Let's talk spring pans for Disc brakes
tdskip
I know this has been discussed but are the Moss aftermarket spring pans worse/better than the Heritage ones?
Are the aftermarket ones OK to use with a disc brake conversion for when that day comes?
kalist
I installed a Moss aftermarket pan on mine and updated to disc brakes without a problem. I read somewhere that the width on the aftermarket were not exact to original equipment but I did not experience that issue.
Jim_Gruber
After redoing Bugsy's front end this winter I can state that later RB Spridgets had much heavier duty, additional reinforcements built into the Spring Pans than on earlier BE's. Not sure when the design changed but I know they are about the same through 68-69. Sometime after that design changed. I was able to get a set from a late Spridget that were perfectly fine for rebuilding. I spent most of a day pulling a set off of a '69 that I intended to use as cores and have rebuilt only to find them totally shot and cracked. Later wishbones were also predrilled for sway bars.
I know Jack Laird has a set of Heritage wishbones on Miss Agatha.
porterthe
I once compared a new aftermarket pan to a new Heritage pan and they looked identical. I would not be surprised if they came off the same line.
R TR2/3/3A Let's talk seats Triumph 27
J General TR Let's Talk Timing a TR2/3/4 for Performance. Triumph 6
T let's talk paint jobs Austin Healey 2
T Let's talk tropical fans... Triumph 1
T So let's talk paint colors... Triumph 39
T Let's talk acid Triumph 11
T So let's talk about powder coating Spridgets 17
T OT - let's talk about car control Triumph 20
QuickSilver Let's Talk Tail Lights MG 7
T Let's talk about stainless steel brake lines... Triumph 4
T TR6 Let's talk TR6 door gaps! Triumph 20
J So let's talk brake lines Triumph 16
Atrus Let's talk towing a spridget! Spridgets 10
2wrench TR6 '74 TR6. Let's talk about disconnecting smog stuf Triumph 29
2wrench Let's talk about the dreaded thrust washer wear. Triumph 8
Atrus Let's talk oil leaks ;-] Spridgets 16
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
George Zeck Thanks ALL - time for me to let go...... Spridgets 5
Griz Universal joint let go Austin Healey 15
Gliderman8 General TR Let there be [LED] light! Triumph 18
healeydan For Sale LIKE NEW '63 BJ7 Restored to Original ** Hate to Let It Go ** $59,900 Austin Healey Classifieds 4
Rut TR4/4A Let the search begin Triumph 9
JPSmit Let's take up a collection Spridgets 4
J Starter works fine but car catches after you let off on the starter Austin Healey 14
Lukens TR2/3/3A Randall, let's try this Triumph 4
JPSmit I accidently let the smoke out Restoration & Tools 5
J Found an E Type in a Barn. Bought it. Let's Make it Run Jaguar 15
J TR2/3/3A Hooked up the Headlights and let the smoke out!!! Triumph 4
Lukens TR2/3/3A Let's see if I'm still having the 'Britishcar forum not responding" problem Triumph 3
D T-Series Let's play "What kind of transmission does this go in?" MG 1
Trevor Jessie I let the smoke out of the welder Spridgets 10
drooartz Let's just say I'd be interested if you found one Spridgets 27
Lukens Well the Big Day arrived. Let the questions begin Triumph 9
T Stag Don't let the Triumph Stag lose! Please! Triumph 11
JodyFKerr Wedge I might have let the smoke out [TR8] Triumph 25
lbc_newbie Let's play.."What's my car worth" Spridgets 13
CinneaghTR Let's Play "Name That Part!"-Sidescreen TR Triumph 10
Mickey Richaud Let the Drooling Begin! Other Cars 11
L Let me know if you need this Spridgets 2
jdubois Don't let this one get away! Spridgets 14
drooartz Progress: let there be light! Spridgets 13
Morris My wife won't let me buy this... Spridgets 5
HerronScott Let it snow.... Triumph 27
C I said let there be light, and there was NO light Spridgets 16
bmurphy7369 Let's Help Basil with Recent Cost Issues, Ideas... Austin Healey 0
bmurphy7369 Let's Help Basil with Recent Cost Issues, Ideas... Spridgets 0
bmurphy7369 Let's Help Basil with Recent Cost Issues, Ideas... Triumph 0
Brosky Let there be light.......... Triumph 14
jhorton3 Let The Fun Begin! Spridgets 5
M Let's Try This Again... Free to a Good Home Spridgets 25
