Still at it with the front suspension rebuild, and more questions. 1)When I screw the trunion back on to the swivel axle, do I screw it down so that it is tight? 2) I am using Tinster's article on the front suspension rebuild - he says to fill the trunion 1/3 with gear oil. I noticed there is a zert fitting that leads into the trunion. The PO had both oil and grease in this area. If it is supposed to be filled with gear oil, why is there a zert fitting?
Thanks, Kevin
Thanks, Kevin
