TR2/3/3A Brake Line
Redoakboo
I am in the fnal stages of restoring a 54 TR-2 Long Door. While starting to bleed the brake system, I discovered that the line from the master cylinder to the left wheel Banjo Fitting had a crack in the lower nut.. I ordered a new 37" line from the Roadster Factory and attempted to install it. I discovered that the fittings on this line have different thread patterns. The top fitting went into the master cylinder fine, but the bottom one didn't; different thread pattern.
Call to Roadster Factory said that line is not available, because of the different thread patterns.
Solution?? Cut the good fitting off the old line, cut the flare off the new line, install the good, old fitting and attempt to flare that new line. There is no way my flare tool is going to make a flare like the one that came on it. Can you use copper for a brake line? Will the DOT 5 react with it?
Any new suggestions from you experts?
Dick Vinal
Sarastro
Don't use copper for a brake line. It's just not strong enough. Use only DOT approved materials.
If you need something more flexible, you can use Cunifer lines, https://cunifer.com/ . That said, I've had trouble flaring the Cunifer lines with a simple flaring tool; even my high-end tool often doesn't do it perfectly. Maybe you just need a friend with a better flaring tool...!
R
Redoakboo
Steve,
Thanks for your help. I called Fedhill and ordered a 6' piece of 3/16" Cunifer line and two P-30-3 3/8" x 20 bsf male fittings , one for the bottom location.
Dick
Graham H
Dick if you have a brake repair shop close by just take the new pipe and old fitting to them and ask them to make the proper flare for you.
Graham
J TR2/3/3A Brake Line Flares Triumph 8
S TR2/3/3A brass fitting from a steel brake line Triumph 2
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
B Brake Line Pictures Austin Healey 1
KVH General Tech Brake Failure--The Line Split Triumph 19
Lin Brake hard line question Austin Healey 4
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
B TR2/3/3A Caliper brake line Triumph 10
Lin Brake line fittings Austin Healey 2
John Turney TR6 Brake Line to Front Calipers Triumph 4
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
FlyingCat Spitfire Brake line Triumph 8
RAC68 Hard Brake Line Compound Opinion/Recomendation Austin Healey 8
Vineyarder Austin Healey 100-4 brake line fittings Austin Healey 10
R Help with BJ7 front brake line routing Austin Healey 6
Rut Brake line routing Spridgets 21
AngliaGT '74 Midget - Best way to Replace Brake Line? Spridgets 1
M TR4/4A 67 TR4A, need brake line fitting specs Triumph 6
M Brake Line Lengths Austin Healey 1
J TR2/3/3A Spring loaded valve in the top of the 4 way brake line fitting? Triumph 3
Rut MGB Need some brake line clips? MG 9
J Brake line material Austin Healey 24
J Brake line pipe Other British Cars 5
DornTRoriginal TR2/3/3A Installation of Brake Line Clamps on Real Axel Triumph 1
PatGalvin TR2/3/3A Hard Brake Line Flaring Question Triumph 11
AHS TR2/3/3A Disc brake line routing Triumph 0
T TR2/3/3A brake line replacement Triumph 11
DornTRoriginal TR2/3/3A Hydraulic Brake Line Clips Installation Triumph 2
C Vacuum line routing for brake booster Austin Healey 5
M Brake line kits Spridgets 28
D TR6 76 TR6 Rear Right Brake Line Triumph 8
mgedit TR2/3/3A Brake Line Master to Banjo Connection LHD 56 TR3 Triumph 4
R Brake line nipple size Triumph 4
Tugboat TR2/3/3A TR3A Brake Line Triumph 2
J TR2/3/3A Brake line advice for my TR3 Triumph 5
luke44 Clip - Brake Line to Firewall Triumph 3
M TR6 Where does this TR6 brake line go?[pic] Triumph 3
W Off to the local shop... brake line bleeding Spridgets 2
W Problems!! Brake line bleeding and leaks Spridgets 5
D Brake line flush Austin Healey 13
T Wiring Harnress and Brake Line Routes Austin Healey 11
E BE Dual Brake Line Switch Assembly Spridgets 0
E BE w/dual line brake master....90 degree fitting? Spridgets 12
K brake line flares Spridgets 9
letemglow Brake line layout with dual master cylinder MG 6
T TR2/3/3A TR3 front brake line routing Triumph 3
B Brake Line Spridgets 5
I brake line fastener source? Spridgets 12
tomshobby rear brake line question Spridgets 17
