Brake Master Reservoir Weeping.......again
G
I had a problem with my brake master reservoir weeping brake fluid from beneath the cap. No matter how tight or loose it was. Smart me I tried a new gasket, then a new cap, then a double gasket (like that worked!), then a whole new reservoir/cap/gasket combo. It still weeps. I have taken to keeping a diaper around the perimeter of the cap. Sweat bands work well. It is obvious when I look down on top of the translucent cap that the rubber gasket never quite seals. Anyone have a fix for this? Perhaps making up my own gasket from a slightly thicker rubber? These things have got to be all warped from the manufacturers. I have seen this before. Very frustrating as I use Dot 3, which would love to dribble down onto my paint.
At least colorful wrist bands make it rather festive under my bonnet.
LastDeadLast
Bill,
I've had two different MC's and they both did same as yours.. I figured it was the price of admission.
I'd like to know a "fix" for this one too, if it exists.
Platinum
Curious: Can you tell from the gasket if it's even being pressed into contact with the 'lip' of the rezzy? You say it never quite seals...
With the gasket out of the lid and wound "home" on the bottle, does it hit on a shoulder on the bottle's O.D.? Could you relieve the I.D. of the cap by chamfering it at the point where it hits and stops?
The other thought is: could the lip of the container be less-than planar at its circumference?
G
That's pretty much what I have deduced. Looks like they are injection-molded, and poorly done at that. My have to "shave" the lip flat with some sort of device.
Bummer.
Platinum
To be a thorough PITA, my "solution" would be to remove it from the car, get a ~flat~ surface (like a piece of marble or steel plate) and some #600 Wet-or-Dry sandpaper and "lap" the edge by holding the thing upside-down and slowly evening out the lip with "figure eights". Water would work as a lubricant.
Caution here: do NOT use Herself's marble countertop if there's ANY residual brake fluid likely to drip out. You'll pay, trust me.
EDIT: Just had a thought! Use that old flywheel as the flat surface!! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Andrew Mace
Bill, Shannon: were these new(ish) cylinders and reservoirs? did the weeping start right "out of the box" or were they on the car for some period of time before the weeping started? I've never owned a TR6, but the dual master cylinders on GT6s and Spitfires are very similar in design, and I don't recall ever having such a problem.
Rickc
Member
TR6BILL said:
........ It is obvious when I look down on top of the translucent cap that the rubber gasket never quite seals. Anyone have a fix for this? ......
Bill,
When I tighten mine back down, I can clearly see the rubber gasket getting evenly compressed around the entire circle. Since yours does not seem to be getting evenly compressed then I would agree with dre. Maybe if you have a small piece of flat stock steel, you might be able to determine "out of flatness" (sorta'speek) without having to remove it....but then you will need to remove it if you need to do a little sanding. Will be interesting to hear if this is an old or newly installed MC reservoir.
If you where to make up a new gasket, it would have to be thicker and much more pliable that OE material.
Rick C
TR3driver
Great Pumpkin - R.I.P
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif Except I don't think you need such a good surface in this case ... MDF will do fine; and I'd use coarser dry paper. I actually touched up my Stag reservoir "by eye" with a machinist's file and it now seals fine. Dunno if it's possible on the TR6, but with persistence the Stag reservoir can be removed with the MC still on the car.
Rickc
Member
Randall
Yes the reservoir can easily be removed but a full brake bleed is in order on re-install.
Good point on the mdf. Bill, What about putting some sort of powder (i.e chalk line powder) or paint or ????? on the surface of the mdf then putting it on the reservoir opening. You might get to see where the "low" spot is and simply take a fine file to it.
Just a thought. Would sure beat having to remove it.
Rick C
TR3driver
Rickc said:
Randall
I don't see it that way. If you've not used the brakes, the MC and everything past it should remain full of fluid with no problem. Any air in the passages between the MC & the reservoir will rise to the top when you fill it.
Of course if the brakes are spongy afterwards then you would want to bleed, but I don't think it would be necessary every time.
In my case it was the bottom of the reservoir that leaked, and I discovered the problem before bleeding the system, so I did have to bleed after facing the surface and reassembling.
T
Tinster
Andy-
Mine was/is brand new right out of the box.
It leaks also.
Bill could you post a photo of your temporary
fix that absorbs the brake fluid?
Doc- #600 grit will cut marble very quickly. A slab
of steel or glass is best . I've been known to use
the Mrs glass top stove for such projects.
d
G
Dale, any ole wrist sweat band will do. Just pop it around the top where it affixes to the reservoir. The more colorful the better!
