Leaking brake fluid from reservoir
G
Hey guys,
Help me with a problem. I am leaking brake fluid (dot 3 paint remover) from my master cylinder reservoir cap no matter how tight I screw it down ( or loose ). Every thing in the hydraulics is new. I have to remove it all to repaint ( bummer ) and want to solve the problem before I reinstall. Someone suggested I may have air in the line, hence causing hyper-pressure in the reservoir and forcing fluid out the cap seal.
Too, when reinstalling the slave reservoir, I bought a "racing type" braided hose from the slave cylinder to the piping, thinking the nylon original style hose is a weak point. The instructions that came with it said "not for street use!" Something about improper installation possibilities and "shorting out". Whaaa? Shorting out what? I always thought that the nylon hose was a bad idea but maybe I am wrong and should stick with original equipment stuff. Any ideas?
Tired-of-repainting-in-Louisiana
Bill
(Oh yeah, my car is a cherry [green actually] 1973 TR6)
XK4
IMO it does sound like the system has not been bled enough to remove all of the air from the line or cylinders. Also the fluid shouldn't be filled all the way to the top of the reservoir. It needs space to flow when the fluid gets hot (from hard braking).
My guess with your "shorting" is that the hose has a braided stainless cover. These things eat thru wiring insulation like a hungry wolf and being stainless if it does eat thru some wiring it will be a direct short complete with sparks, smoke etc.
Just make sure no wiring is close to it and it will be fine.
Jim
Larry Kronemeyer
Brake lines and hoses stating not for street use are not DOT certified. The unions and consistency of the materials are not age tolerant or road dirt tolerable, most are used for racing and show.
Larry
Darwin
Bronze
Get ahold of a Mityvac and use it to clear your lines. Also check that you are getting fluid to all 4 wheeels with pressure, sounds like a restriction someplace in the circuit. I have also been told that you should use DOT 4 brake fluid or DOT 5 silicone as the DOT 3 will rot the natural rubber seals in our LBC's. Noticed a lot of rubber "goo" in the piston bore on my spitfire when I rebuilt them this summer and it was caused by the DOT 3 I had been using.
Jon12
Do not use dot 3. NO DOT 3. I made that mistake when I first got my sptifire and now a rear wheel cylinder is leaking and my clutch slave cylinder needs to be re-build. So my next project is rebuild all the rubbers in the hydraulic system.
Use castrol LMA, dot 4 or dot 5. Don't mix dot 5 with any thing else though.
Dave Russell
Yoda - R.I.P
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Jon12:
<hr></blockquote>
Jon,
I don't agree. There is very little difference between DOT 3, & DOT 4.
See this link;
https://www.team.net/html_arc/tvr/200108/msg00027.html
I do agree with using LMA. Quoted from another source;
Castrol brake fluid, GT LMA is a DOT 3- DOT 4 with a glycol ether ester base which is considered to be synthetic in origin, although it is not advertised as such. Castrol GT LMA, which exhibits low moisture activity and exceeds the
most severe performance and safety requirements, is the fluid of choice. For completely reliable brake operation, maintain the required brake system service schedule and use Castrol GT LMA Brake Fluid. The "scoop" is.... Lucas Girling is the brake manufacturer, and Castrol is "Girling Approved".
G
Dave,
I concur on the use of Castrol LMA DOT 3. It is the only proper fluid to use in Girling systems. Silicon fluids will give a "mushy" feel to the braking. I will re-bleed everything, after repainting. Might go with a oil-rig type epoxy coating beneath the hydraulics to prevent the cursed "curled paint syndrome". My car is so modified that I am not worried about sticking to original everthing. Whenever I do modify it is to "improve".
Thanks for the tips, guys.
Bill
F Girling Brake Fluid Reservoirs Leaking Austin Healey 12
delisaj TR6 TR6 Leaking brake fluid Triumph 1
regularman Gear leaking from axle housing into rear brake drum Spridgets 3
C TR6 Brake servo leaking Triumph 3
R TR2/3/3A TR3A front brake cailper leaking Triumph 7
G Brake switch leaking Triumph 17
JodyFKerr Spitfire Brake pressure sensor leaking ['78 Spitfire] Triumph 6
doughairfield Brake Master Cylinder leaking Triumph 11
bigjones Brake drum leaking differential oil Spridgets 29
Nelson Leaking brake line flares Spridgets 15
RickB Rear brake cylinder leaking - just a wee bit... Spridgets 11
tr6web TR6 TR6 leaking at brake pedal Triumph 12
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
S Leaking HD6 Rear Carb Austin Healey 10
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
bighealeysource T-Series My older Brooklands steering wheel is leaking ! MG 4
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
S TR2/3/3A rear main seal is leaking Triumph 13
R TR2/3/3A Leaking O.D. section of Transmission Triumph 43
E Oil leaking from the Tachometer cable Austin Healey 5
I TR6 TR6 - Fuel leaking from bottom of Evaporator Canister Triumph 11
T TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
Jim_Gruber BE Steering Rack-Leaking 90w Spridgets 5
AUSMHLY BJ8 Rear Wheel Cylinder leaking Austin Healey 30
jfarris TR2/3/3A Leaking Fuel Pump Triumph 11
drooartz Leaking 5-speed drain plug Spridgets 26
S TR2/3/3A and the radiator was leaking. Triumph 7
H TR4/4A Leaking ft hub seals Triumph 5
D BT7 rear wheel leaking Austin Healey 25
N Leaking Carburettor Austin Healey 11
B MGB Hif’s Rear leaking gas MG 11
J TR4/4A Head leaking water Triumph 14
T TR4/4A Tr4A oil leaking from timing cover Triumph 13
RJS TR4/4A Head Leaking Coolant after Coolant Flush Triumph 15
R soft plug leaking Austin Healey 45
George Zeck Master Cyl Leaking .... Spridgets 5
M TR2/3/3A O/D brass cap leaking Triumph 5
F Leaking rear axle hub [BT7] following instalation of new seal! Austin Healey 9
rjc157 Leaking steering box Austin Healey 4
B mysterious leaking of SU HD8 Jaguar 9
F Leaking rocker/bable cover gasket BT7 Austin Healey 6
B TR6 Oil pressure gauge-oil leaking behind the glass Triumph 2
B Rear Engine Side Cover Leaking Austin Healey 9
D Overdrive Leaking Oil Austin Healey 4
KVH TR4/4A Oil Pressure Banjo Nut is Leaking Triumph 6
H TR2/3/3A Leaking Fuel Pump Sediment Bowl Triumph 5
