MGB-GT Remote Brake Fluid Reservoir on 67 GT
Monark192
Here it is. Clausager mentions that it was for cars "destined for France and other Benelux countries"
Wonder how it got to California.
Platinum
My guess would be via USAF.
Monark192
Monark192
Maybe, but the car came with the orginal service book showing it was sold by Hollywood Motors to a Mr. Miller who lived in LA. A few other receipts indicate he owned it until at least 1975 when he had a new muffler fitted for $29.00 dollars.
Platinum
Shoots my theory down in flames. :shocked:
Monark192
Monark192
Do you know if there were any other unique features to the european cars - like speedos in KM (mine is in Miles) or...?
bob67bgt
Some early euro cars had steering column locks and different serial number plates with car weights on them in certain countrys. 2 color lens also on the park and tail lamps.
Hamish Racing TR2/3/3A Remote brake light switch Triumph 5
RAC68 Alternative Remote Brake Booster Austin Healey 3
krswen General TR Need help finding remote brake reservoir .... Triumph 2
B General MG Remote Starter Switch MG 6
WHT Remote Clutch Slave Cylinder Bleed Extension Austin Healey 11
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
K TR2/3/3A Remote starter to alternator connection.... Triumph 10
A Transmission remote - Sprite Mk2A Spridgets 6
steveg Remote clutch bleeder setup Austin Healey 7
P Can I have door remote opening mechanisms refurbished? Austin Healey 1
richberman remote unit part? Austin Healey 1
bthompson Remote starting quandry... Spridgets 5
Wirewheels Remote purchase help needed! Triumph 8
pipercollins 1500 Drain Plug with Remote Dipstick Triumph 7
M Remote Vacuum Servo Spridgets 14
R Remote Oil Filter TVR 0
B Remote door lock question Jaguar 8
bighealeysource Help - looking for BN6 door remote assemblies Austin Healey 4
T Boot Remote Lamp Spridgets 2
T Remote starter question Triumph 4
drooartz Smooth case remote shifter on a rib case Spridgets 7
Westfield_XI Remote Oil Filter Spridgets 2
GT6_Mark Remote/Central Door Locking Triumph 7
healeyboz remote bleeder Spridgets 7
boeingpilot Remote Starter for 2001 Disco Rover / Land Rover 1
H Remote starter question MG 2
weewillie remote clutch bleeder Spridgets 18
S remote tranny filler Spridgets 3
philman shifter remote Spridgets 5
P remote servo unit on a Triumph? Triumph 1
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
