Brake line fittings
Lin
Hi guys,
Trying to help my son with a project. I am not with my car, my tools or my manuals. Looking for the size (diameter and threads per inch) of the male fittings on our Big Healey brake lines. Can anyone help me?
Thanks as always.
Lin
steveg
Vineyarder Austin Healey 100-4 brake line fittings Austin Healey 10
MGTF1250Dave Brake Line Fittings Triumph 6
J TR2/3/3A Brake Line Flares Triumph 8
S TR2/3/3A brass fitting from a steel brake line Triumph 2
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
B Brake Line Pictures Austin Healey 1
KVH General Tech Brake Failure--The Line Split Triumph 19
Lin Brake hard line question Austin Healey 4
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
R TR2/3/3A Brake Line Triumph 4
B TR2/3/3A Caliper brake line Triumph 10
John Turney TR6 Brake Line to Front Calipers Triumph 4
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
FlyingCat Spitfire Brake line Triumph 8
RAC68 Hard Brake Line Compound Opinion/Recomendation Austin Healey 8
R Help with BJ7 front brake line routing Austin Healey 6
Rut Brake line routing Spridgets 21
AngliaGT '74 Midget - Best way to Replace Brake Line? Spridgets 1
M TR4/4A 67 TR4A, need brake line fitting specs Triumph 6
M Brake Line Lengths Austin Healey 1
J TR2/3/3A Spring loaded valve in the top of the 4 way brake line fitting? Triumph 3
Rut MGB Need some brake line clips? MG 9
J Brake line material Austin Healey 24
J Brake line pipe Other British Cars 5
DornTRoriginal TR2/3/3A Installation of Brake Line Clamps on Real Axel Triumph 1
PatGalvin TR2/3/3A Hard Brake Line Flaring Question Triumph 11
AHS TR2/3/3A Disc brake line routing Triumph 0
T TR2/3/3A brake line replacement Triumph 11
DornTRoriginal TR2/3/3A Hydraulic Brake Line Clips Installation Triumph 2
C Vacuum line routing for brake booster Austin Healey 5
M Brake line kits Spridgets 28
D TR6 76 TR6 Rear Right Brake Line Triumph 8
mgedit TR2/3/3A Brake Line Master to Banjo Connection LHD 56 TR3 Triumph 4
R Brake line nipple size Triumph 4
Tugboat TR2/3/3A TR3A Brake Line Triumph 2
J TR2/3/3A Brake line advice for my TR3 Triumph 5
luke44 Clip - Brake Line to Firewall Triumph 3
M TR6 Where does this TR6 brake line go?[pic] Triumph 3
W Off to the local shop... brake line bleeding Spridgets 2
W Problems!! Brake line bleeding and leaks Spridgets 5
D Brake line flush Austin Healey 13
T Wiring Harnress and Brake Line Routes Austin Healey 11
E BE Dual Brake Line Switch Assembly Spridgets 0
E BE w/dual line brake master....90 degree fitting? Spridgets 12
K brake line flares Spridgets 9
letemglow Brake line layout with dual master cylinder MG 6
T TR2/3/3A TR3 front brake line routing Triumph 3
B Brake Line Spridgets 5
I brake line fastener source? Spridgets 12
