Wedge I might have let the smoke out [TR8]
JodyFKerr
I swear this car hates me.
Went to move the TR8. Battery is flat. Put my jumper on there, get it started, leave it idling for a few. Go to turn the car around and it dies. No electricity. Tried to put jumper back on, massive amount of sparks. Check cables, they're melt-plastic hot.
The neg battery cable is brand new. Well grounded. The positive cable is brand new. I can't see any shorts, but I haven't tried tearing out the carpet.
Traced the engine segment. Line on starter looks good, line to alternator looks good. Brown/Yello sense wire, however, not connected.
Is it possible that not having the sense attached could do this?? Or am I looking at yet another wonked alternator and or fused battery?
Galdangit! I pray the whole electrical system isn't fried.
TR3driver
Great Pumpkin - R.I.P
Possible, but unlikely I think. If so, it probably popped the diodes in the alternator, so at least the damage will be localized.
I would start by disconnecting a cable at the battery, and connect your jumper cables to the battery. If you get sparks and hot cables, the battery is toast & has to be replaced. But don't assume that is the only problem.
Next, I would try disconnecting the main wire to the alternator and see if you can power up the rest of the car with the jumper cables. If that's not it, try the starter next. Continue with the "divide and conquer" approach until you isolate the problem.
GBRandy
Well if you got huge sparks when reconnecting the cables you have a dead short somewhere.
It was idling and all was fine....move it a fraction and 'zap' everything is dead and the wires are hot....right? Something must have shifted and shorted out when you moved it....
As Randall points out the battery could be the culprit. His other suggestions are spot on.
There is little than can cause that kind of excitement in the car.
I would check the positive connection block in the passenger footwell too.
tr8todd
A tired starter will cause the cables to get hot, which could lead to a short in the main cable heading from the trunk to the starter. Check the main cable for continuity to ground. Make sure the battery clamps didn't short against the hold down. How come you are the only one having trouble with TR8s? These things are easy.
JodyFKerr
JodyFKerr
I swear this bloody car is cursed.
Battery tested good at Autozone, left it for a longer charge.
Neg cable = new
Pos cable = new
Starter = new gear reduction
Alternator = new from Vicky Brit.
Have checked where the pos. cable goes into the body from the back and out the body at the front.
I'm assuming at this stage that I borked the Alternator wiring when I converted back from a GM set up.
Will get the battery from autozone. Will test w/out alternator to see if I can get it going. then continue from there.
To add insult to injury I can't get the brakes work either. Rebuilt MC, rebuilt calipers, rebuilt wheel cylinders, new rubber brake lines. No brakes. Bleed and bleed, but no pressure. No leaks either.
I'm afraid I may have to take this car in to a shop. I haven't had to do that in over 20 years. It's embarrassing.
Darrell_Walker
Something gummed up in the pressure reducing valve?
JodyFKerr
JodyFKerr
If I remember correctly, if the Pressure valve was gummed up the brake fluid would not gravity feed through the system. Brakes worked just fine until the rear wheel cylinder started leaking.
Ok, I put the battery back in and disconnected the alternator. It's something in the alternator connections and/or the alternator itself. At least I've got the stupid car back in the driveway and not sitting in the street.
Darrell_Walker
Oh, so you get fluid out when bleeding, but just can't get enough pressure when operating the brakes?
JodyFKerr
JodyFKerr
All four bleed very well. I get NO pedal at all.
I was informed by a local Triumph guy that there's some screw somewhere on the MC that I may need to fiddle with, but I haven't looked yet as I got sidetracked by the sparks.
Darrell_Walker
There is the warning switch on the bottom of the master cylinder, once the still shuttle trips, you need to remove the switch to reset. Not sure if that affects pressure or not.
tr8todd
You don't need the pressure valve anyway. Dividing the bias 50/50 still isn't enough to lock up the rears. On the race car, I would divide them up with tees and then put an adjustable prop valve on the front just to bias it down enough to get the rears to work. Those masters are notorious for difficulty bleeding. Start by cracking the lines at the master, and then at the prop valve, before heading to the calipers and finally to the rear. Pump three times then hold down and crack the lines. Repeat.
Dale
Hi Jody!
Sorry your having trouble with the 8. I can't be much help, but I can encourage you to persevere. I know you are competent enough to sort it out.
Renee and I took the J-H out for a nice topless drive and ice cream Sunday. Days like that justify the hardship and frustration. This afternoon the wind was blowing such dirt I couldn't see a quarter mile. If it keeps up, Arizona will be charging us property tax. Hang in there.
JodyFKerr
JodyFKerr
ugh. that sucks. So good old gravity bleeding won't cut it?
Oh, is it possible with this MC that SWMBO could have bottomed out the MC and that's why it's like this?
JodyFKerr
JodyFKerr
Dale said:
Hi Jody!
Glad to hear the Jensen's treating you well. As to the AZ dust, you're welcome to it. It just makes me sneeze.
It's all a matter getting the correct order to things. First, restore my garage to ready state after having lost it to cabinet prep. The wife's to-do lists caught up with me and I've spent the last couple weeks staining and prepping cabinets/counter top for her laundry room.
Then get 8 back into garage. Sort electrics, then get some help from a club member to get these brakes sorted. Then I might be able to finally get this ridiculous car on the road.
