Welding Bugeye Spring Base Plate??
Lawk
Hello,
Has anyone restored a Bugeye Sprite without welding the Spring Base Plate to the base of the Spring Box?
Welding them together seems to very much be a belt and suspenders approach given the fact that you have two 1/2 inch bolts and two 3/8 bolts tying them together along with the 1/4 elliptical spring.
Thanks Ken (restoring 1958 Sprite)
Joe Schlosser
I welded the whole thing together. Remember the entire load of the rear axle goes through this assembly and the load is transferred through the box through the brace between it and the front cross member just in front of the seat. This spreads the load out through the entire monococque.
I bugeye bonnet welding help please Spridgets 11
Tr3aguy TR2/3/3A Welding in Frank’s bump stops Triumph 0
S TR2/3/3A tips for mig plug welding vertically? Triumph 11
S TR2/3/3A Welding hoods. Triumph 14
D Off Topic welding fumes Triumph 5
R TR2/3/3A Welding in the floor questikns Triumph 19
dklawson Antra Auto Darkening Welding Helmets? - 2016 Restoration & Tools 6
KVH General Tech Welding, Braising, Tacking Triumph 3
R TR2/3/3A Question on order of welding Triumph 31
S TR2/3/3A welding battery box Triumph 6
Rut TR4/4A On or off frame when welding in body panels Triumph 16
Jim_Gruber Bugsy II - Planning some Welding - Part II Spridgets 18
Jim_Gruber Bugsy II - Planning Welding - I need some advice Spridgets 14
B 1275 Block Welding Spridgets 14
G Filler metal used for tig welding ah aluminum shrouds Austin Healey 2
S TR2/3/3A welding slag in the carb tr3 Triumph 8
wangdango inner body panel painting/welding/etc Austin Healey 3
J Welding advice please Restoration & Tools 9
boxfullofyertoys Thoughts on DIY welding/bodywork Spridgets 27
Morris Welding fun! Spridgets 9
K Modern Epoxy instead of Welding? Triumph 13
TRMark New Welding Helmet Restoration & Tools 3
M Welding 101. Triumph 1
hymodyne rear quarterpanel repair section welding Restoration & Tools 10
M_Pied_Lourd TR2/3/3A TR3A Floor Welding Question Triumph 8
T cast iron welding info and repair-FYI Triumph 1
ekamm welding tr3a inner sill Restoration & Tools 2
T Inner fender progress - welding pictures Triumph 17
germanmichel The story of the bad weld seams with MAG-welding.. Restoration & Tools 4
1965_MGB MIG Welding Anyone? Restoration & Tools 8
1965_MGB Gas Welding Anyone? Restoration & Tools 8
TRMark Welding Table Outlets Restoration & Tools 5
Popeye Welding butt joints... crack in weld after grindin Restoration & Tools 3
M Welding the Exhaust vs. Electrical Problems Spridgets 5
motofiaccone Welding in panels Spridgets 5
MGBGT_noob The great welding method controversy MG 12
M welding advice Triumph 5
T Aweman, I have a welding question, you there? Triumph 6
T Wedge Nearly done welding the TR8 floor repairs Triumph 15
T More welding quesitons - how much overlap? Triumph 9
T Question on seam welding - why not do it? Triumph 18
dhungerf Welding Patches? Triumph 11
A TR2/3/3A TR3 head welding Triumph 4
J Welding aluminum water neck Austin Healey 3
T First stab at welding Triumph 12
v8mgbal welding Spridgets 36
S Welding sheet metal Triumph 17
EastBoundJoe Welding newbie Spridgets 39
Popeye Welding: Butt- or Lap? Restoration & Tools 12
vping Welding to a rear axel tube. Can you? MG 17
