Stripping Aluminum Threads
BobbyD
Cross Post Time!
Last week I "upgraded" my TAs with KeenSerts and got to thinking about what it takes to strip various thread sizes and threaded inserts from aluminum sooooooooooooo................here's my very unscientific study results. Yea...I know....get a life....do something productive like get the CVJs actually installed! :wink:
crj7driver
Thanks for going through all the work in developing the jig and testing the threads to failure. While cast aluminum probably fails at lower values, the keensert can only help improve over the 5/16-24 that is in the stock TA.
At least this is one expense I can truly justify to my wife as a safety improvement that along with new seat belts. The other 99% of my budget not so much :wink:
Tinkerman
Very interesting Bob. I'm not familiar with keenserts are they competitors to Helicoil? How are they price wise? I just got through recently putting a bunch in my transmission cover base. I think I put in four or five and just did the same with the intake header. Pricey little buggers but they really do the job.
I kinda suspect that your billet is probably better than the cast stuff in our cars.
Good job! Cheers, Tinkerman
Platinum
HeliCoil is just the threads in a coil. Works pretty well. KeenSerts are a fully enclosed insert. Quite stout. There are others as well. Zerts come to mind and Marson has a line of 'em, too.
I really like the "Destructive Testing" approach, Bob!!! Abuse it 'til it fails! That's the only way to truly quantify stuff. I did it with SEM's panel bonding epoxy. It took extreme torture before it showed any signs of failure. The test pieces it was bonding looked like they'd been hit with shrapnel.
Waay fun, too! :devilgrin:
BobbyD
BobbyD
Tinkerman.......I went with KeenSerts on the advice of a few people who favored them over Heli-coils and I had never used anything like this before. From what I've been told they both do the job when installed properly.
The KeenSert have these 4 locking tabs that get driven into the TA after you've screwed the insert all the way in.
Here's how the locking tabs work
Tinkerman
My thanks to both you and the Great Pumpkin. As I said I put in some helicoil ones. Used them because I didn't know any difference. I had known they were around for a number of years, but never had the need or inclination. Worked fine for me so far.
Thanks, Tinkerman
Brosky
Nice job Bob, as usual. Great documentation.
DougF
Tinkerman,
HeliCoils will work fine with your application.
Keenserts are probably 2-3 times the price(a guess), and are great where torque is necessary and/or safety is a factor. There are heavy and light duty Keenserts available. Light requires a smaller hole and would be adequate with our cars. A kit would include the inserts and an installation tool.
In billet aluminum, a 1/4" grade 8 (150,000 lbs. tensile strength) bolt will break before the insert moves inside the aluminum. I've never done the demonstration with anything larger than 1/4".
T
Tinster
BobbyD - Nice effort!
You wrote:
"For this test I put used a socket larger then the KeenSert diameter so I could draw it up into the socket. I slipped the bolt through a grade 8 washer and into the socket and started tightening in 5 pounds increments. When I hit 60 lbs of torque, the only thing I had accomplished was to suck the washer into the head of the socket to the point were I had very little bolt head left to grip"
<span style="color: #990000">This test procedure most resembles a true ASTM pull-out
test, except the screw is pulled vertically until it "pops"
at failure.
I suggest you use a longer shank screw, put a piece of 1/4" steel plate under the socket to more evenly distribute the load. A hole slightly larger than the diameter of the insert should be drilled.
Allow the bolt head to extend above the socket. Again, a piece of 1/4" steel sits on top of the socket with a hole
drilled only large enough for the bolt shank and thread to pass thru. Place a Grade #8 washer between bolt head and steel. Grease everything so the rotational friction is taken
out of the procedure as much as possible. Make sure your test bolt is long enough to pass thru all the pieces and embed the depth you desire into the aluminum.
Torque at 5# intervals until the bolt "pops", ie your
torque will drop to zero.
Just my take from doing hundreds of fastener pull-out tests.
We use a device manufactured specifically to pull screws.
The socket method will get you in the ballpark.
regards,
dale</span>
Brosky
Did you convince Al to loan you one of his trailing arms for further testing?
T
Tinster
BobbyD-
If you get your hands on an old trailing arm;
I can walk you thru a procedure that will give
you a more accurate pull-out test than the socket
and washer.
You need to pull the bolts vertically with NO rotation
whatsoever. I can help you build a device at home.
In brief- similar procedure but the bolt head rests
on the bottom of a small steel U clip. The top of the
steel clip is pulled upward thru the socket by a long bolt
and torques from the top. This pulls the T/A bolt up
without rotating it.
Regards,
Dale
PS: now give me a little help with my distributor thread!!
T
Tinster
BobbyD said:
Dale..... I see what you mean on the pull test and I did respond in the distributor thread. :driving:
<span style="color: #990000">cool!!!
