TR2/3/3A TR3 Steering Wheel Repair
mallard
Getting ready to start a repair on my steering wheel and was wondering if anyone has tried Gorilla Epoxy to fix minor cracks in the wheels rim. It sounds like it would work without having to spend all the money on a repair kit from company like Eastwood.
Geo Hahn
I have used JBWeld to fill those cracks. Pretty easy to sand smooth and match the contours, then of course the wheel will need a black finish.
M
mallard
Thanks George, JBWeld is a great product. It was on my list of things to use. I was just wondering about the Gorilla Epoxy since it's new.
apbos
PC-7 epoxy is what the kit uses. It is available at Ace Hardware.
Paul
tinman58
Keith!
Listen to Paul. His steering wheel came out great!
Most of what Paul does comes out great!
apbos
Thanks Dan! But I have yet to finish anything!
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
Tinkerman TR2/3/3A 1960 TR3 A Steering wheel play or Lash Triumph 2
O TR2/3/3A TR3 Steering Wheel Hub / Control Head Triumph 1
B TR2/3/3A TR3 Steering wheel restoration Triumph 4
O TR2/3/3A TR3 Steering Wheel Swap Triumph 1
T TR2/3/3A TR3 steering wheel and indicator Triumph 5
T TR2/3/3A tr3 steering wheel resto Triumph 5
A TR2/3/3A TR3 steering wheel support Triumph 10
T TR2/3/3A Is there a Delrin bush available for the top of TR3 steering column instead of felt? Triumph 8
B Wanted Need '58 TR3 adjustable steering set up Triumph Classifieds 4
C TR2/3/3A Installation of stator tube in steering column 1957 TR3 Triumph 2
Tinkerman TR2/3/3A 1960 TR3 A Additional steering question Triumph 4
M TR2/3/3A TR3 Steering lockstop set Triumph 4
M TR2/3/3A One more steering question TR3 Triumph 4
Tr3aguy TR2/3/3A Need TR3 bits for steering support!!! Triumph 18
M TR2/3/3A TR3 Steering box rocker shaft and drop arm Triumph 5
J TR2/3/3A How to fill TR3 steering idler? Triumph 10
luke44 TR2/3/3A TR3 Steering Column Blanking Plate Triumph 18
CJD TR2/3/3A TR3 Steering Wander Triumph 20
TRclassic3 TR2/3/3A TR3 Steering groan Triumph 6
M TR2/3/3A TR3 steering column mounting question???? Triumph 2
R TR2/3/3A TR3 Front Suspension and Steering Triumph 12
ekamm TR2/3/3A Tr3 steering box end plate Triumph 8
ekamm TR2/3/3A Tr3 steering rocker shaft bushing Triumph 1
ekamm TR2/3/3A Tr3 steering gear box removal Triumph 6
ekamm TR2/3/3A tr3 steering colmn felt bush Triumph 5
B TR2/3/3A 57 tr3 steering box Triumph 3
ekamm TR2/3/3A Tr3 steering rebuild Triumph 2
T TR2/3/3A TR3 steering column bracket Triumph 5
S TR2/3/3A Tr3 steering box olive Triumph 9
J TR2/3/3A tr3 notchy steering in parking lots Triumph 12
mountainman TR2/3/3A TR3 Hard Steering Question Triumph 16
T TR2/3/3A TR3 steering column/bad post Triumph 14
T TR2/3/3A tr3 steering box drop arm nut torque setting? Triumph 2
T TR2/3/3A yet another TR3 steering box question/hone? Triumph 9
H TR2/3/3A TR3 Steering Box Removal Triumph 11
Tinkerman TR2/3/3A Another Steering Box Question TR3 Triumph 4
J TR2/3/3A Rack and Pinon steering for TR3 at MOSS Triumph 1
G TR2/3/3A TR3 steering coulmn install Triumph 8
E TR2/3/3A TR3 Steering rack conversion Triumph 41
newmexTR3 TR2/3/3A Separating Tie Rod Ends from Steering Arms TR3 Triumph 18
A TR2/3/3A TR3 steering box rebuild Triumph 4
J TR2/3/3A tr3 steering box leak Triumph 3
K TR2/3/3A TR3 Steering:Nut that attaches drop arm........... Triumph 2
K TR2/3/3A TR3 front end..mounting wishbone near steering box Triumph 9
TR4nut TR2/3/3A Blanking off the spare steering hole on TR3/3A? Triumph 7
M TR2/3/3A TR3 Steering: Penrite v. Snythetic Triumph 4
newmexTR3 TR2/3/3A TR3 Steering Box Rebuild Service? Triumph 10
S TR2/3/3A tr3 steering Triumph 38
