TR2/3/3A TR3 Seatbelts
CJD
My TR3 came with no seatbelts...as most did. I'd like to add them, though. Does anyone have photos, or any details, about how the belts connect?
Thanks,
John
CJD
CJD
Thanks Andrew.
I didn't see that coming! I assumed they would anchor to the frame through the floor. If I am reading the diagram correctly, it looks like they mount right to the body vertical sheet metal. Is there any special reinforcing to the body to keep them from pulling through?
John
AEW
This was a google search hit...
https://www.wescoperformance.com/2-point-seatbelt-install.html
I guess I wonder if the Standard template is consistent with true safety designs. Seems I heard something about belt position needs to be on the lap more than across the gut. All this theory is way after Triumph would have published their answers.
Andrew Mace
CJD said:
Thanks Andrew.
Yes, John, mounting through the "heel board" is how I interpret those drawings. I suspect that heel board is a bit stronger than the floor pan on a TR3?
Oddly there was nothing with the original bulletin (at least my copy) about hardware, but I would assume it wouldn't be much different than what one might get today to do such an installation: quality eye bolt (or regular if preferred) and very substantial washers and such to spread the load as best that can be done. Stuff like this from Andover, whose products I have used and been happy with in the Herald:
PeterK
When I did mine, I added a 2x4" square of 1/8" plate steel on the bottom instead of the large washers to add more surface area to each mount.
CJD
CJD
Excellent info. Glad I asked, as I never would have envisioned the installation that way.
Thanks!
John
Andrew Mace
bnw said:
What about the pre-60000 body?
Hard to say. At the time of the bulletin, states such as Connecticut and New York were requiring front belts or, at least in New York's case, front seat belt mountings:
<span style="font-style: italic">NY Vehicle & Traffic Code:
§ 383. Safety belts and anchorage assemblies. 1....
2. Anchorage assemblies. No motor vehicle shall be sold or registered
in this state unless such motor vehicle is equipped with safety belt
assembly anchorages conforming to standards established by the
commissioner for each safety belt required in such motor vehicle. In
addition, no motor vehicle manufactured or assembled after June
thirtieth, nineteen hundred sixty-two shall be sold or registered in
commissioner for two safety belts for the front seat of such vehicle.</span>
HerronScott
Andy,
I tried to register so I could change that link as well but haven't gotten my registration mail yet.
Scott
jfarris TR2/3/3A Adding Seatbelts to a TR3 Triumph 4
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
R TR2/3/3A TR3 Wiper motor Triumph 10
H For Sale TR3 RHD tonneau cover nee Triumph Classifieds 0
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
5 TR2/3/3A TR3 fender patch panel question Triumph 10
