Spitfire Spitfire - Trunion Bushing/Sleeve Clearance?
dklawson
I'm cleaning up the front suspension on our project '71 Spitfire. I've got all the pieces apart, most look good. The chrome plated sleeves for the trunnion bushings look almost new. However, there is a small gap between the ID of the plastic trunnion bushings and the sleeve.
Is there a specified limit on how much clearance is allowable between the chrome plated sleeve and the ID of the nylon trunnion bushings?
Andrew Mace
Doug, I've never seen any spec's, but they're a light-to-medium press fit in the nylon bush when new. So if there's any gap at all as you describe, they're done.
Ever since dad's first Herald in 1964 (ok, really ever since I was old enough to start working on it in '68), I've treated trunnion bushings almost like oil, i.e, as a regular maintenance item. So buy kits and replace 'em; you'll be glad you did!
dklawson
dklawson
Thanks Andy. I'll take your advice. I vaguely remember the trunnions on the GT6 being a light press as you describe. There's no point in putting worn out parts back in.
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
glemon Spitfire Spitfire Questions Triumph 7
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
T General Tech Spitfire overdrive, the sequel Triumph 3
