TR2/3/3A TR3 Wheel Swap and Tire Size
oxendine
It's my understanding that TR6 steel wheels will bolt to a TR3 hub. Is this the case and if so, what size tire can be used?
Thanks, Donnie
TR3driver
Great Pumpkin - R.I.P
They do bolt up, I've been running them for many years now. There are several tire sizes that can be used, ISTR 185/65 was a good fit and reasonably close to the stock diameter. I'm currently running 205/55, which are quite a bit shorter than stock (affecting ride height and speedometer calibration) and may cause problems with rubbing on the sway bar & rear fenders.
TRMark
Bronze
I have been running steel TR6 wheels on my TR4 for years using a 195/65 tire. The wheels are 5 1/2" I recently bought a set of VTO wheels from Hap at Acme Speed Shop. I will sell the steel wheels. I have 5 of them, don't know how that happened, found the extra in the shop. I did not measure runout on the spare, the worst one on the car was .10 the rest were around .05. Not sure what they are worth.
TR4nut
A friend of mine recently swapped his wire wheels for 6" Panasports on his 3B - he put on 205s initially, but for the concerns Randall mentions dropped down to 195-65. I have 5.5" rims and 195-65s on my TR4, I think that size works well for both cars.
TR3driver
Yeah, I had the same problem with some old 5.5" alloys I tried. Offset is important!
vivdownunder
Keep a standard wheel and tire as a spare for the narrow wheel well.
And unless there's a luggage rack, pack a large garbage bag for carrying a wet flat behind the seats.
Viv.
PeterK
... AND don't forget to also carry a set of standard lug nuts for the spare if you're running alloys. duh - and a wrench for said nuts.
TR3driver
With the compact spare tire mounted on a standard rim, there is enough room to pack a cheap blanket instead of the garbage bag. It helps fill the spare tire compartment (so the tire doesn't slide around) and is also handy to kneel on while changing the tire (or lay on for other roadside tech sessions).
O TR2/3/3A TR3 Steering Wheel Swap Triumph 1
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
W TR2/3/3A TR3 wheel studs Triumph 4
T TR2/3/3A Is there any problem in putting TR6 plastic wheel covers & TR6 lug nuts on TR3 wheels Triumph 4
K For Sale TR3 Wheel spacers...Never Used...1/2 Price Triumph Classifieds 0
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
T TR2/3/3A TR3 wiper wheel boxes Triumph 5
charleyf TR2/3/3A Front wheel bearing--inner tr3 Triumph 4
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
Tinkerman TR2/3/3A 1960 TR3 A Steering wheel play or Lash Triumph 2
Scotsman TR2/3/3A tr3 front wheel hub stud removal Triumph 2
O TR2/3/3A TR3 Steering Wheel Hub / Control Head Triumph 1
B TR2/3/3A TR3 Steering wheel restoration Triumph 4
Number_6 TR2/3/3A TR3 Wheel paint Triumph 8
K TR2/3/3A Wheel Lug Nut Torque for a TR3? Triumph 2
K TR2/3/3A Tightening wheel bearing Nut TR3? Triumph 8
T TR2/3/3A TR3 steering wheel and indicator Triumph 5
O TR2/3/3A TR3 Wheel Bolt Pattern Triumph 1
M TR2/3/3A TR3 Steering Wheel Repair Triumph 5
O TR2/3/3A TR3 Wheel Studs, Couple of Hinges Needed. Triumph 2
S TR2/3/3A tr3 brakes-Rear wheel Triumph 2
K TR2/3/3A TR3 wheel specs? Triumph 3
K TR2/3/3A Source for TR3 wheel studs that are 1" longer? Triumph 8
K TR2/3/3A Installing wheel studs to hub TR3 Triumph 2
RedTR3 TR2/3/3A TR3 Wheel Track Spec Triumph 14
T TR2/3/3A tr3 steering wheel resto Triumph 5
mountainman TR2/3/3A TR3 Front Wheel Bearing Triumph 1
Marvin Gruber TR2/3/3A Early TR3 wire wheel set up. Triumph 9
T TR2/3/3A wheel spacers for TR3 Triumph 13
Brooklands TR2/3/3A Spare Wheel Door rubber gasket - TR3 Triumph 3
A TR2/3/3A TR3 steering wheel support Triumph 10
T TR2/3/3A TR3 wheel bolt pattern Triumph 7
K TR2/3/3A TR3 front wheel bearings [again] Triumph 3
S TR2/3/3A narrow wheel tr3 Triumph 13
K TR2/3/3A Who used 1/2" wheel lugs on their TR3 hubs? Triumph 1
NutmegCT TR2/3/3A TR3-4 owners: wheel poll Triumph 21
JPeter TR2/3/3A TR3 Rear wheel brake cylinders Triumph 7
fad64b TR2/3/3A TR3 steel wheel color Triumph 6
M TR2/3/3A TR3 Front Hubs/Wheel Bearings Triumph 7
JFS TR2/3/3A TR3 Rear Wheel Bearings Triumph 13
A TR2/3/3A TR3 Wire Wheel painting Triumph 2
martx-5 TR2/3/3A TR3 Wheel Info Needed Triumph 1
J TR2/3/3A Leaky front wheel cylinders-- TR3 Triumph 4
S TR2/3/3A TR3 speedometer and wheel revs per mile Triumph 6
R TR2/3/3A TR3 Timminge Triumph 11
