TR6 Trunk mounted brake light for TR6
hondo402000
I have been looking for a trunk mounted brake light, I decided to see what I could find on existing cars, 86 toy celica convertable, NLA, pontiac sunbird 86 conv NLA, 86 jaguar convert, available at 202.00, 2004 ford thunderbird, 134.00, LED I think this would be the best option, so once I see the car up close and think it might work I am going to buy it part number is 1W6Z-13A613-AA
On both my TRs I use a magnetic 3rd brake light. It's a pair of towing lights (WallyMart, et al) split to make one for each car. Added a cirle of soft flannel to prevent scratching.
Being removable I only use it in traffic, can take it off for shows & club drives where I more or less trust the driver behind me.
I did change the wires to approriate colors and used Lucas bullet connectors...
I use the Hyper-Lite product. Barely visible when off, but very visible when on. They flash for eight seconds and then remain on. Mount them anywhere you might like.
Paul,
I like your setup.
Hondo,
Look in a street rod or motorcycle magazine. You'll see a variety of LED units. The motorcycle lights are usually smaller and have the blinking features like Paul mentioned.
BOBH
hondo402000 said:
I tried calling some salvage yards and no luck
You need to go to your local Pick-a-Part salvage yard and take a tour of the yard. You'll find lots of usefull items that can be used including third brake lite...and it shouldn't cost more than $10.00 or so...
Paul
I like the lights but how are they mounted when the hard top is off and the rag top is down??? I am on the trail of a mercedes 560 SL third light
Where are you going to mount the Mercedes style lite, on the trunk.
I'm thinking of a stalk mounting from the rear package shelf that has the lite on top, and can double as a horozontal fire extinguisher mount
The Mercedes lamp is mounted on the trunk, on the 560 it is close to the end of the trunk, I was thinking more toward the edge nearer to the gas cap
looks like a third light from an 87 jag, its on order from a salvage yard, I will post pics before I start drilling holes in the trunk, for approval
To avoid drilling into the trunk lid, I suggest the following. Get a piece of sheetmetal the length of the LED lamp assembly and bend it 90 degrees or so. Mount the LED light body horizontally on the vertical part of the sheetmetal bracket. Lift off your tonneau cover or vinyl cover across the back and drill and tap two holes where these holes will be hidden once you snap the vinyl cover back into place. Then drill clearance holes in the piece of sheetmetal and secure the sheetmetal bracket to the two holes which will become hidden. Feed the wire up behind the gas tank and out a third hole to be connected to the LED light assembly. Now re-snap the cover back into place and it will cover the screw heads, the hole where the wire come up and it will cover part of the new bracket. This could be painted body colour. If you're at a concours show, you could remove it and no-one would see the screws and/or the wire under the edge of the cover.
If you do mount it near the gas cap check to see that it doesn't hit the cap if the cap is open and you open the trunk.
Another option is to install the light, or lights on the back side of the headrests. This will allow you to avoid having to drill anything and have the lights visible with the top up or down. There is a variety of brightness ratings on LEDs. A strip of the brightest mounted between the headrest and the back ot the seat would be nearly undetectable until you hit the brakes.
BOBH
Good idea, if you have a luggage rack it might block the view from behind. Also before you drill, put the top up to see how it all comes together. The way I invision it it will not matter, but best to be sure.
I m still thiking about a parcel tray mounted shaft made out of 1 inch square tubing that barely sticks up over the tonneau cover that can act as a fire extinguisher mount,and with one of those little hyper lites on top.
Here is a rough prototype of my idea. A flat base mounted between seats on packeage tray in front of hump. The box represents the hyper lite which will be smaller than the box. Paint it black with a plastic cap, run wires down the center of shaft, under carpet into back of car. This solves the problem of where to mount the fire extinguisher also. The shaft only sticks up enough to allow the hyper lite to peak over the tonneau cover.
It can definetly work.
Do you have a roll bar? Best place for one if you have the bar. Nice and high and visible through window.
N Fastners for trunk mounted luggage rack? Triumph 8
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
TireKicker847 Wanted 07 Jaguar XK trunk covers Jaguar Classifieds 0
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Twit TR4/4A TR4 trunk badge Triumph 8
69MGC MGC Putting a 12v battery in the trunk MG 10
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
6TTR3A TR6 TR6 Trunk lock set screws Triumph 2
S TR2/3/3A rubber seal go towards the inside of the trunk Triumph 3
A TR2/3/3A Brakes, exhaust and trunk floor Triumph 2
aero3113 100-4 trunk liner kit Austin Healey 4
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
JimLaney Refurbishing the trunk lid Spridgets 2
R TR2/3/3A Trunk floor replacment Triumph 4
1 Wedge Breaking Into a Trunk Boot Triumph 3
R TR2/3/3A Boot/trunk floor Triumph 5
S TR2/3/3A tr3 trunk primer Triumph 2
H trunk floor pan replacement 1964 BJ8 Austin Healey 2
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
S TR4/4A trunk seal question Triumph 10
S TR2/3/3A T handle trunk lock Triumph 14
C For Sale 67 BJ8 rear trunk luggage rack- Austin Healey Classifieds 0
T TR4/4A License plate on trunk lid Triumph 6
aero3113 Trunk Prop Stay Austin Healey 8
T TR2/3/3A Replacement Floor and Trunk Panel Quality Triumph 14
maxwedge5281 bn6 two seater trunk versus bt7 four seater trunk Austin Healey 27
MisterB And now.... the trunk Austin Healey 12
maxwedge5281 bn6 two seater trunk Austin Healey 16
bcbennett Wedge Bonnet and trunk prop rods Triumph 0
M TR2/3/3A Water in Trunk Triumph 10
69MGC MGC MGC Trunk Thingies? MG 5
Rob Glasgow Armacord Trunk Liner Austin Healey 8
S Trunk Lid Spridgets 26
T TR4/4A Trunk lid lettering - template wanted Triumph 0
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
maxwedge5281 bn6 armacord trunk liner kit Austin Healey 4
petnatcar Trunk modification for bt7 Austin Healey 15
magman BN-1 trunk latch adjustment Austin Healey 1
Scotsman TR4/4A TR4a trunk lid Triumph 2
Popeye TR4/4A Trunk [boot] lock removal Triumph 12
S TR4/4A door and trunk seals Triumph 3
TRMark TR4/4A Trunk lid and handle assembly Triumph 7
B Gaskets for Trunk Lid Hinges Austin Healey 9
J TR4/4A Trunk Lid Seal Triumph 4
B Works Boot Rack [ For boot read trunk] Austin Healey 5
John Turney Trunk Lid Control Cable Austin Healey 2
M_Pied_Lourd TR2/3/3A 1960 Triumph TR3A Trunk Seal Orientation Triumph 6
M TR4/4A Trunk/Boot rubber seal. Triumph 8
M TR4/4A Position of wiring loom inside the trunk/boot area. ? Triumph 3
M TR4/4A Cover for trunk/boot spare wheel....help please. Triumph 9
