TR2/3/3A TR3 transmission cover - supposed to be metal?
tdskip
Is a metal cover stock? I was pleasantly surprised when I pulled the cover today. The rest of the car was a mess, but boy is that a nice transmission cover!
TR4nut
yep, and I'm willing to trade one of my rusty ones for yours!
Don Elliott
tdskip - Instead of the rust bucket you bought, you should have bought a rust-free TR from someone in Southern California where "It never ever rains in . . . .".
Don Elliott
Here is my original steel cover with plugs added for access to quickly change the solenoid if I have to.
T
tdskip
Yeah, but in a slight defense of my current proposition I bought this out of New Mexico and asked all the right questions first about the inner sills, floors, floorboards etc.. and got (to be charitable) highly misleading info from the dealer/seller. That is in addition to the engine issues...
But I bought it, so I need to suck it up and fixed. But man, do I really hate when people screw other LBC'ers. And yes, he had to know because he reassembled it.
Got_All_4 TR2/3/3A Fitting the original tr3 transmission cover over a tr6 overdrive Triumph 9
M TR2/3/3A Metal transmission cover color for TR3 ??? Triumph 9
S TR4/4A TR3/4/4a Transmission rebuild question Triumph 7
S TR2/3/3A What weight transmission oil in a tr3 with OD? Triumph 13
G Wanted TR3 Overdrive Transmission Triumph Classifieds 2
Moosca TR2/3/3A TR3 Overdrive Transmission Verification Triumph 5
T For Sale Free tr3 transmission radiator and generator Triumph Classifieds 2
D TR2/3/3A TR3 Overdrive to transmission mating problem Triumph 8
R TR2/3/3A TR2/TR3 transmission dip stick access Triumph 10
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
R TR2/3/3A TR3 A Transmission rebuild Triumph 5
charleyf TR2/3/3A Transmission numbers on a TR3 Triumph 7
Scotsman TR2/3/3A HVDA transmission conversion. 90* speedometer cable adapter may be required on TR3's Triumph 4
JFeher TR2/3/3A Has anyone installed a TR6 OD transmission in their TR3? Triumph 8
AHS TR2/3/3A TR3 transmission clutch fork & shifter removal? Triumph 5
T TR4/4A I'm back to the well of knowledge - TR3/TR4/TR4A clutch-transmission confusuion Triumph 10
P TR2/3/3A TR3 Transmission oil Triumph 13
T TR2/3/3A Is CT52431 a TR3 Transmission serial ? Triumph 4
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
Russ Austin TR2/3/3A TR3 Transmission Installation Hints / Tips Please! Triumph 14
Russ Austin TR2/3/3A TR3 Transmission question Triumph 8
mgbmedic TR2/3/3A TR3 Transmission Tunnel Triumph 8
O TR2/3/3A TR3 Transmission Removal Triumph 2
RedTR3 TR2/3/3A TR3 Transmission Differences Triumph 27
RedTR3 TR2/3/3A Removing TR3 OD transmission Triumph 5
M TR2/3/3A Draining and refilling TR3 transmission with OD Triumph 23
Moseso TR2/3/3A TR3 Transmission noises Triumph 11
K TR2/3/3A Toyota transmission for TR3=long distance driving Triumph 13
CCURTISS TR2/3/3A TR3 Transmission Tunnel Sealant Triumph 7
CCURTISS TR2/3/3A TR3 Transmission Questions Triumph 14
B TR2/3/3A tr3 transmission oil fill plug Triumph 18
White79MGB TR2/3/3A TR3 Transmission Oil Triumph 18
hondo402000 TR6 TR3 VS TR6 Transmission units Triumph 6
gubba TR2/3/3A TR3 B 5 speed Transmission conversion Triumph 0
S TR2/3/3A tr3 transmission Triumph 2
S TR2/3/3A tr3 transmission front seal Triumph 3
mcguijo TR2/3/3A TR3 Transmission Blues Triumph 16
jsneddon TR2/3/3A TR3 Transmission Oil Capacity Triumph 3
S TR2/3/3A Tr3 transmission oil Triumph 4
T TR2/3/3A Hole in transmission bellhousing TR3!!!! Triumph 5
T TR2/3/3A Proper oil TR3 Transmission Triumph 3