Also am picking up SWMBO's new project this Saturday. '69 AH Sprite. Once I get her completely distracted with farting around with that I can go back to my projects.
I've convinced both her and the daughter that you have to hand sand the body to get all the paint off. That should give me plenty of peace for a while. It'll take 'em a couple days to get fed up with doing it that way.
JodyFKerr
JodyFKerr
Ok, I finally had enough patience to go back and mess with the 8 tonight. Went back over every bit of wiring and then noticed this:
I guess I found how all the smoke was getting out. Turns out that when I swapped the proper alternator back in it shifted the wiring just a hair because of the differences in the mount point. Looks like I need to remake some wiring.
Then I started going back over the brakes. No leaks anywhere, then just for the sake of ruling everything out I tried this:
It turns out that either the threads on the reservoir are no good, or the cap is no good. After doing this I immediately got brake pressure. This sorta works for now, but I'm going to need to come up with a better solution long term.
So, in theory, I might be able to make this sucker drive.....
tr8todd
Not sure how or why the tissue made a difference. Doesn't the cap need to breath as the fluid moves in and out of the reservoir? I pulled my master, and prop valve out this week so I could paint the engine bay in my grey TR8. While they were out I put a nice coat of gloss black on them, and changed the rusty nuts and bolts out for some stainless. Sometime this weekend I'll snare one of the girls and have them help me bleed the braking and clutch systems. Hope it goes smoothly.
JodyFKerr
JodyFKerr
Ok, got it running. then the squealing started.
Did some research. This is the pulley on my water pump:
Every reference I can find is for a double pulley. Is this the wrong pulley?
tr8todd
Stock it is a 2 piece pulley. The outer pulley is for the belt that goes from the crank to the water pump to the alternator. The inner(removable) pulley acts as an idler pulley for either the ac or the air pump. Can't remember which, as I don't have either on my cars. If you need one, I should have all of the ones I removed. If you change the pump out to a Buick pump, you will have to change the pulley to a 4 bolt anyway. Buick pumps are cheap and at the auto parts store now. The GM pumps use a better impeller than stock Rover, so if you opt to have the rover rebuilt locally, you can just use Buick componants.
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
JPSmit Not quite an LBC - but the size might be close :) Restoration & Tools 3
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
M Wanted I tried to post this earlier and it didn't seem to work so this might soon appear as Austin Healey Classifieds 6
davester Help me make some engine teardown/evaluation/might-as-well decisions please. Spridgets 6
Steve This might go for silly money... Rover / Land Rover 1
waltesefalcon It might be sacrilege ... Other British Cars 4
RickB Anyone doing a steering wheel swap - a little loctite might be a good idea Spridgets 2
D Might be returning to Spridgets... Spridgets 5
Lbp TR2/3/3A What Might Cause The Entire Electrical System on my TR3A to Die? Triumph 19
H Think This Might be Part of the Problem? Austin Healey 3
Randy Forbes It might be a slug, but it sure is pretty... Austin Healey 28
6 might as well syndrome Triumph 11
DNK Might be worth a spare one. Triumph 7
JPSmit You all might be interested MG 0
G You might think I'm nuts, but I'd rather drive... Spridgets 14
D This just might get me to buy a Spridget...... Spridgets 12
C This might be a dumb question but.... Spridgets 15
Thor Any idea what this sound might be from motot Spridgets 9
RickB Bugeye might be available - value question Spridgets 8
YankeeTR You guys might enjoy this... MG 16
prb51 You might be a car nut if.... Triumph 39
F What a Healey might be Austin Healey 27
jlaird Thought you might like to see what I Spridgets 29
jaegzie What might be a desirable serial number be on a BE Spridgets 13
T Today might be the demise of the Crypt Car Triumph 19
T I might buy another Triumph! Triumph 14
bluemiata90 I MIGHT NEED THERAPY Triumph 13
jlaird Thought you all might like these. Spridgets 24
Trevor Jessie Might be a little quiet here for a few days Spridgets 24
regularman I believe a blind man, might be able to see my... Spridgets 14
G Spitfire 1971-80 Spitfire owner's might be interested. Triumph 1
bravenrace Might be a World Record - Where's Guiness? TVR 3
kyreb1862 Might As Well's MG 2
jlaird YOU MIGHT BE A SPRITE DRIVER IF. Spridgets 26
T Wedge Nice TR8 at Cars & Coffee - might be for sale Triumph 0
19_again Head gasket--might as well? MG 7
jlaird Thought you all might Spridgets 1
gsalt57tr3 looks like, smells like a scam, might be a scam Triumph 7
TR4 Might be nice ....... Triumph 5
jlaird Thought you might like these Spridgets 3
jlaird Thought you might Spridgets 10
Steve Might do somebody some good.... Triumph 2
J thought you guys might like this TVR 2
6 Thought some of you might like to see my Sprite Spridgets 40
regularman Important question [I might have just screwed up] Spridgets 8
T TR6 "Might as well" if you need to pull the TR6 dash Triumph 6
budk1953 You might want one British Motor Corp 9
ahpook This might be a sin, but Spridgets 7
YankeeTR You might enjoy some of these pictures... Triumph 8
