bash
I just finished rebuilding the hydraulics for my clutch (TR6) and I found that someone had "doctored" the slave cylinder push rod - when the replacement arrived today I compared the two and found that the one I took off the car had nearly 1.5 inches added to the end... I remember reading one of Nelson Reidel's articles where he descirbed a similar "modification" and it turned out to be a broken fork pin at the root of the problem. I am pretty much sure that I will be ordering some clutch parts and pulling a gearbox in the near future, but wanted to check with those who have experienced the problem first.
I haven't really driven the car, though I have moved it around using the engine and the clutch worked fine. I know that I wasn't asking much of it, but it didn't seem unusually heavy or like it wasn't engaging as I would expect. Would that be the case with a broken pin?
I cannot move the lever on the cross shaft backwards at all by hand. Should I be able to make it move? It sits roughly vertical at what seems to be the rearward extent of its travel. It will rotate towards the engine with minimal effort, and I suspect that if I install the new push rod it will be moving in this very low effort part of its travel - is that possibly the right arc of movement? I am clinging to the idea that the badly worn clevis pin at the pedal could have caused enough slack to make the PO decide to weld a length onto the slave push rod!
I was doing so well ticking off items on the list I made last summer when I bouhgt the car, and I was looking forward to driving in the next few weeks - I will be very pleased if someone can reassure me that the clutch doesn't need work just yet! Thanks in advance for your replies, even if you are just confirming what appears to be the inevitable!
Alistair
Alistair
