TR2/3/3A Spring loaded valve in the top of the 4 way brake line fitting?
John_Progess
What is the purpose of the spring loaded poppet valve in the top of the 4 way brake line fitting? I got mine all cleaned and the springs seem to work but is this thing needed? Never seen one in any other of my cars. Thanks and have a good day!
John
Geo Hahn
It works like a check valve -- the idea is to keep the brake pads close to the rotor - otherwise they tend to get knocked back due to flex in the spindles on cornering, etc.
Some omit the guts to disable it (you still need the body of it to connect the line) as it can cause some brake drag up front. I've experimented both with and w/o and can't say there is much difference.
TR3driver
Great Pumpkin - R.I.P
To notice the pads getting knocked back, you have to drive pretty hard. I never notice it unless I've been driving close to the limit on cornering. And even then, all it does is cause the brake pedal to be somewhat lower than normal. I might notice it more because I use relatively wide, sticky tires.
But, I pay attention to the brakes and whether they release fully. To me, the drag caused by the valve (more correctly called a residual pressure valve) is quite noticeable. My feeling is that it also accelerates brake wear and wastes a tiny amount of fuel. So I'm one of those that remove the plunger to disable the valve. (As I recall, you could connect the line directly to the 5-way, but the stock line is too short to reach without the valve body.)
A better solution IMO is stiffer front spindles. TRF sells both uprated spindles, and a spacer that fits over the spindle to provide a lot of extra stiffness. The downside of the spacer is that you have to change shims to adjust the wheel bearing clearance. These mods were developed and tested by a well known Triumph racer, and are recommended by Kas Kastner in his newer books on TR competition preparation.
PS, the contact information in the flyer below is obsolete, as Jack Drews passed away some years ago (while racing his TR4!). However, I believe you can still buy the components through his son Tony if you prefer (he also supplies TRF):
[FONT=Trebuchet MS, Arial, Helvetica]For further information, contact Tony in lieu of "uncle jack" at tony@tonydrews.com or 309-764-4506.[/FONT]
charleyf
I bought one of the kits with the spacer and shims from TRF a couple of years ago. I recall seeing them in a recent sale catalog , but don't recall when. So I believe they are available.
Charley
G HS4 fixed needle or spring loaded? [which is best] Spridgets 15
A Spring loaded needle??? Triumph 3
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 6
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
SpeedyG TR4/4A Door window regulator spring Triumph 5
mctriumph General TR Spring boot sale Umpteenth Annual Triumph 5
2 For Sale Dr. Doolin Spring Compressor for TR3 Triumph Classifieds 0
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
P MGB 1974 MGB front spring length. MG 0
F 59 bugeye spring bushing bolt Spridgets 8
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Clutch slave "return spring"? Triumph 3
newmexTR3 TR2/3/3A TR3 Shock tower spring collar Triumph 7
jfarris TR2/3/3A First drive of spring - I hate electricity!!! Triumph 7
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
B Poor quality BE replacement spring boxes Spridgets 0
B Any issue with cutting this weld on the spring base plates? Spridgets 4
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
jfarris TR2/3/3A Relacing rear spring busings Triumph 3
J TR4/4A Seat install, Spring clip Triumph 0
F TR2/3/3A Leaf spring advice Triumph 16
K Missing spring clutch release lever Other British Classifieds 1
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
T Heater Door Spring Austin Healey 1
R General TR Spring collar flange thickness options Triumph 2
Editor_Reid Unusual Leaf Spring Austin Healey 4
J Tips for quarter elliiptic spring install Spridgets 3
L Welding Bugeye Spring Base Plate?? Spridgets 1
R TR2/3/3A Throttle rod spring location Triumph 3
pkmh Front Spring Removal For BJ8 Austin Healey 8
R TR2/3/3A Carb throttle return spring tension Triumph 2
Got_All_4 TR5/TR250 Spring question Triumph 1
P TR6 Spring checkup Triumph 1
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
66healey BJ8 shifter spring install Austin Healey 2
longbridgehealey Clutch return spring Austin Healey 7
A 1974 2500M Spring Rates TVR 6
Carlos TR4/4A Moss rear spring distance piece 674-560 Triumph 16
GeorgeC Rear spring disassembly - BN1 Austin Healey 1
tr6nitjulius General TR Triumph Club of So Cal Spring Drive 4/27/19 Triumph 0
Joe Schlosser Quarter Eliptic spring bushing Spridgets 6
dougie SOVERN's Pacifc NW Vintage Racing Spring Sprints Season Opener Racing 5
M For Sale Churchill 18G106 Valve Spring Compressor for Austin Healey 3000 Austin Healey Classifieds 0
Lotus Club SoCal LCoSC - Spring San Gabriel Mountains Drive Lotus 0
S TR2/3/3A Front coil spring recommendation? Triumph 7
