TR6 Spring checkup
pdplot
Gave the TR6 its annual checkup today. Points ok, plugs ditto, a few drops of oil in the distributor shaft, a few drops in the carburetor dashpots, oil on the door hinges and latches, oiled the carb linkage and choke cable, topped up the brake fluid, added 1/2 quart of 20W-50 oil, checked the tire pressures, tested the fan belt tension and condition, checked out the electrical system - all works and now she's good to go. Took it for a test ride - usual rough ride on our crappy roads but no obvious problems. I had greased the trunnions last fall so no problem there.
glemon
That is a good list, I feel like I take good care of my car, and it leads a pretty sheltered life, but an ounce of prevention (or oil or grease) is worth a pound of cure.
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 6
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
SpeedyG TR4/4A Door window regulator spring Triumph 5
mctriumph General TR Spring boot sale Umpteenth Annual Triumph 5
2 For Sale Dr. Doolin Spring Compressor for TR3 Triumph Classifieds 0
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
P MGB 1974 MGB front spring length. MG 0
F 59 bugeye spring bushing bolt Spridgets 8
Hamish Racing Another 3 sisters spring with commentary Racing 0
K TR2/3/3A Clutch slave "return spring"? Triumph 3
newmexTR3 TR2/3/3A TR3 Shock tower spring collar Triumph 7
jfarris TR2/3/3A First drive of spring - I hate electricity!!! Triumph 7
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
B Poor quality BE replacement spring boxes Spridgets 0
B Any issue with cutting this weld on the spring base plates? Spridgets 4
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
jfarris TR2/3/3A Relacing rear spring busings Triumph 3
J TR4/4A Seat install, Spring clip Triumph 0
F TR2/3/3A Leaf spring advice Triumph 16
K Missing spring clutch release lever Other British Classifieds 1
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
T Heater Door Spring Austin Healey 1
R General TR Spring collar flange thickness options Triumph 2
Editor_Reid Unusual Leaf Spring Austin Healey 4
J Tips for quarter elliiptic spring install Spridgets 3
L Welding Bugeye Spring Base Plate?? Spridgets 1
R TR2/3/3A Throttle rod spring location Triumph 3
pkmh Front Spring Removal For BJ8 Austin Healey 8
R TR2/3/3A Carb throttle return spring tension Triumph 2
Got_All_4 TR5/TR250 Spring question Triumph 1
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
66healey BJ8 shifter spring install Austin Healey 2
longbridgehealey Clutch return spring Austin Healey 7
A 1974 2500M Spring Rates TVR 6
Carlos TR4/4A Moss rear spring distance piece 674-560 Triumph 16
GeorgeC Rear spring disassembly - BN1 Austin Healey 1
tr6nitjulius General TR Triumph Club of So Cal Spring Drive 4/27/19 Triumph 0
Joe Schlosser Quarter Eliptic spring bushing Spridgets 6
dougie SOVERN's Pacifc NW Vintage Racing Spring Sprints Season Opener Racing 5
M For Sale Churchill 18G106 Valve Spring Compressor for Austin Healey 3000 Austin Healey Classifieds 0
Lotus Club SoCal LCoSC - Spring San Gabriel Mountains Drive Lotus 0
S TR2/3/3A Front coil spring recommendation? Triumph 7
K TR2/3/3A Auxillary carb return spring in "More BS about TR,s" Triumph 9
tr6nitjulius General TR Rites of Spring April 2018 video/pics Triumph 0
C MGB Found this spring in my gas tank MG 8
