Grease Nipple Threads
mylesw
Hello
Can someone tell me what sort of threads are on the grease nipples that fit in the lower A arms on a TR4? Looks like it make be 3/8" fine thread though I'm sure it's probably something more exotic... I need to find a tap to clean mine up.
Thanks
Myles
TR4nut
Myles-
I believe 1/8"-27 NPT pipe tap. It is similar to 3/8"-24 which what you'd have with 3/8" fine thread. Those nipples are hard to get back on, I nearly messed up one of my a-arms trying to get things put back together. I may have one because of that fiasco but I'm not positive.
Randy
edit: Just checked, yes I did buy this tap to fix up the same problem - so if you'd like to borrow it, pm me.
edit #2: Just checked the team.net archives to refresh my memory. I think the original was 1/8-28 British Standard Pipe, but the complication is that it is pretty exotic and the nipples you get here are 1/8-27 National Pipe Thread. The thread pitch is close enough that I think it will mate fine. Someone with better technical knowledge may have a more correct story - but I know I bought the tap I have to fix this problem, and it did!
D TR2/3/3A grease nipple/zerk Triumph 6
MGTF1250Dave TR2/3/3A TR3 Drive Shaft Grease nipple Triumph 4
fmichaels a-arm fulcrum grease nipple Spridgets 10
T Missing grease nipple on clutch mechanism? Triumph 16
L Red Rubber Brake Grease Austin Healey 2
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
drooartz What am I seeing - oil/grease on wheel Spridgets 20
Hangtown Healey King Pin Bushings Grease Groove Austin Healey 8
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
T TR2/3/3A Steering box oils - grease ? Triumph 20
Jayplum TR2/3/3A Grease cap Triumph 25
K For Sale Original Grease gun and jack....complete your TR3 collection. Triumph Classifieds 0
AUSMHLY Grease type for zerk fittings Austin Healey 7
warwick-steve Missing grease cap in front hub Austin Healey 8
warwick-steve Front hub bearing grease repacking Austin Healey 28
S Grease Gun Recommendation? Spridgets 7
steveg Recycling grease question Austin Healey 11
R grease for windshield wiper motor- BJ7 Austin Healey 4
C TR2/3/3A Grease Zerks Triumph 7
S TR4/4A how ro grease steering box? Triumph 4
C General Tech Grease and Grease Gun recommendations Triumph 12
Martinld123 Grease Retaining Cup Not Tight Fit Austin Healey 2
CJD TR2/3/3A Grease Gun Color Triumph 9
N Lockheed brake assembly grease??? Spridgets 2
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
P TR6 Grease job Triumph 6
Popeye TR4/4A Stub axle - grease or no grease? Triumph 4
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
M Oil Gun vs Grease Gun Spridgets 21
tahoe healey dielectric grease Austin Healey 13
S How much grease for the drive [prop] shaft plunger Austin Healey 3
T TR2/3/3A Windshield Wiper Motor Grease Triumph 4
S Plugged Grease Zerks Spridgets 7
S Will copper grease work for squeeling brakes? Austin Healey 3
charleyf TR2/3/3A Rear axle grease Triumph 0
K TR2/3/3A Greasing the idler arm grease zirk??? Triumph 3
R TR2/3/3A Grease fitting list Triumph 5
simon1966 Current day grease choices? Austin Healey 3
RJS TR4/4A Grease for IRS Axle Shaft Splines Triumph 5
RJS General TR U-Joint Grease fitting interferes Triumph 4
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
AUSMHLY Distributor grease Austin Healey 2
K TR2/3/3A Front wheel bearing grease seal with felt packing? Triumph 4
K TR2/3/3A Trunnion oil/grease again? Triumph 1
brohawk TR6 Grease on rear hubs Triumph 8
