'60 Sprite clutch/brake reservoir
Sam1
Hi all,
I'm helping a friend restore a 1960 Sprite. We're wondering if it would be possible to swap out the single reservoir feeding the clutch and brake system for a dual setup found on later models. I tried searching the forums, but couldn't come up with anything pertaining to this type of modification.
Thanks.
screenprinter
Hi Sam1 - Just a suggestion before I bend your ear with my opinion - There's a dedicated Spridget forum a bit lower on the list which is swamped to drowning with Sprite/Midget finatics -
I'm sure that this can be accomplished if originality is not an issue - Note that on the sprite forum there are many members who race these little cars and I'm sure they convert the archaic stock systems to stuff that is pretty much state-of-the-art - after all, their butts depend on being able to stop in a pinch.
I don't know if later model Sprite stuff will work, but I've seen many conversion which use modern components - some off of Nissans and Toyotas which are not only a lot more available but probably cheaper.
So log on to the Spridget forum and post this question there and you'll have more answers than you can shake a stick at.
Welcome to BCF!
Bob M.
spritenut
I have the later dual set up on my Bugeye.
I opted for the 1967 set up because it doesn't have that funky pressure failure switch and the lines are the same size.
You do have to move the wiper motor (or install a later 2 speed wiper on the fender well) and make the pedal box hole wider and shorter. Wider isn't too hard and I just fashined a plate to cover the taller original pedal box hole.
Any pedal box from 67 on will work.
S
Sam1
Thanks for the replies and sorry about the mis-post. I didn't even see the Spridget forum until this morning.
I'll take everyone's ideas into consideration, though, and I'll let you know what I decide.
im_a_hypnotist 66 sprite mk III dual master brake/clutch cylinder Austin Healey 2
A For Sale Sprite/Midget 1275 clutch cover. Austin Healey Classifieds 0
O sprite clutch release Spridgets 1
K clutch 1969 sprite Austin Healey 4
O 65 Sprite Clutch Spridgets 4
RickB Clutch problem this morning MK2 Sprite Spridgets 4
N Clutch Wanted 1098 motor 1964 Sprite Mkll Spridgets 4
fmichaels 67 sprite clutch master trivia Spridgets 17
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 6
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
CARSINC Progress On My 1965 Sprite (update) Spridgets 3
Bayless Onslo the Sprite runs Spridgets 4
F Sprite Gearbox Spridgets 5
CARSINC Sprite bonnet emblems Spridgets 4
George Zeck SOLD!! 1964 AH Sprite MKII Spridgets Classified 0
drooartz A disassembled sprite takes up a lot of space! Spridgets 30
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
CARSINC For Sale Sprite Differential Spridgets Classified 0
CARSINC For Sale AH Sprite Axles and Hubs Spridgets Classified 0
Bayless What size battery for my '67 Sprite? Spridgets 5
CARSINC 1965 Sprite Bugeye Spridgets 5
CARSINC Sprite Electrical System Information Spridgets 2
Boink 3D Sprite Model Spridgets 3
A Sprite Tacho Spridgets 2
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
S Calling All Spridget Owners & Race Fans - Sprite Turns 65 Spridgets 3
Bayless How does '67 Sprite top attach to body? Spridgets 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
D Whitworth on 59 Sprite. Spridgets 11
N For Sale Austin Healey Frogeye Sprite Spridgets Classified 0
D Sprite Model Identification Austin Healey 2
S Sprite Fuel Pump Upgrade Austin Healey 1
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
Bayless My primrose Sprite Spridgets 3
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
Bayless A Sprite gets some paint finally Spridgets 2
N Sprite "Ribcase" Transmission Austin Healey 3
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
tr6nitjulius For Sale 1967 Austin Healey Sprite Mark 111 Spridgets Classified 0
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
J Wanted Austin Healey Sprite Bonnet Austin Healey Classifieds 4
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
SD Bugeye For Sale 59 sprite Spridgets Classified 9
R Has this ever happened to you? Any odd Sprite story... Spridgets 8
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
