Willie_P
This is regarding a tr4 with 3deg trunions: Is this the correct washer to be placed on the outermost end of the trunion through-pin (secured by castle nut)?
If it is indeed the correct part, does it need to be reamed to fit the serrated end of the trunion (portion behind the threads on the pin shaft) or does it need to be hammered on (for an interference fit)?
The washer shown below is a new Moss piece and I am using original trunions/pins.
OR...do I have the wrong part (washer) altogether? ..and need to order the correct part.
thank you so much - I've been staring at this unassembled lower wishbone set-up for days now.
wp
wp
