Tom,
I thought about raising the body, but after getting everything fitting well over the last two years, I decided against it. Believe it or not, I'm fighting shipwrights disease as we speak, so don't tempt me anymore.
The body mounts are in surprisingly good shape, so I', leaving that for another time (or owner!).
We hammered along the entire frame and body and the only bad surprise on the frame is the spot in the previous picture and that is now cut out and repaired stronger than new. Erik will be spraying the Waxoyl or equivalent inside the frame and body panels after this is done.
I do have a tiny spot on the RF Fender and LR rocker that are going to get checked after this is done. Oddly, they are under the coating on the sides and it's hardly worn off at all. By spring I will have washed off the undercoating that was sprayed on the rocker areas and will have checked that out. It all feels really solid, but there is a bare spot in each area that may or may not need attention. I'll strip it all off over the winter and then take it to my buddy's body shop if needed.
That is certainly easy enough to repair and respray with undercoating after it's all fixed.
