Spitfire Spitfire transmission cover installation question
tdskip
Quick question folks;
In preparation for the SoCal TT I am finally installing the new transmission cover. My question is if I should install strips of a sealing material under the cover before I tighten it down.
What do you think/recommend?
T
tdskip
Thanks guys.
I already installed reflective heat shielding based on feedback from NASS (thanks Harve!), but didn't put the strips down.
I'll check those out and see what SpitBits has.
Thanks!
eschneider Spitfire Spitfire ABS transmission tunnel cover - worth it? Triumph 10
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
bobmga62 Spitfire Spitfire transmission appears to be locked Triumph 5
S Spitfire Triumph Spitfire 74 transmission bellhousing leak Triumph 6
L Spitfire spitfire transmission Triumph 2
T Spitfire Spitfire/Midget transmission questions Triumph 0
STL_Joe Spitfire Spitfire 4 Transmission Fluid Triumph 7
JPSmit Spitfire Spitfire Transmission question Triumph 2
B Spitfire spitfire transmission conversion to GT6? Triumph 5
M Spitfire Spitfire 1500 OD transmission Triumph 9
C Spitfire Spitfire transmission question Triumph 2
JamesWilson Spitfire Spitfire O/D Transmission Triumph 3
pjsmetana Spitfire Spitfire Transmission Options Triumph 8
R Spitfire spitfire transmission and j type O/D oil question Triumph 29
J Spitfire Spitfire Transmission Swap Triumph 5
JPSmit Spitfire transmission Question Spridgets 7
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
