Broken universal joint
wkilleffer
Well, I was almost home, when the rear universal joint broke on one of the busier streets near my house. AAA sent a tow truck within 20 minutes.
I'm thinking that since one is broken, that the second one can't be far behind. I've seen one of the catalogs with a set and all hardware, and am wondering if that's the way to go. Also, how challenging is the job of replacing the u-joints on MGB's? I have reasonable mechanical ability and do about all of my own car work.
The worst part of this is that I was *really* enjoying using the B as my daily driver. At least the motorcycle is available.
Thank you,
tony barnhill
Great Pumpkin - R.I.P
Not a big deal...hardest part might be getting the driveshaft out...
Check the pricing for the set and individually - I've seen it better both ways (make sure you include all the parts that the "set" has when you do the individual math).
tony barnhill
Re: Broken universal joint *DELETED*
Post deleted by tony barnhill
Wrong thread tony! But I got it.
wkilleffer
wkilleffer
I was beginning to think that Tony's rusty car must have really gotten to him.
Just out of curiousity, I checked the Advance auto parts site to see if they even knew of such things. To my surprise, their website had several choices, ranging from $8.99 to over $20. Various types of warranties were also represented. Now, none of the area stores had them in stock, but any of the ones that I would consider would be here in a business day.
Now, I know we're supposed to support small business parts vendors, but I'm curious about how these parts would stack up against a part from TRF or Moss. Since I've never done this job before, I don't know what is needed besides the part itself.
Platinum
Find a parts store that'll get you Spicer U-J's. They were actually the OEM. MGB U-J's are not "strange" sizes, so should be available redily. Check the local NAPA yet?
wkilleffer
wkilleffer
[ QUOTE ]
[/ QUOTE ]
Thanks for the reminder. I'd forgotten all about NAPA. This si what happens when everything's behaving. I forget what to do when something goes wrong. /ubbthreads/images/graemlins/crazyeyes.gif
While searching for a dizzy cap and rotor for my Alfa earlier tonight, Advance's site didn't show any in stock either at any store, so I called the closest one (had the guy oogling at the fact I had an Alfa on the road - he was really impressed saying "cool" and all that)... turns out they had "several" in stock. I told him I'd be in to get them in the morning.
Always pays to pick up a phone (one of the things I hate doing), and checking with the local guys. I figure because my Alfa uses Bosch dizzy parts, that they stock the same parts for VW guys.
Keoke
HI Wkilleffer, sometimes when the drive shaft fails under load the yokes on the shaft can get beatup a bit be sure and check them while you are waiting for the replacement Crosses.-Fwiw---Keoke
Oh, and something I learned from Tony... when it comes to bearings buy the best you can get!
tony barnhill
Absolutely, Kenny....go for the best bearings/u-joints you can afford.
D TR2/3/3A repairing broken hardboard seatback Triumph 8
Bayless How to repair broken vent window studs? Spridgets 1
M TR6 1973 TR6 - broken choke cable Triumph 6
P Broken Overdrive Switch in Gear Knob Austin Healey 14
AH67AH Broken Shock Mounts Austin Healey 23
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
K What is this broken part in my transmission/OD? Austin Healey 6
tahoe healey Broken Spokes Austin Healey 8
H broken sway bar link - again Austin Healey 8
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
KVH General Tech Clutch Fork and Broken Pin Triumph 8
RJS TR4/4A Broken Cylinder Head Stud Triumph 10
T Philosophizing on keeping cars for more decades - prompted by a broken throttle cable Spridgets 3
B wire wheels and broken spokes Austin Healey 19
I TR6 Broken front suspension bracket Triumph 3
D TR4/4A broken trans fork pin Triumph 14
mcmillal TR4/4A Broken Vertical Link Triumph 17
D BJ 8 Side window broken - Help !! Austin Healey 9
K TR2/3/3A Broken exhaust manifold TR3b Triumph 13
K TR4/4A Performance Cam=Broken Rings??? Triumph 9
C TR6 Broken Throttle Shaft Triumph 4
TomChar TR6 '74 TR6 - Broken Top bow Triumph 1
B TR4/4A TR4A Head off for broken manifold stud - What else to do ? Triumph 13
J Healey 100 -- Broken rocker and bent push rods !!! Austin Healey 7
P BJ 8 broken hood frame screw Austin Healey 6
TomChar TR6 '74 Clutch & various broken bits Triumph 20
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
J TR2/3/3A Broken pinion gear tooth, I am sad! Triumph 2
A Broken Axle Question? Spridgets 11
Gliderman8 Help with restoring broken aluminum logo badge Restoration & Tools 6
J Need some expertise, broken exhaust maniford Triumph 9
jharrison77 Broken Heater Control Tap [valve] Austin Healey 9
K Anyone experience a broken crosshaft pin.... Triumph 6
H broken sway bar link Austin Healey 13
K TR2/3/3A Crossshaft broken taper pin removal? TR3 Triumph 5
P broken oil cooler fitting MG 1
R TR2/3/3A TR-3A Rear Leaf Spring Broken Triumph 3
nevets Points failure - broken cam follower Austin Healey 3
W TR6 broken bleeder on rear brakes tr6 Triumph 12
Westfield_XI Three broken spiders later..... Spridgets 54
tahoe healey broken spoke Austin Healey 12
V Help: key broken off in ignition! Triumph 18
BugeyeNJ58 Gas Gauge Broken on '58 Bugeye.?? Spridgets 9
B High Torque Starter Broken mount Austin Healey 1
T TR4/4A Broken disc wheel stud on TR4A IRS hub. Triumph 3
S TR2/3/3A TR3 clutch pressure problem - not a broken spring! Triumph 3
middie Is this sender wire broken?? Spridgets 2
K BROKEN ROD BOLT has any body had one? Triumph 9
davester Help needed...broken exhaust manifold stud MG 15
jvandyke hood [bonnet] release broken cable Spridgets 34
