Twosheds Back On Line
Twosheds
If anyone cares, I am now back on the Forum after about a month of being incommunicado whilst my computer was fitted with some new vaccuum tubes.
I am once again able to supply smarmy remarks and useless information.
What did I miss?
DNK
DAle trying to rebuild,tighten bearings , on his front end
NutmegCT
John - welcome back!
Wondered if you had decided to keep you tent up at Valley Forge after the VTR show closed.
Lots of new things about TeeYah to relate when you have time.
Tom
PS - did your computer need a new 6AU6? Mine was running low on kerosene for a while ...
Geo Hahn
Twosheds said:
...What did I miss?
DoT4 vs DoT5, which oil in ODs, eBay scams revealed... I don't think you'll have much trouble catching up. Sort of like missing a month of a soap opera.
Mickey Richaud
Indeed it was good to meet ya, John!
Glad you're back with us.
Brosky
Doctor J,
Well, let's just say that the eBay scammers are still around and Dale and that red devil are still fighting down in Puerto Rico.
That about sums it up!
Nice to have you back.
G
Geo Hahn said:
Twosheds said:
...What did I miss?
Well if people start posting how to build patio decks and fixing shed doors, I'm going to purposely break my computer. Those are the reasons I joined this forum.
100DashSix
Is there any relation to Arthur "Two Sheds" Jackson?
R
RonMacPherson
Hey, hey, hey now!
Sounds like Dale has the beast beaten.
Crypt car is now becoming Amos.... soon, very, very soon!
Twosheds
Twosheds
We are not blood kin, but Arthur and I share the nickname.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]
Third Interviewer Last week the Royal Festival Hall saw the first performance of a new symphony by one of the world's leading modern composers, Arthur 'Two Sheds' Jackson. Mr Jackson.
Jackson Good evening.
Third Interviewer May I just sidetrack for one moment. Mr. Jackson, this, what shall I call it, nickname of yours.
Jackson Ah yes.
Third Interviewer 'Two sheds'. How did you come by it?
Jackson Well, I don't use it myself, it's just a few of my friends call me 'Two Sheds'.
Third Interviewer I see, and do you in fact have two sheds?
Jackson No. No, I've only one shed. I've had one for some time, but a few years ago I said I was thinking of getting another one, and since then some people have called me 'Two Sheds'.
Etc. etc. etc.
[/QUOTE]
TRclassic3
I can attest to the fact that John actually does have "Two Sheds", and they are quite full...although rumor has it that an organizational effort was recently initated by the Chief Boffin.
Twosheds
Twosheds
TRclassic3 is quite correct, I do have two sheds.
One houses the HSTRL Laboratory and The Blue TR3 and has recently been organized so that the Boffins can now walk around in it without fear of tripping over a TR3 part. It's also a shelter for homeless mice.
The other shed, formerly the HSTRL Annex, is rented to a Mad Boffin who uses it to store The Very First TVR Vixen Ever Made and some TR3 parts.
Aldwyn
Welcome back, John!
Since this is a LBC forum, shouldnt we be saying you needed some vacuum "valves" for your computer rather then "tubes"?
I mean, if we use "spanner" and "bonnet", we might as well call them "valves" too, right?
/bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
Twosheds
Twosheds
Aldwyn said:
Welcome back, John!
You're right, Aldwyn, and I apologise. I thought of it after I clicked on SEND.
It actually needed a Hydrogen Valve, an Interoceter, and a Flux Capacitor.
P.S. Missed you at Gettysburg somehow.
Platinum
I've a goodly supply of 6AU6's any time that occurrs in future, John. And a few dozen 12V assorted as well. /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
HerronScott TR2/3/3A Twosheds [John Herrera] TR3 for sale Triumph 9
YankeeTR Twosheds is OK in my book... Triumph 10
B MGA Axle Brake line MG 0
A TR2/3/3A Those round fuel line clips Triumph 2
J TR2/3/3A Brake Line Flares Triumph 8
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Walter74 Fuel Line Routing Austin Healey 7
B TR4/4A In-Line fuse 25 or 35 Amp? Triumph 21
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
G TR6 Clogged fuel line Triumph 6
B Brake Line Pictures Austin Healey 1
KVH General Tech Brake Failure--The Line Split Triumph 19
petnatcar Fuel Line Upgrade Austin Healey 8
B TR4/4A Rear Fuel Line Routing IRS Triumph 5
D TR2/3/3A oil pressure line venting? Triumph 4
TomMull TR2/3/3A rear mount does not line up Triumph 10
R Bugeye oil pressure line Spridgets 9
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
D TR2/3/3A rearmost fuel line question Triumph 5
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
JPSmit Fuel line - gas tank question Restoration & Tools 5
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
steveg TR6 Source for fuel line P-clip Triumph 17
Lin Brake hard line question Austin Healey 4
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
C TR2/3/3A Gas Line Triumph 11
R TR2/3/3A Brake Line Triumph 4
B TR2/3/3A Caliper brake line Triumph 10
Lin Healey assembly line - engine installation Austin Healey 19
Jim_Stevens TR2/3/3A Clutch slave hydraulic line Triumph 1
Lin Brake line fittings Austin Healey 2
M Vacuum Line on a 948 Spridgets 4
A TR2/3/3A how do i fix this hood line? Triumph 5
mctriumph Morgan drive line Other British Cars 2
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
longbridgehealey In line fuses Austin Healey 25
Bayless What size fuel line for '67 Sprite? Spridgets 2
John Turney TR6 Brake Line to Front Calipers Triumph 4
dklawson General TR Fuel Line Routing Triumph 4
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
D 62 tri-carb fuel line connection Austin Healey 10
