Trunion question
TR250
So this may be a stupid question, but here goes: Can the trunion be removed from the verticle steering arm without dismantling the entire stubaxle? I keep reading all my references, which say to "unscrew" the assembly. I see in the diagrams the there are threads in the interior of the trunion, but even if I remove the stop, there is not enough clearance from the rear of the disc to spin the trunion. Am I missin' something here?
Also, what type of lubricant are you guys using? Any good/bad experiences?
Any uplifting advice?
thanks,
Andy "replacing all those suspension bushings should only take a few hours" Bradley /ubbthreads/images/graemlins/crazy.gif
MDCanaday
You must take off the upper control arms and remove the spindle from the Knuckle, then you can unscrew it up out of the trunion. Be advised you can clean it up and re-thread it down into the trunion one more turn in many cases, this gives you a much tighter assy when done and as long as the critter doesnt bind at the extreme part of its rotation, you have saved time and money!!
MD(mad dog)
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
4tecdog Trunion bearings Austin Healey 5
EWD TR6 Trunion Install Triumph 0
R TR6 Trunion Hole Triumph 2
Willie_P Trunion/lower wishbone washer HELP Triumph 3
Superwrench Trunion Bearings Austin Healey 2
B Lower trunion assembly Triumph 1
I TR6 TR6 Trunion installation/stop sleeve help Triumph 4
I TR6 TR6 trunion help - how tight, correct lubricant? Triumph 24
I TR6 TR6 Trunion resleeving? Triumph 2
dklawson Spitfire Spitfire - Trunion Bushing/Sleeve Clearance? Triumph 2
I TR6 TR6 frozen brass lower trunion Triumph 3
jhorton3 Trunion Spridgets 9
F er Trunion Bolts Austin Healey 5
T Trunion part missing Triumph 11
G trunion/vertical link seal Triumph 5
TR250 trunion re-assembly Triumph 4
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
