Lower trunion assembly
BillJoBob
Hello gents,
Sitting here snow bound and trying to figure out exactly why and how the components of the lower trunion are assembled as they are. Never seen anything made that way before and I have one already installed on the car, but thought I would ask about it just to get some insight. The oddly shaped washers and the locking collar?
Thanks!
TR3driver
Great Pumpkin - R.I.P
It's a very old design, from before they could economically make ball joints that would withstand the forces.
The oddly shaped washers are thrust washers (bearing babbitt over a steel core) , they wind up taking most of the fore/aft force applied to the wheels. Under hard braking there is a lot of force involved, and the joint still needs to be able to turn (in case you hit a bump while standing on the brakes). The funny shape results from grooves and channels, to help distribute the grease everywhere.
The "locking collar" is actually part of the thrust bearing; it locks to the shaft to ensure that it doesn't turn against the shaft (which would cause it to wear quickly at that point and possibly unscrew the nut).
The whole thing is a bit Rube Goldberg-ish; but it works pretty good, especially considering it's made with 19th century materials & processes.
You should see what Morgan used !
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
Willie_P Trunion/lower wishbone washer HELP Triumph 3
I TR6 TR6 frozen brass lower trunion Triumph 3
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
S TR2/3/3A lower small brass bushing Triumph 13
S TR2/3/3A steel bushings for the lower Arms Triumph 10
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
R TR6 Lower A-arm trunnion bushings Triumph 18
edkap2002 TR6 lower radiator hose fitting Triumph 2
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
B TR2/3/3A lower wishbone installation Triumph 5
L TR2/3/3A Bent lower wishbone arms Triumph 6
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
KVH TR4/4A Lower Control Arm Front Pivot Bolt Triumph 9
KVH General TR Pressing in the Lower Control Arm Bushing Triumph 6
C TR6 Lower A-arms Triumph 8
wangdango BJ8 lower radiator hose! Austin Healey 2
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
I General TR Lower wishbone arm attachment bracket advice needed Triumph 8
Rut TR4/4A Lower fulcrum brackets Triumph 3
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
Tr3aguy TR2/3/3A Lower control arm question Triumph 2
aero3113 100 lower windshield seal Austin Healey 4
RCarr BN1 Lower Control Arms Austin Healey 0
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
K TR2/3/3A The "air vent"on the lower part of the front apron below the grille.... Triumph 5
Jeepster Lower wishbone bush replacement. Austin Healey 33
H Post-War Other Herald rear suspension lower block installation Triumph 3
KVH General TR Pressing in the lower/inner control arm bushings Triumph 3
Scotsman TR4/4A Lower steering flex joint upgrade to TR6 Universal joint Triumph 2
Martinld123 Want to lower car about an inch Austin Healey 4
Rut TR4/4A Lower crash pad Triumph 9
KVH General TR Lower Control Arms Triumph 1
BoyRacer BN1 lower control arms Austin Healey 1
B TR2/3/3A Removing front lower wishbone confusion Triumph 3
M TR4/4A Left lower dash crash pad. Triumph 5
Geo Hahn TR2/3/3A lower generator bolt Triumph 7
K TR2/3/3A Refresh...main reson why idle will lower when kicking the gas pedal? Triumph 3
M TR4/4A Lower crash pads for dash....help. Triumph 4
sqbsprite TR6 Frame cracking around lower control arm mount, have you checked yours? Triumph 3
Keith_M Lower wishbone recondition? Spridgets 5
PAUL161 T-Series Windshield lower rubber MG 5
J TR2/3/3A Lower windshield rubber seal Triumph 3
B Lower Steering Column Bush - Where does it go and how? Austin Healey 14
madhouse RF Fender and Lower Cowel Body Parts needed Austin Healey 10
J Poly Lower A-Arm Bushings - One easy question as I am confused Austin Healey 1
CJD TR2/3/3A Lower Inner Wishbone Bushings Triumph 2
