TR2/3/3A Heater Spacer Threads are a mystery
PatGalvin
Hey guys
What is the thread pitch for these spacers? I removed the spacers and cleaned them up as part of the heater refurbishment. And threw the nuts in the trash as they were very rusted. Just assumed they were 1/4-28. Well, they are indeed 1/4 inch but not 28 TPI. My thread pitch gauge seems to show they are 27 threads per inch. Well, I just don't see 1/4-27 nuts at my local hardware store. Any thoughts on this? I may just replace them with machine screws and add a couple nuts as spacers if I can't figure this out shortly.
TR3driver
Great Pumpkin - R.I.P
PatGalvin
PatGalvin
Thanks Randall. I had a 28 and 27 gauge but from there, my next coarser was 20. Thanks for solving this one for me.
pat
TR3driver
You could try a lock nut, The plastic inside the nut will conform to a little change.
True, but the steel part of the threads won't.
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
E Heater install Spridgets 2
R 3000 Heater Valve Austin Healey 4
KVH General Tech Heater control valve/cable Triumph 1
R TR6 Heater box Triumph 6
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
E MGB MGB heater motor problem MG 3
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
D Heater knob removal Spridgets 6
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
R Bugeye heater cable Spridgets 12
E austin van heater removal Other British Cars 0
Lin Heater water valve question Spridgets 2
T Bug Eye Heater Switch Help Spridgets 2
T Heater Door Spring Austin Healey 1
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
H BJ8 Heater Valve/Control Tap Austin Healey 3
jlaird MGB Heater MG 5
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
6 Smith heater rebuild Austin Healey 8
Healey Nut Heater Box Installation Austin Healey 4
CJD TR2/3/3A Heater Delete Triumph 15
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
F TR6 Heater Triumph 7
C Water flow in heater? Austin Healey 5
C Heater knobs won’t stay on... Austin Healey 4
Lutz Kramer Heater Control Valve function Austin Healey 2
S Heater and fan control replacement - any advice? Austin Healey 9
S Wanted Austin Healey heater assembly Austin Healey Classifieds 1
C TR6 Heater Removal Triumph 2
R BJ7 heater blower vibration Austin Healey 11
wangdango BJ8 heater blower? Austin Healey 4
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
F Heater valve/tap gasket- Install dry? Austin Healey 10
F Heater pipe and air duct routing BT7 Austin Healey 3
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
L TR2/3/3A Heater ID Triumph 5
F Help need reinstating my heater - BT7 Austin Healey 7
C Testing heater core Austin Healey 9
S TR2/3/3A power wirer for the heater switch Triumph 16
glemon Shop Heater Restoration & Tools 17
D Smiths Heater rebuild. Restoration & Tools 1
D TR2/3/3A Smiths Heater rebuild. Triumph 2
Got_All_4 TR6 Heater upgrade Triumph 6
Michael Oritt Heater motor or switch problem Austin Healey 1
B TR6 Heater controls stiff Triumph 4
edkap2002 TR6 Heater Control Valve Triumph 9
