TR6 TR-6 Brake MC Reservoir Seal
fwtexasbj8
Doesn't it always happen this way? I was replacing the tires on my wife's TR-6 and since I never liked the way the brakes felt, I figured I would bleed them to be sure while I had it on jack stands. That led to the discovery the rubber lines in the rear were shot which fouled both wheel cylinders. Got everything replaced and then started to bleed the system. Ended up having to remove the MC because I could not get it to begin pumping fliud and bench bled it, after I tried all the other techniques on loosening the lines to no avail. In the process of looking at it on the bench, I could see the spring on the tip over valve was not right so I had to remove the reservoir from the cylinder. Sure enough, the clip was off the valve. No problem, everything back together without any problems!
Now it is all back together but I cannot get the dang reservoir to stop seeping between the tank and top of the cylinder. I put a thin layer of red grease on the rubber seals when I re-assembled everything thinking that would help. I had re-tightened the bolts as tight as I can but still leaks a little, not bad, but bad enough.
Does anyone have any suggestions on how to re-seal the reservoir? I have loosened the screws, wiggled it on the cylinder and re-tightened but still no luck.
TR3driver
Great Pumpkin - R.I.P
I had a similar problem with the Stag MC, even with new seals. I fixed it by laying a sheet of medium-fine sandpaper (about 300 grit as I recall) on a flat surface and rubbing the reservoir against it enough to true up the bottom surface and put a bit more 'bite' on the seals.
M TR2/3/3A Brake/Clutch Reservoir Seal Triumph 9
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
B TR2/3/3A Bubbling in brake reservoir. No pressure in lines Triumph 5
S TR2/3/3A brake reservoir on a tr3 Triumph 8
wangdango BJ8 brake reservoir? Austin Healey 7
vette Brake/Clutch Reservoir Austin Healey 14
H Adviced asked on unscrewing lid brake fluid reservoir Austin Healey 9
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
Rob Glasgow Brake/Clutch Reservoir Lines Austin Healey 9
B TR2/3/3A Gaskets for Brake/Clutch Fluid Reservoir? Triumph 15
Kleykamp TR2/3/3A brake reservoir cap leak??? Triumph 9
K TR2/3/3A TR3 brake fluid reservoir outlet at the bottom..... Triumph 0
krswen General TR Need help finding remote brake reservoir .... Triumph 2
krswen Need help finding brake reservoir Austin Healey 5
PatGalvin TR2/3/3A Brake Master Cylinder Fluid Reservoir Bracket needed, TR3A Triumph 6
nevets Replacing the brake/clutch fluid reservoir Austin Healey 21
Jim_Newman brake/clutch fluid reservoir Austin Healey 4
HealeyRick Brake Fluid Reservoir Leak Austin Healey 6
richberman brakes/clutch fluid out top of brake reservoir Austin Healey 11
RAC68 BJ8 Brake/Clutch Reservoir Fluid Loss Austin Healey 14
D 85 XJ6 brake fluid reservoir leak Jaguar 4
C Brake Fluid Reservoir Triumph 2
John_Mc Gray "sludge" in brake reservoir Triumph 4
A TR6 TR-6 Brake reservoir bubbles Triumph 11
dklawson Spitfire Brake MC Reservoir Seals for '72 Spit ? Triumph 5
Monark192 MGB-GT Remote Brake Fluid Reservoir on 67 GT MG 6
A Brake/Clutch Reservoir - any idea what it fits? Triumph 4
Moseso TR2/3/3A TR3 Clutch/Brake Reservoir Triumph 4
G My Brake MC Reservoir Fix Works! Triumph 14
G Brake Master Reservoir Weeping.......again Triumph 13
G Brake Master Cylinder Reservoir Nappy Triumph 8
martx-5 TR2/3/3A TR3 Brake Fluid Reservoir Triumph 1
mgbnew T-Series Which is which? Brake or clutch reservoir? 1 or 2? MG 7
GregW Brake tubing, Reservoir to MC Austin Healey 4
nevets brake fluid reservoir appearance Austin Healey 48
S '60 Sprite clutch/brake reservoir Spridgets 4
G Leaking brake fluid from reservoir Triumph 6
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
