TR2/3/3A TR3 steering wheel and indicator
tomgt6
I pulled the indicator to replace with a new unit. The tub in the new unit was about a foot long but when I pulled the old unit there was a copper tube from the indicator all the was to the front of the steering box. The old indicator tube was attached to this tube all the way to the front of the steering box.
Does someone have pictures of something showing how you need to re-assemble this.
I put the new indicator in and tightened the grub screws but the unit still wants to turn in the steering wheel. Shouldn't this indicator be locked in place?
Or does the horn and indicator float and spin around on the wheel?
OK did a bit more looking around and found that the tube has been modified on my car. So now the question is does the indicator spin with the wheel or always stay at 12?
What should this look like and with a new head how should it work? Any pictures and advice will be helpful.
The old unit was a pita so I don't have something to work from in how it should have looked and worked. Thanks everyone.
CJD
The tube has to go all the way to the steering gear box to hold the horn/turn signal in the correct orientation.
The oringinal "stator tube" is not just a straight tube, but a steel one with two places where the tube is expanded (like the barrel of a cartoon shotgun that blew up and split) to steady it inside the large steering tube. There is a notch at the horn side of the tube for the horn assembly to key into as you install it. This notch is long enough and wide enough to accept the key on the tube behind the horn assembly.
This inner tube installs first, and comes out the end of the steering gear box. A split collar and nut are installed...loosely at this point. You then install the horn assembly - properly keyed with the turn signal striaght up, and as you push it into place, the inner stator tube is pushed out the proper distance from the end of the gearbox. You can then tighten the collar nut at the gearbox, and the set screws at the steering wheel. Once the stator is positioned, you can later pull the horn button without having to mess with the position of the stator.
Unfortunately, I don't know of anyone who carries the stator tube...
John
T
tomgt6
OK, Update from more research.
The stator tube should have a slit in it from what I can see. PO made a tube with a cooper pipe an welded the clamp that attaches to the indicator at the tabs.
So here is what I did but I see I will need to do more work.
I cut the copper tube down 8 inches or so. I then slid the tube up inside the indicator tube but what I see I need to do now is cut a slit in the tube to look in the indicator.
How wide and long is the slit?
TR3driver
Great Pumpkin - R.I.P
That long tube down the center of the column is what is supposed to hold the control head from turning. There should be some dimples in the shorter tube that engage a slot in the long one. And then there is a compression fitting on the front of the steering box that locks the long (aka stator) tube from turning.
There are different ways to do this, but here is what I suggest:
Attach the wires to the control head, noting that the ring terminals have little pegs on them that engage with holes to keep them from turning and possibly shorting out. Pull the wires through the stator tube, until the end of the stator tube engages with the tube on the control head as far as it will go. Make sure the dimples engage with the slot. Use an ohmmeter or powered test light to make sure the turn & horn switches work as they should (no shorts or opens in the wires).
Put the "lantern springs" in place on the stator tube (there are tiny pips that should hold them). Center the turn mechanism (finger points down, away from the lever) and also center the steering wheel. If you have the adjustable column, move the wheel as far forward as it will go. Remove (if installed) the compression nut and sleeve from the front of the steering box.
Now slide the tube into place. Before the control head seats against the steering wheel, turn it so the operating lever points straight up (with the turn switch in the 'off' position). Push it all the way home (should be only a small, like 1/8", gap between the control head steering wheel). Tighten the 3 grub screws. Now, without turning anything, install the compression sleeve and nut onto the steering box, over the wire and stator tube. Tighten firmly.
Connect the wires and check that the turn signals and horn work as they should.
TR3driver
Oops, guess I'm a little slow typing. Took a break for a bite of breakfast :smile:
I don't think copper will work out well in this application. The tube has to be thinner than copper usually is, and also stronger.
For a proper stator tube, try Mark Macy ( Macy's Garage ). Realey Healey used to have them too, but they appear to be gone.
TR3driver
I disagree on that point. The "expanded" places are actually separate parts, the "lantern springs" that I mentioned before. Stanpart 56334 (but not available new AFAIK). But they are just to keep the tube from rattling against the steering column, not really required for operation.
