Let's talk about the dreaded thrust washer wear.
2wrench
Much to do in my research about thrust washer wear and
things to do in order to prevent the early engine demise
in the event they fail.
Wow. A few catch words: White metal thrust shims.
Lead indium thrust shims made
by AE/Glacier
Revington's solution to thrust
washer wear (allows pining of
an extra half thrust washer to
the rear face of the rear main
bearing cap) [which takes 90
percent of the wear].
Thrust washer "check" has been suggested when looking at
a used engine to indicate its present state of affairs...
to some degree, of course.
So, how much attention should I pay to this issue? Is this
really something I should be going after for upgrade during
rebuild or do I just buy 'em; put 'em in and be done because
this is over-kill issue? Help me, Obi Wan Kanobie (or however it's spelled), you're my only hope.
TR3driver
Great Pumpkin - R.I.P
Just my $.02 ... if you are planning to keep and drive the motor for a long time, say 50,000 miles; then IMO you should do the mod to install 2 sets of thrust washers. If you can't imagine putting 20,000 on it; then it's probably not worth the cost. Of course extreme poverty might be another excuse; but I assume that's not the case.
Although I cannot prove it, I rather suspect that it's only necessary if you install one of those horribly heavy "wrong" clutch plates. But it's cheap insurance, IMO, against the chore of replacing thrust washers later or, worse yet, having one fall out.
You can get the mod done here in CA, no need to send to Revington. I think HVDA still does it, or Greg Solow (The Engine Room). No doubt Ken at BFE knows where to have it done, too; or Ted at TSi (in Ohio).
Again, my opinion/point of view : the material of the thrust is not the problem. That type of bearing relies on a (microscopic) thin film of oil at all times. As long as the film holds up, the bearing only wears due to dirt (that pierces the film). Rapid wear results when the bearing is overloaded, which squeezes the oil out and causes metal-to-metal contact. Doubling the surface area halves the load and is the right way to fix the problem.
T
Tinster
Hey Randall !!
The thrust washers issue is one that worries me to no end,
given the terrible condition of my car when purchased.
I have no reason to believe PDO Pedro would have replaced
the thrust washers when he didn't even change the oil for
three years. /bcforum/images/%%GRAEMLIN_URL%%/nonono.gif
I think I have now passed auto mechanic 101- "how to
replace simple bolts and nuts with torque wrench use."
How do I determine if the TWs are shot?
If, as I suspect, they are shot; is this a procedure I can
accomplish with my limited skill set?
or do I need to fly in a Triumph TR6 experienced mechanic?
Thanks as always,
dale
TR3driver
One way is to first step on the clutch (engine not running) to push the crank all the way forward. Then watch carefully where the timing pointer extends towards the damper as you lever the damper back. The movement should be no more than .013", which is about the thickness of a matchbook cover or fingernail. If it's more than that, you have a problem.
Here's another way :
https://www.vtr.org/maintain/thrust-washers.shtml<div class="ubbcode-block"><div class="ubbcode-header">Quote:]If, as I suspect, they are shot; is this a procedure I can accomplish with my limited skill set?[/QUOTE]Depends on how bad things are. If the movement is only a little out of spec, then you should be able to just drop the pan & change the thrust washers with the engine still in the car. You'll want jack stands and a torque wrench, but otherwise it's easy. Replacements come in both standard and .005" oversize, so buy a set of each.
However, if the movement is 1/8" or more, then the old TW has fallen out and you need to pull the engine, tear it down and decide if the block & crank can be salvaged or not. Without the TW, the thrust surface of the crank rubs directly against the block, damaging both of them.
T
Tinster
Ouch! Stupid kid on the block question.
What is the damper?
I'm guessing it located on the engine front end?
Also, what is a main bearing?
Can I use the valve adjustment feeler strips to
measure the "gap" ? I think I have a .010 strip.
thanks,
d
TR3driver
The damper is the pulley on the crankshaft, where the water pump/alternator belt goes.
Main bearings are inside the engine/oil pan; where the crankshaft rides in the block.
