Threads
DNK
TR6 , the adapter from the manifold pipe to the thermostat housing.
BSP ,yes but does any one know if it is BSPP or BSPT???
TR3driver
Great Pumpkin - R.I.P
I'm not even certain it's BSP, since similar connections on the TR2-4 are NPT.
However, if it is BSPP (parallel threads), then there will be some other arrangement for sealing, like a fiber washer. Only tapered threads are self-sealing.
DNK
DNK
There is a washer on it which makes me think BSPP
Darrell_Walker
That part looks very much like the PCV connection to the intake manifold on the 4A. Definitely an odd size, and not tapered threads.
Brosky
Don, I just sold my spare a few weeks ago so I can't go down and check it for you. I cannot find the spare fitting that goes in there either.
Darrell_Walker
Don,
Do you need the fitting, or just want to screw something in the hole? I have an extra or two (assuming the 4A version is the same). Let me know.
-Darrell
DNK
DNK
Actually trying to wrestle one out of a spare housing. Everything came off but that bugger.
Gonna put an adapter to NPT there.
Darrell_Walker
Cut the end off, and tap what is left?
DNK
DNK
I kind of screwed up the one I had by trying to tap it. Not a lot of meat there
DNK
DNK
Well, never mind.
Broke it off trying to get it out.
Ended up taking it (or is that bring it) to the machinist and he tapped it to 3/8's NPT
Of course this was after I drove to S. Seattle to get the adapter!! :madder: :madder:
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
TR3MT TR2/3/3A Whitworth Threads (as on the bolt) Triumph 6
B Damaged threads in the gas tank Austin Healey 7
nichola TR6 Water pump to manifold adaptor threads BSPT or BSP or ??? Triumph 17
S Stripped Threads Austin Healey 10
T why would an intake manifold stud have both coarse and fine threads? Spridgets 8
JimLaney Organizing threads into book? FORUM Navigation Questions 10
JimLaney Whitworth Threads or Just Nuts! Spridgets 5
Jim_Gruber 1/4 Elliptic Spring Clamps - Are those Whitworth Threads on those 1/4 Screws Spridgets 7
vette Threads for the Water Temp Sender Austin Healey 6
R BJ7 spark plug threads Austin Healey 17
Mickey Richaud General MG Two More Threads! MG 0
Basil Admn Note Using Prefixes to filter threads of interest Triumph 5
Basil Admin Note Use Prefixes to filter threads you read MG 4
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
KVH TR4/4A Wrong Threads on New Fuel Pump? Triumph 13
K TR2/3/3A Gearbox drain plug threads stripped? Triumph 8
S TR2/3/3A Spark plug threads Triumph 10
PatGalvin TR2/3/3A Heater Spacer Threads are a mystery Triumph 4
M stripped threads on master cyl Spridgets 12
K TR2/3/3A Gearbox drain plug threads stripped? Triumph 1
Jer chasing spark plug threads on head? Spridgets 8
A TR2/3/3A TR-3A Windshiedl Tenex Peg Set Threads Triumph 2
T TR2/3/3A What size and threads for corner finisher on TR3A windshield Triumph 3
S Where are the threads from 11/7 - 11/17? Austin Healey 2
KVH What happened to all the threads between "today" and November 6? Triumph 6
TulsaFred Harmonic balancer threads Spridgets 2
J Stripped threads engine block Triumph 7
L Removing chrome from threads Spridgets 16
M Bajo bolt and rocker pedestal threads.. Austin Healey 6
J threads on the fill plug for the steering box? Austin Healey 1
rikiwho123 uys what can be done to rstripped threads in head? Triumph 11
RickB Prestige Auto Trim zipout window- threads unravel Spridgets 1
J BN1 King Pin Nut Threads Austin Healey 1
T BE Quarter Elliptic Mounting Bolts - threads gone Spridgets 5
Don Elliott TR2/3/3A Stripped threads - TR3A block RHS rear ead stud Triumph 9
Ohiobugeye Metric or US Standard Threads? Spridgets 26
B shift lever threads Austin Healey 6
bthompson Nigel's new threads: a winter tale. Spridgets 5
davidk Stripped threads in oil pan front saddle block Triumph 12
BobbyD Stripping Aluminum Threads Triumph 17
M Block threads stripped torquing head Triumph 16
Dougal Front damper striped threads Austin Healey 30
B Manifold stud threads. MG 21
G What threads on 1500 oil sending unit? Spridgets 1
M Grease Nipple Threads Triumph 2
Morris 1500 oil filter threads Spridgets 4
Tinkerman Gear shift lever threads Triumph 21
JPSmit Gear Shift threads and trivia question Spridgets 1
6 Search old threads? Spridgets 2