A shame the various folks in the world cannot do the same.
You and I disagree on a few general things but agree to help
each other in general. Is THAT so difficult?
And I hope yer t/a upgrade is a wild successs.
I'll be front of the line after 12 months of field testing!!
(if no wheels fall off!!!)
:yesnod:
later gator,
dale </span>
Platinum
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]And I hope yer t/a upgrade is a wild successs.
(if no wheels fall off!!!) [/QUOTE]
By whatever measure, SAE, ASTM, FAA... inserts are a legit way to anchor threaded fasteners. particularly into alloy housings. Somehow I doubt there will be anything LIKE a catastrophic failure of those inserts anytime soon. The "field testing" is already done. May as well order 'em up and install 'em in the OTHER trailing arm while ya wait for the dizzy to return. Good insurance.
TR6BILL
In installed new studs in my trailing arms today using the Rick Patton jig. Quite a piece of machinery! That said, I had Rick make up a jig for me to use HeliCoils (I was gonna use Recoils but found that they are really flimsy) and decided to only replace the most crusty of my studs. Four out of six on one side and none on the other side. My opinion of HeliCoils has changed somewhat. I applied the requisite 16+ lbs of torque, and I used some Red Loctite, and felt they were "giving". Have never used KeenSerts but they have got to be better after reading the results of the above treatise. Helicoils are OK, but I just felt there was too much "give" when I torqued down. Of course, I used my magic "muscle torque by feel" torque because my wrench won't go down that low accurately.
BobbyD
BobbyD
Bill.....even with the KeenSerts, you can't crank the nuts down past the 14-16 lb Haynes range. The industry recommended torque for Grade 5 5/16-24 is 14 lbs and for Grade 8 it's 20 lbs. I first did mine by "feel" and when I checked it with a torque wrench I was at 16 lbs.
Brosky
Bill,
The February Hemming's S&E magazines are at Borders today. I picked mine up tonight, so I'm going to sign off and go read all about BobbyD!!
algot1901 Weather stripping and rubber parts Other British Cars 1
NutmegCT How to remove old weather stripping Restoration & Tools 8
S TR2/3/3A Stripping paint Triumph 16
J Up-date on car Stripping , The car is back! Triumph 4
Brosky Wax stripping and removal Restoration & Tools 11
G TR6 TR6 door rattles/weather stripping Triumph 0
luke44 TR2/3/3A TR3 Body Stripping Bare QuikStrip Allentown Triumph 25
T Got the blast cabinet set up, but not stripping Triumph 13
MGBGT_noob Stripping! Restoration & Tools 20
Brosky Frame stripping and POR15 pictures link Triumph 2
Brosky Up-date: Frame stripping and POR15 painting Triumph 30
Brosky Frame stripping started- added pics 11-03 Triumph 11
KLUTZ T-Series Stripping, Scraping, Sanding, Etching... MG 1
R Stripping paint MG 5
B Stripping shroud Austin Healey 13
P paint stripping Jaguar 1
sim 948 aluminum head gasket Spridgets 2
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
J Best Aluminum Fenders? Austin Healey 3
S TR2/3/3A 87mm Venulia aluminum pistons , Triumph 2
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
S TR2/3/3A Aluminum one time use stretch bolts Triumph 7
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
Healey Nut Aluminum doors Austin Healey 7
HighAltitudeTR3 TR2/3/3A Aluminum Plug in Head Triumph 16
nichola TR6 Aluminum block engine Triumph 8
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
S TR2/3/3A Aluminum tail pipe section Triumph 3
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
C TR4/4A TR4 coolant leak through aluminum plug in top side of head Triumph 6
R Proper Aluminum Sump Installation Austin Healey 13
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
I TR6 Aluminum trim ring band removal Triumph 5
I TR6 How to distinguish between stainless and aluminum Triumph 6
JimLaney Clean Oxidation from cast aluminum Restoration & Tools 6
I Wanted TR6 OEM or NOS aluminum trim rings Triumph Classifieds 9
R General Tech Aluminum oil gallery plugs Triumph 3
Martinld123 Aluminum Radiator Leak? Austin Healey 3
T TR2/3/3A Iron or aluminum plug in top of head? Triumph 2
T TR6 TR6 Aluminum Valve Cover Gasket Triumph 3
Griz Aluminum door trim Austin Healey 5
B TR4/4A Aluminum head water leak? Triumph 7
maxwedge5281 aluminum fender vents installation Austin Healey 14
JFS Wedge Aluminum Rad Triumph 16
Nunyas what to use on polished aluminum Restoration & Tools 4
Chancevought953 Black welt piping on aluminum surrounds Austin Healey 1