Platinum
Tinster said:
Doc- #600 grit will cut marble very quickly. A slab of steel or glass is best . I've been known to use
the Mrs glass top stove for such projects. d
Dunno how ya figger the sheet of wet-or-dry would abrade the marble if used as a "fat slurface" to level the PLASTIC lip of a M/C... the abrasive side would be facing the work, not the marble. Unless of course you're suicidal. /bcforum/images/%%GRAEMLIN_URL%%/smirk.gif
bobh
Bill, Dale and Shannon,
What type of brake fluid are you using?
In general some fluids have a tendency to creep onto surfaces not covered in the fluid. You'll see this on your dip stick with some oils. The initial reading is higher than the second reading after wiping the stick.
I'm wondering if the 3 of you are all using silicon fluid and if silicon fluid creeps up the sides of the reservoir.
Creep is a good thing in some situations. Penetrating oil is designed to creep. For example;
P7â„¢ Penetrating Oil has a low surface tension, which allows it to spread into a very fine film. One 12-ounce can of P7â„¢ Oil will cover approximately 300 square feet of surface. This low surface tension allows P7â„¢ Oil to "creep" up surfaces against gravity. It will penetrate and coat 16mm of a threaded bolt in 15 minutes. P7â„¢ Oil will lubricate tight crevices and loosen frozen parts.
I've used regular brake fluid as penetrating oil. It's one of the best. So I don't know if creep has anything to do with your leaks or if it is caused by something entirely different.
I searched on Silicon creep and found various comments. For example;
https://www.secondchancegarage.com/public/106.cfm
"Silicon fluids were developed in the 1960s. The major advantage of silicon fluid is its absolute resistance to water, making it a "permanent" brake fluid. Its chief disadvantages are a slightly higher viscosity, tendency to "foam-up" during bleeding and refilling, and a high capillary action (its surface tension is lower, allowing it to creep, or spread out, along the walls of the brake components, sometimes causing seepage or leaks.) Most silicon fluid-equipped cars exhibit a softer, "spongy" brake pedal effort."
BOBH
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
PatGalvin TR2/3/3A Brake Master Cylinder Fluid Reservoir Bracket needed, TR3A Triumph 6
G Brake Master Cylinder Reservoir Nappy Triumph 8
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
bighealeysource Brake Master Cylinder Austin Healey 27
A Brake Master Cylinder Freeplay Austin Healey 11
volunteer Wanted: Brake Master Cyl. Repair Kit for Daimler DS420 Other British Cars 18
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
D BJ8 brake master cylinder question Austin Healey 6
D TR2/3/3A Brake Master Cylinder. Triumph 4
Michael Oritt Brake Master Cylinder access Austin Healey 0
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
R brake master missing seal Austin Healey 11
vickxxx T-Series Brake master adaptor MG 2
M TR6 Brake master cylinder question. Triumph 2
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
T TR2/3/3A another brake master cylinder question Triumph 16
M_Pied_Lourd TR2/3/3A Brake and Clutch Master Pushrod Question Triumph 4
T TR2/3/3A Aftermarket brake master cylinder 1961 TR 3A Triumph 11
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
H master cylinder brake vs mc clutch Austin Healey 14
RJS TR4/4A Brake Master Cylinder Cap Options Triumph 11
D MGA Master Brake Cylinder Leak MG 2
nevets question about brake master cylinder Austin Healey 12
Lukens More clutch / brake master cylinder questions. Triumph 7
L Initial Adjustment of Pushrod on BJ8 Brake Master Cylinder Austin Healey 5
mgedit TR2/3/3A Brake Line Master to Banjo Connection LHD 56 TR3 Triumph 4
Jim_Gruber Brake Master from Alternative Sources Spridgets 10
KVH Bleeding the Brake Master Cylinder Triumph 8
J TR6 TR-6 Brake Master Cylinder Seepage Triumph 4
J TR6 TR-6 Brake Master Cylinder-Rebuild or Replace ? Triumph 4
D Brake master cylinder Austin Healey 1
K TR2/3/3A TR3 Brake & Master Cyl "C" clips? Triumph 2
A Wedge 1980 TR7 Brake master Question Triumph 5
R TR2/3/3A TR 3a brake/clutch master cylinders/pedal movement Triumph 4
rlich8 TR4/4A TR4A Brake Master Connector Leak Triumph 2
A Divided brake master cylinder MG 6
1 Brake Master Cylinder Spridgets 11
K TR4/4A TR4A Master Brake Cyl Internal Spring Clip? Triumph 6
K TR4/4A TR4A Brake Master Cylinder Internal Spring and Triumph 13
E BE w/dual line brake master....90 degree fitting? Spridgets 12
E 1275 Brake Master Nylon Bushing Spridgets 3
