Transmission Cover Fastener question
nevets
I am attempting to remove the transmission cover on my BN6. While the fasteners attaching the cover to the floor panels are conventional sheet metal screws, there are fasters attaching the front flange to the bulkhead that appear to be rivets? At first I thought they might be hex or torx head screws, but when I inserted an allen wrench I was able to push it right through the center of the fastener, which leads me to believe it's a rivet.
Why a rivet? Is this a standard detail? Maybe the threads in the bulkhead got stripped and the PO/restorer wanted to avoid a large sheet metal screw for aesthetic reasons? Assuming it is a rivet, is my only option is to drill it out? Any advice is appreciated.
Note: One of the pictures has been rotated 90 degrees by the BCF uploading process..
Rob Glasgow
Not sure about a BN6, but those fasteners on my BT7 have always been Phillip (or Posidrive) head sheet Metal screws.
nevets
nevets
OK, so they should be Phillips screws. Any thoughts about the fasteners I have encountered? Thanks.
vette
The one in the 1st pic looks suspiciously like the male half of a carpet snap.
nevets
nevets
Interesting...if that's what they are then maybe the screws that actually secure the tunnel to the bulkhead are hidden under the bulkhead carpet? I'll peel it back further and have a look. Thanks for the reply,
nevets
nevets
Turns out those fasteners are rivets. They go right through the bulkhead. Guess I will need to drill them out and replace with screws. Question...is it necessary to remove the seat frames, which are bolted to the floor, in order to remove the transmission tunnel? I would rather not, but the trans/tunnel flange that screws into the floor is very wide. Thanks.
steveg
You should be able to unbolt the lower seat frames from the slides, lift the seats out and move the inner slides all the way to the rear. If you can't remove the tunnel at that point, you'll need to remove the inner slides from under the car.
On my car, I don't have to remove the slides. IIRC, the tunnel flange may be notched where it aligns with the front of the inner slides.
PS - my car - and the Moss catalog - have no screws or rivets connecting the tunnel to the extension panel as shown in the pictures above.
nevets
nevets
Thanks steveg
I'm not sure why there are rivets fastening the tunnel to the bulkhead? Interesting that you don't have any fasteners along that flange. I'm guessing the restorer used fasteners to hold the cover snug to the bulkhead for a neater look?
John Turney
Thanks steveg
Probably to help keep the heat out.
F TR2/3/3A TR3A Transmission ID and cover Triumph 4
Joe Schlosser Advice on Transmission Front Cover Spridgets 4
Got_All_4 TR2/3/3A Fitting the original tr3 transmission cover over a tr6 overdrive Triumph 9
R TR2/3/3A Transmission Front Cover Triumph 3
C removal of transmission cover from 1959 100-6 Austin Healey 16
S TR2/3/3A new floors & removable transmission cover Triumph 3
T TR4/4A Cutting an access panel into transmission tunnel cover for solenoid adjustment Triumph 13
KVH Transmission Top Cover Rebuild Triumph 1
KVH TR4/4A TR4 Transmission Cover: The Three Big Triumph 7
M TR2/3/3A Metal transmission cover color for TR3 ??? Triumph 9
T Tips on installting top transmission cover bolts Triumph 2
T Correct seal for the transmission cover? Triumph 6
eschneider Spitfire Spitfire ABS transmission tunnel cover - worth it? Triumph 10
T TR2/3/3A TR3 transmission cover - supposed to be metal? Triumph 5
J Transmission Tunnel Cover - BN7 Austin Healey 10
T Spitfire Spitfire transmission cover installation question Triumph 5
Thomas591 Transmission cover BN2 Austin Healey 6
R6MGS T-Series MGTC Transmission Cover plate[monting bracket] MG 2
L Early B transmission tunnel cover needed MG 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
KVH General TR Transmission Problem Triumph 3
T Looking for "BillMs rear transmission mount" Spridgets 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
D transmission conversion Other British Cars 1
PAUL161 T-Series Original transmission sold MG 2
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
BritBite Transmission Repair Austin Healey 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
