shift lever threads
bowen
I have a 1962 BT7 with a side shift transmission. The shift lever is the "s" configuration. The threads are damaged and I want to trace them with a die. Does anyone know the thread information for this type lever. size,fine, or course threads,etc.
thanks
John_Progess
Bowen,
My car has the center shift but Moss lists the gearshift knob as the same part number. Mine is 3/8" diameter with 16 threads per inch (coarse threads). Have a good day!
John
Rob Glasgow
Speaking of the two types of levers used on the 3000 side shift transmissions, does anyone have an opinion why the factory made the change from a single bend to the double bend? I've only had experience with the single bend so I can't comment on why an extra bend would be better. Any ideas?
davidb
Bowen,
I ran a die down the shaft of my side shift(S-shaped BT7, like yours) and found that a 7/16 NC(national coarse)14 fit well, with very little slop, even though the thread gauge prescribed a 16 thread size would be a best fit. I found the 3/8 NC16 was, in fact, too snug and I think it might take off some metal. That may be because the chroming process adds some metal to the shift stick and gives it a thicker profile. If you can find a 7/16 NC16 that might be your best bet. But If your threads are crushed or rusted, try the 7/16 NC14 first. You might want to wrap some teflon tape to give it more "bite" when you screw the shift knob back on. You can always take metal off later if this isn't a snug enough fit for you, but you can't put metal back on......
Cheers
Dave
bob hughes
(but you can't put metal back on......)
I hope you can, I have the centre shift and PO put an Aluminium Knob on with a grub screw to tighten onto the threads, but it revolves. Result - threads are shot to ribbons.
Plan is to remove shift stick, weld up threads, turn down the result on a lathe and re thread and re chrome. But that is for the future, it would be difficult with the offset stick but not impossible - it would mean a lot of careful filing and grinding first.
Bob
zblu
Why not just use a two pack epoxy to glue it on with?, or failing that butter it up with devcon and recut the threads?
davidb
I guess you could also turn the shift lever down to the next thread size that gives you some decent grip, and find an mating insert that could then be drilled and glued into the shift knob.
Tinkerman Gear shift lever threads Triumph 21
S Gear Shift Lever Travel Austin Healey 13
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
R RIB CASE SHIFT LEVER Spridgets 0
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
S CHROME RING, shift lever grommet ....? Austin Healey 3
T Ribcase Shift Lever Installation -Bushing Spridgets 1
J BN2 Shift Lever Bushing Replacement Austin Healey 6
C TR2/3/3A Rotating shift lever Triumph 12
Rob Glasgow Wanted Austin Healey Gear Shift Lever Austin Healey Classifieds 2
C TR6 Shift lever Triumph 4
G BJ-7 Center Shift Gear Lever and bush Austin Healey 4
Michael Oritt Shift lever issue [No Healey content] Austin Healey 0
Michael Oritt Gear shift lever modifiacation [No Healey Content] Austin Healey 7
Rut 5 speed gear shift lever Spridgets 28
Rut MGB MGB OD gear shift lever MG 0
P Sprite Shift Lever Spridgets 20
6 Gear Shift Lever Spridgets 3
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
TomMull Post-War Other Herald shift lever Triumph 3
PatGalvin TR2/3/3A Shift Lever Question Triumph 19
bthompson A quick 1500 fix for when you go for reverse and rip off your shift lever! Spridgets 4
T TR2/3/3A TR3B gear shift lever Triumph 6
brgrmyster GTG6 Gear Shift Lever Inner Ferrule? Triumph 0
PAUL161 Gear Shift Lever Thread Size? MG 28
M Datsun 210 transmission 5 speed shift lever Austin Healey 4
Schroeders Any of you fine folks have 1275 shift lever FS? MG 2
K TR4/4A vibrating TR-4 shift lever on accelleration. Triumph 1
H TR2/3/3A TR3 Shift Lever Removal Triumph 24
d_valentino Looking for a shift lever for a BN2 Austin Healey 2
J Replacing the nylon shift lever bushing Austin Healey 8
jbowlby 1275 Ribcage Shift lever Spridgets 2
Jim_Newman Shift lever boot Jaguar 3
davidk TR6 Shift Lever Position - TR-6 Triumph 5
davidk Gear Shift Lever Vibration Triumph 4
Bruce_B Triumph Overdrive Shift Knob and Lever Triumph 9
aeronca65t MGB MGB Shift Lever Removal? MG 8
vping MGB Shortening a MGB shift lever MG 51
W Shift lever retainer plate Spridgets 2
jpr28056 Gear shift lever twisting Spridgets 10
A TR6 Need TR6 shift lever measurement Triumph 4
trrdster2000 Shortened my Shift lever Triumph 8
P loose shift lever Triumph 7
T Shift lever removal Triumph 29
tahoe healey shift lever removal Austin Healey 17
C TR2/3/3A Motor and Trans Out!!! TR3 shift lever??? Triumph 6
Tinkerman TR2/3/3A TR-3, Pitting on gear shift lever ball. Triumph 2
AHS Side-Shift Gearbox Austin Healey 3
bighealeysource Side-Shift Transmission Austin Healey 13
