrick TR4/4A Knock off wire wheels procedure..basic questions Triumph 9
K 1068 mkIII wire wheel rub Spridgets 1
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
E educational resources for truing wire wheels Restoration & Tools 0
D Wanted TR6 72 Spoke Wire Wheels (painted) Wanted Triumph Classifieds 0
W TR2/3/3A Wire Wheel Conversion Triumph 5
SNClocks Electrical Wire Lug Spridgets 2
R Wire Wheel Fit Austin Healey 10
DocDup1 MGA Wire Wheel Hubs For MGA MG 6
M General MG Wire Wheel Specialist Needed in Los Angeles area MG 0
KLUTZ Wedge FASD wire question Triumph 1
P TR5/TR250 Wire wheels width Triumph 8
P Wire Wheel Splines Austin Healey 10
KVH General Tech O/D Electrical Wire Burned Triumph 22
D Wire Wheels and Air Leak Austin Healey 16
S TR2/3/3A wire repair Triumph 7
TR6Canuck TR6 Wire Wheels: MWS/Dunlop vs Dayton - which is better? Triumph 5
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
R General TR Emergency hot wire - because you never know whats next Triumph 2
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
PAUL161 T-Series MGTD Wire Wheels or Not MG 4
S MGB mystery wire MG 32
RJS General TR Wire Wheel Spline Question Triumph 3
steveg 100-4 Distributor Internal Ground Wire Austin Healey 6
M 60 vs 72 Spoke Wire Wheels Austin Healey 19
B Tubes in radial tires on wire wheels - what do you do? Austin Healey 27
steveg TR6 Steering boot clamp wire - why? Triumph 2
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
B TR4/4A Wire wheel question Triumph 10
