er Trunion Bolts
fwtexasbj8
I just removed my front BJ8 shocks to drain the old oil and refill and in putting everything back together, I found a problem with the upper trunion bolts. While I had the top of the suspension apart, I wanted to replace the trunion bushings. Sounds simple, right? I cleaned the trunion of the old gunk from previous bushings, lubed the new bushings and as I was tightening the bolt, found I could not compress the new bushings enough to install the cotter pin. I am about 1/16 inch short on being able to install the pin. Unfortunately, I kept trying and stripped the trunion bolt in the process s I am down until the new ones arrive.
Here is my question. When you re-install the trunion bolts, do I need to drive the car a little to get the new bushings to seat somehow? Seems a little odd to not have the suspension bolts pinned, but I cannot seem to get the new bushings to close. The new parts weere all Moss and except to the protruding lip, seem to fit fine. The lip is thicker than the old ones but I just thought that was from compression and wear with the shock arm over the 18 years since they were last replaced.
Thanks for any help,
Doug
John Loftus
I remember having a similar problem with those bushes (from Moss). The inner steel bush was too long, compared to the ones they replaced, and I shortened them with a bench top belt sander being careful not to heat the rubber/steel assembly too much (which could cause delaminination). I told Moss about the problem but seems they haven't made any changes. Measure the steel core length your old ones and the new ones to see if you are experiencing the same problem.
Cheers,
John
F
fwtexasbj8
Thanks John,
I had thought about that after all was back together and could not get to them. I will measure them next week when I get the new bolts and modify to match the old ones. That certainly makes more sense than driving without the pins.
I appreciate your help,
Doug
F
fwtexasbj8
John,
One more question. Which side of the bushing did you grind off. I would think it would be the outer edge where the shock arm interface is, right?
I spoke to Moss today and they claim to have had at least 4 complaints on the bushing length. Their technical department is supposedly working on a fix that will be ready "soon".
Thanks,
Doug
John Loftus
Doug,
I recall grinding the inside (small end) because I didn't want to remove material from the flange side. Once the steel bushes are the proper size, there will be enough room for the bush. You can loosen the cross bolt on the shock arms and prise them apart a bit to ease assembly if needed.
Cheers,
John
F
fwtexasbj8
John,
Thanks again for the help!
Doug
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
4tecdog Trunion bearings Austin Healey 5
EWD TR6 Trunion Install Triumph 0
R TR6 Trunion Hole Triumph 2
Willie_P Trunion/lower wishbone washer HELP Triumph 3
Superwrench Trunion Bearings Austin Healey 2
B Lower trunion assembly Triumph 1
I TR6 TR6 Trunion installation/stop sleeve help Triumph 4
I TR6 TR6 trunion help - how tight, correct lubricant? Triumph 24
I TR6 TR6 Trunion resleeving? Triumph 2
dklawson Spitfire Spitfire - Trunion Bushing/Sleeve Clearance? Triumph 2
I TR6 TR6 frozen brass lower trunion Triumph 3
jhorton3 Trunion Spridgets 9
T Trunion part missing Triumph 11
G trunion/vertical link seal Triumph 5
TR250 trunion re-assembly Triumph 4
TR250 Trunion question Triumph 1
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 5
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
shadowfever Midget seat nuts and bolts Spridgets 2
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
D ARP big end bolts. Spridgets 7
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
W Generator and Starter Long Bolts Spridgets 0
G HD8 Carb Banjo Bolts Austin Healey 2
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
M Tranny Mount Bolts Spridgets 3
M TR2/3/3A oil pan bolts Triumph 16
AUSMHLY BJ8 Dowel Bolts Austin Healey 35
S TR2/3/3A Aluminum one time use stretch bolts Triumph 7
B McMaster Carr for bolts and fasteners Spridgets 8
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
charlie74 TR6 Bearing cap bolts Triumph 8
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
P Help with torquing bolts Restoration & Tools 3
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
AngliaGT Got Lucky Today - CHECK THOSE BOLTS! Spridgets 6
S TR2/3/3A Body Mounting Bolts. Triumph 14
B MGA Mystery bolts MG 2
B TR4/4A Self locking bolts question Triumph 13
J Thread Locker on Shock Bolts? Austin Healey 19
Jim_Gruber In need of 2 Fulcrum Pin Bolts - MOSS Has them on Back Order Spridgets 3
F TR2/3/3A Trunnion bolts Triumph 11
S TR2/3/3A banjo bolts to seal up on the early SUs Triumph 4
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
Jim_Stevens TR2/3/3A Rear bumper bolts size/thread? Triumph 3
I TR6 Source for Elevator Bolts? Triumph 16
K TR2/3/3A Brake caliper hold bolts? Triumph 1
C MGB Starter bolts MG 5