To use a feeler gauge to measure, you'll need to drop the pan. Then you can stick the feeler between the bearing surface and the crank surface, to measure the gap directly. But that's a lot of work just to check it, IMO. If you don't think you can check it "by eye", then I'd suggest adding a dial indicator and magnetic mount to your toolbox. You can usually find a cheap one on sale at Enco for around $20
https://www.use-enco.com/CGI/INPDFF?PMKANO=130&PMPAGE=20
(lower right corner)
70herald
Re: Let's talk about the dreaded thrust washer wea
Most likely the major cause of excessive wear, along with riding the clutch pedal, mechanical problems with the clutch which result in constant pressure on the clutch, starting the engine with the clutch depressed....
Basically, if you use the clutch properly, ie shift and then get your foot off the pedal they should last quite a long time. I kind of hope that most everyone here knows how to drive a manual transmission car properly, but even when manuals were "standard" the actual level of skills by the average driver were rather low.
T
Tinster
70herald Most likely the major cause of excessive wear said:
Ain't it the truth. I donated my year 2000 Jeep to a worthy cause: with 42,000 miles on it and a brand new
clutch.
The young lad driving my old Jeep wore out the new clutch in less than 4,000 miles by constantly riding the pedal.
d
R TR2/3/3A Let's talk seats Triumph 27
J General TR Let's Talk Timing a TR2/3/4 for Performance. Triumph 6
T let's talk paint jobs Austin Healey 2
T Let's talk spring pans for Disc brakes Spridgets 4
T Let's talk tropical fans... Triumph 1
T So let's talk paint colors... Triumph 39
T Let's talk acid Triumph 11
T So let's talk about powder coating Spridgets 17
T OT - let's talk about car control Triumph 20
QuickSilver Let's Talk Tail Lights MG 7
T Let's talk about stainless steel brake lines... Triumph 4
T TR6 Let's talk TR6 door gaps! Triumph 20
J So let's talk brake lines Triumph 16
Atrus Let's talk towing a spridget! Spridgets 10
2wrench TR6 '74 TR6. Let's talk about disconnecting smog stuf Triumph 29
Atrus Let's talk oil leaks ;-] Spridgets 16
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
George Zeck Thanks ALL - time for me to let go...... Spridgets 5
Griz Universal joint let go Austin Healey 15
Gliderman8 General TR Let there be [LED] light! Triumph 18
healeydan For Sale LIKE NEW '63 BJ7 Restored to Original ** Hate to Let It Go ** $59,900 Austin Healey Classifieds 4
Rut TR4/4A Let the search begin Triumph 9
JPSmit Let's take up a collection Spridgets 4
J Starter works fine but car catches after you let off on the starter Austin Healey 14
Lukens TR2/3/3A Randall, let's try this Triumph 4
JPSmit I accidently let the smoke out Restoration & Tools 5
J Found an E Type in a Barn. Bought it. Let's Make it Run Jaguar 15
J TR2/3/3A Hooked up the Headlights and let the smoke out!!! Triumph 4
Lukens TR2/3/3A Let's see if I'm still having the 'Britishcar forum not responding" problem Triumph 3
D T-Series Let's play "What kind of transmission does this go in?" MG 1
Trevor Jessie I let the smoke out of the welder Spridgets 10
drooartz Let's just say I'd be interested if you found one Spridgets 27
Lukens Well the Big Day arrived. Let the questions begin Triumph 9
T Stag Don't let the Triumph Stag lose! Please! Triumph 11
JodyFKerr Wedge I might have let the smoke out [TR8] Triumph 25
lbc_newbie Let's play.."What's my car worth" Spridgets 13
CinneaghTR Let's Play "Name That Part!"-Sidescreen TR Triumph 10
Mickey Richaud Let the Drooling Begin! Other Cars 11
L Let me know if you need this Spridgets 2
jdubois Don't let this one get away! Spridgets 14
drooartz Progress: let there be light! Spridgets 13
Morris My wife won't let me buy this... Spridgets 5
HerronScott Let it snow.... Triumph 27
C I said let there be light, and there was NO light Spridgets 16
bmurphy7369 Let's Help Basil with Recent Cost Issues, Ideas... Austin Healey 0
bmurphy7369 Let's Help Basil with Recent Cost Issues, Ideas... Spridgets 0
bmurphy7369 Let's Help Basil with Recent Cost Issues, Ideas... Triumph 0
Brosky Let there be light.......... Triumph 14
jhorton3 Let The Fun Begin! Spridgets 5
M Let's Try This Again... Free to a Good Home Spridgets 25
