jhorton3
I started working on reassembling the front end suspension of the car. Not without some disassembly though. Took out the old steering rack. That's a pain in the behind! The steering column didn't have to be taken loose for taking the rack out, but it had to come loose going back in. Got the pinch bolt stuck and wound up having to cut it off and punching out. That took up a lot of time, but finally got the new rack installed and looks great compared to the old ratty overspray one.
Also installed the new rubber bump stops on either side. I might get brave enough to reinstall the shocks tonight....or not. Pretty wiped out working in the garage in 95 degree heat for six hours. I think I've gone through a gallon of Gatorade!
