TR2/3/3A Shift Lever Question
PatGalvin
I have the HVDA tranny conversion and just installed what I thought was a TR3 Shift Lever. But, the top of the lever is much larger diameter than the shift ball that I have. Do any of you know if this is a stock TR3 lever? If so, what part am I missing in order to mount a shift knob? (as info, the shift lever seems to work fine.
Thanks
Pat
TR3driver
Great Pumpkin - R.I.P
Yup, that's it. It's a weird thread, too, not easily found. You've probably got a TR4-6 shift knob.
PatGalvin
PatGalvin
Thanks Randall
Yep, I think you are correct. My brand new sexy wooden shift knob has much smaller diameter hole in bottom. Thanks for quick response.
pat
mgedit
TRF carries one that presumably has the correct thread. It is hard rubber material and narrow, not round. Part 109045 ... on sale right now till midnight for $12 (NFI). Cheers, Mike
pdplot
Back in 1957, I replaced the small rubber TR3 knob with a black tourmaline doorknob. I had to solder in a new thread as I recall some 50-plus years later. Worked fine too.
Jerry
Pat,
Let me know the approximate thread and size. I have one die that I bought just for gear shifts for one of the cars. It is a really odd die size.
Jerry
PatGalvin
PatGalvin
I bought the $12 TRF hard rubber knob for now (the tall one). But, ultimately I'd rather run a smaller wooden knob with the red TR3 flag on it. Silly detail, but I think it will look cool. Seems like I could cut an inch off the lever, JB weld or solder in a stud (in whatever appropriate thread pattern will work on newer knobs), and have this one solved. Any thoughts?
Starting to move my car out of the garage (under it's own engine power). So, I'll be sending a video soon of me doing laps up and down the court, after 7 years of wrenching on this thing.
Pat
sp53
It might be better if you have an old knob to try and get the threaded insert out of that and put that in a knob you like
CJD
That's a great idea, Steve! My knob is the worst looking part on the planet, but the insert will come in handy. Glad you guys posted before I tossed it...
PatGalvin
PatGalvin
Is that a shift knob? Looks like something generated around a campfire, when making Smores?
pdplot
Looks nasty! I replaced my rubber knob because rubber dust was coming off on my hand. The hard doorknob cured that plus it took less effort to shift with more leverage provided by the bigger knob. The leather knob on my TR6 looks and feels better than that old TR3 ever did. If it fits a TR2, 3 or 4, perhaps that's the way to go if you don't care about authenticity. I sure don't.
martx-5
The threads on the shift lever are 7/16"-32.
PatGalvin
PatGalvin
Not having any idea where to find such a nut, I did some google searching. I can't find jam nuts with 7/16-32 but it looks like a common size for "panel nuts" used for switches. Jameco Electronics sells them, as do other electronic supply houses. Those nuts would be thinner than a jam nut. If anyone knows where a 7/16-32 jam nut could be found, I'd be very curious.
pat
TR3driver
I But, ultimately I'd rather run a smaller wooden knob with the red TR3 flag on it.
Looks like LBCarCo might have a few left:
https://www.lbcarco.com/cgi-bin/gen5?nextform=/gearknobcloseout.html&t=_top&o=
They also show up on eBay from time to time; although you have to check carefully for fit (as you may have already learned). There were some made that had interchangeable plastic inserts to let them fit multiple cars; but in general a TR4 knob won't fit a TR3.
I got kind of disgusted with the old AMCO ones, kept splitting the walnut around the insert (probably from over-enthusiastic shifting). But they did look nice!
BTW, if you can find one of the locknuts, you can use it to adjust the height of the knob to some extent. Personally, I prefer it short as otherwise the side of my hand tends to drag on the bottom of the dash, which wore the side of my old driving gloves. Especially on my former TR3A, which had the clip for the in-line tail light fuse right there, which had a sharp edge on it.
FordFiesta
Besides the stock knobs available new, new-old-stock and used wood AMCO knobs show up fairly often on Ebay
SteveBones
Macy's garage I believe sells them (If you are talking about the nut that goes on before the shift lever to secure it - stop it from spinning).
Geo Hahn
The San Diego Wild Animal Park (now the Safari Park) has an abandoned Land Rover as part of the Heart of Africa exhibit:
Peering in one can see an interesting feature:
Sadly, after being there for many years someone finally broke into the cab and swiped that knob.
S Gear Shift Lever Travel Austin Healey 13
CARSINC For Sale Sprite Shift Lever Spridgets Classified 0
R RIB CASE SHIFT LEVER Spridgets 0
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
S CHROME RING, shift lever grommet ....? Austin Healey 3
T Ribcase Shift Lever Installation -Bushing Spridgets 1
J BN2 Shift Lever Bushing Replacement Austin Healey 6
C TR2/3/3A Rotating shift lever Triumph 12
Rob Glasgow Wanted Austin Healey Gear Shift Lever Austin Healey Classifieds 2
C TR6 Shift lever Triumph 4
G BJ-7 Center Shift Gear Lever and bush Austin Healey 4
Michael Oritt Shift lever issue [No Healey content] Austin Healey 0
Michael Oritt Gear shift lever modifiacation [No Healey Content] Austin Healey 7
Rut 5 speed gear shift lever Spridgets 28
Rut MGB MGB OD gear shift lever MG 0
P Sprite Shift Lever Spridgets 20
6 Gear Shift Lever Spridgets 3
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
TomMull Post-War Other Herald shift lever Triumph 3
bthompson A quick 1500 fix for when you go for reverse and rip off your shift lever! Spridgets 4
T TR2/3/3A TR3B gear shift lever Triumph 6
brgrmyster GTG6 Gear Shift Lever Inner Ferrule? Triumph 0
PAUL161 Gear Shift Lever Thread Size? MG 28
M Datsun 210 transmission 5 speed shift lever Austin Healey 4
Schroeders Any of you fine folks have 1275 shift lever FS? MG 2
K TR4/4A vibrating TR-4 shift lever on accelleration. Triumph 1
H TR2/3/3A TR3 Shift Lever Removal Triumph 24
d_valentino Looking for a shift lever for a BN2 Austin Healey 2
J Replacing the nylon shift lever bushing Austin Healey 8
jbowlby 1275 Ribcage Shift lever Spridgets 2
Jim_Newman Shift lever boot Jaguar 3
davidk TR6 Shift Lever Position - TR-6 Triumph 5
B shift lever threads Austin Healey 6
davidk Gear Shift Lever Vibration Triumph 4
Bruce_B Triumph Overdrive Shift Knob and Lever Triumph 9
aeronca65t MGB MGB Shift Lever Removal? MG 8
Tinkerman Gear shift lever threads Triumph 21
vping MGB Shortening a MGB shift lever MG 51
W Shift lever retainer plate Spridgets 2
jpr28056 Gear shift lever twisting Spridgets 10
A TR6 Need TR6 shift lever measurement Triumph 4
trrdster2000 Shortened my Shift lever Triumph 8
P loose shift lever Triumph 7
T Shift lever removal Triumph 29
tahoe healey shift lever removal Austin Healey 17
C TR2/3/3A Motor and Trans Out!!! TR3 shift lever??? Triumph 6
Tinkerman TR2/3/3A TR-3, Pitting on gear shift lever ball. Triumph 2
AHS Side-Shift Gearbox Austin Healey 3
bighealeysource Side-Shift Transmission Austin Healey 13