K TR2/3/3A Non Adjustable TR3 Steering Wheel Triumph 7
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
Tinkerman TR2/3/3A 1960 TR3 A Steering wheel play or Lash Triumph 2
O TR2/3/3A TR3 Steering Wheel Hub / Control Head Triumph 1
B TR2/3/3A TR3 Steering wheel restoration Triumph 4
O TR2/3/3A TR3 Steering Wheel Swap Triumph 1
M TR2/3/3A TR3 Steering Wheel Repair Triumph 5
T TR2/3/3A tr3 steering wheel resto Triumph 5
A TR2/3/3A TR3 steering wheel support Triumph 10
T TR2/3/3A Is there a Delrin bush available for the top of TR3 steering column instead of felt? Triumph 8
B Wanted Need '58 TR3 adjustable steering set up Triumph Classifieds 4
C TR2/3/3A Installation of stator tube in steering column 1957 TR3 Triumph 2
Tinkerman TR2/3/3A 1960 TR3 A Additional steering question Triumph 4
M TR2/3/3A TR3 Steering lockstop set Triumph 4
M TR2/3/3A One more steering question TR3 Triumph 4
Tr3aguy TR2/3/3A Need TR3 bits for steering support!!! Triumph 18
M TR2/3/3A TR3 Steering box rocker shaft and drop arm Triumph 5
J TR2/3/3A How to fill TR3 steering idler? Triumph 10
luke44 TR2/3/3A TR3 Steering Column Blanking Plate Triumph 18
CJD TR2/3/3A TR3 Steering Wander Triumph 20
TRclassic3 TR2/3/3A TR3 Steering groan Triumph 6
M TR2/3/3A TR3 steering column mounting question???? Triumph 2
R TR2/3/3A TR3 Front Suspension and Steering Triumph 12
ekamm TR2/3/3A Tr3 steering box end plate Triumph 8
ekamm TR2/3/3A Tr3 steering rocker shaft bushing Triumph 1
ekamm TR2/3/3A Tr3 steering gear box removal Triumph 6
ekamm TR2/3/3A tr3 steering colmn felt bush Triumph 5
B TR2/3/3A 57 tr3 steering box Triumph 3
ekamm TR2/3/3A Tr3 steering rebuild Triumph 2
T TR2/3/3A TR3 steering column bracket Triumph 5
S TR2/3/3A Tr3 steering box olive Triumph 9
J TR2/3/3A tr3 notchy steering in parking lots Triumph 12
mountainman TR2/3/3A TR3 Hard Steering Question Triumph 16
T TR2/3/3A TR3 steering column/bad post Triumph 14
T TR2/3/3A tr3 steering box drop arm nut torque setting? Triumph 2
T TR2/3/3A yet another TR3 steering box question/hone? Triumph 9
H TR2/3/3A TR3 Steering Box Removal Triumph 11
Tinkerman TR2/3/3A Another Steering Box Question TR3 Triumph 4
J TR2/3/3A Rack and Pinon steering for TR3 at MOSS Triumph 1
G TR2/3/3A TR3 steering coulmn install Triumph 8
E TR2/3/3A TR3 Steering rack conversion Triumph 41
newmexTR3 TR2/3/3A Separating Tie Rod Ends from Steering Arms TR3 Triumph 18
A TR2/3/3A TR3 steering box rebuild Triumph 4
J TR2/3/3A tr3 steering box leak Triumph 3
K TR2/3/3A TR3 Steering:Nut that attaches drop arm........... Triumph 2
K TR2/3/3A TR3 front end..mounting wishbone near steering box Triumph 9
TR4nut TR2/3/3A Blanking off the spare steering hole on TR3/3A? Triumph 7
M TR2/3/3A TR3 Steering: Penrite v. Snythetic Triumph 4
newmexTR3 TR2/3/3A TR3 Steering Box Rebuild Service? Triumph 10
S TR2/3/3A tr3 steering Triumph 38
