TR2/3/3A SU-H "lift button"
NutmegCT
SU manuals often indicate lifting the piston 1/32" with the tip of a screwdriver, or using the lift button at the side, as an adjustment test.
If you push the lift button up fully, does that lift the piston 1/32"? or does SU mean to push that button 1/32" instead of using a screwdriver to actually lift the piston 1/32"?
Thanks.
Tom M.
PeterK
I just lift it up (all the way I guess, never bothered with measure) with my finger then let go to test.
NutmegCT
NutmegCT
Thanks Peter. I know you can use the button to lift the piston to see if it drops correctly. I'm just wondering if the "lift the piston 1/32" and see how it changes engine speed" can be done by pushing that button all the way, or pushing that button only 1/32".
Tom M.
TR3driver
Great Pumpkin - R.I.P
Neither, actually. If you want only 1/32", You have to lift the button a short distance before it contacts the piston and then 1/32" more.
However, the 1/32" figure was increased later on. Practical Hints & TR4 workshop both give it as 1/8", which is pretty close to what you get lifting the pin all the way. It's not super critical anyway, IMO.
TR3driver
a-HA!
https://www.tr-register.com.au/Files/su6.html
"Check for correct mixture by gently pushing the lifting pin up about 1/32 in."
TM
Sure won't work on my engine. There is at least 1/32" freeplay between the pin at rest and the piston!
I've posted links to the actual Triumph documentation many times, but its a hassle on this phone. Let me know if you need them again.
NutmegCT
NutmegCT
Thanks Randall. I've got the Practical Hints. Also good to know about the amount not being overly critical. I'm thinking now that the "use the lift pin" just eliminates sticking something under the piston; you still have to watch how far up the piston moves when you use the pin. Next time I do this, I'll actually measure how far up the piston goes, when I use the pin.
Tom M.
glemon
Tom, I guess the phrase is a little ambiguous "Ultimately a car with the right mixture will start easy and run well, too lean will take a long time to warm up and take throttle from cold without a miss"
A word or two changed helps: " too lean will take a long time before it warms up and takes throttle from cold without a miss"
To elaborate:
An engine that is too lean will hesitate, stall or miss with throttle applied when cold and take a long time to warm up. While such behavior is normal in subfreezing temps, if too lean the car will exhibit such behavior even on moderate to warm days.
NutmegCT
NutmegCT
" ... too lean will take a long time to warm up and take throttle from cold without a miss".
Not sure I understand - do you mean if mixture is too lean, the cold engine revs up quickly without a miss?
Thanks.
Tom M.
TR3driver
No, just the opposite. A cold engine has to have some choke (richer mixture) to run smoothly. If the main mixture is on the lean side, then it takes longer for the engine to get hot enough that it will run smoothly without the choke.
Not necessarily a bad thing, IMO, as you'll get better fuel economy that way. But it is one indication of whether the mixture is a bit lean or a bit rich. If you can start from cold and immediately drive without the choke, then your mixture is definitely too rich.
T Does a car lift exist that could be placed against a wall, and the car rolled sideways onto it? Spridgets 16
drooartz Bugeye fits on the lift! Spridgets 14
K For Sale TR3 Engine Lift Bracket...hard to find! Triumph Classifieds 0
jfarris TR2/3/3A Loose Lift the Dot Stud Triumph 7
Bob_Spidell Lift for Healeys Austin Healey 40
A TR2/3/3A Lift-a-dot studs [for wood] Triumph 5
HighAltitudeTR3 Wanted TR3 Hood Lift Assembly Triumph Classifieds 2
I General TR Hydraulic lift opinions/info needed Triumph 34
rr64 Wanted Reproduction of the Shelley brand lift jack decal shown Other British Classifieds 19
M TR6 Tonneau cover strap lift-the-dot stud location Triumph 8
R General Tech Car Lift Triumph 5
R Car Lift Austin Healey 10
Rut HF lift Spridgets 1
S TR2/3/3A Question on the lift dot fastener, Triumph 3
Rut TR4/4A Shop with lift ideas Triumph 21
T TR6 TR-6 Wheels Wobble & Lift Triumph 4
N TR6 Lift Question Triumph 4
GTP1960 TR2/3/3A Ranger Quickjack lift for TR3A Triumph 5
jfarris TR2/3/3A Problem with lift-the-dot fastener on door Triumph 4
Popeye TR4/4A TR4A rear engine lift point - photos? Triumph 14
F Any Experience with BendPak MD-6XP Scissor Lift? Austin Healey 8
T TR2/3/3A Lift the Dot question Triumph 4
CJD TR2/3/3A Stock Valve Lift Triumph 3
angelfj1 NORTHERN TOOL - Ranger QuickJack Portable Lift Restoration & Tools 3
J TR2/3/3A Hood lift to front apron, what size are the screws that go from bottom up? Triumph 10
K TR2/3/3A Repair ripped tonneau cover at a Lift-a-Dot? Triumph 3
60TR3A Looking for Recommendations for Garage Lift Austin Healey 9
Vila TR4/4A TR4 carpet Lift-The-Dot question Triumph 0
T TR2/3/3A tr3a hood lift spring assembly Triumph 11
T TR2/3/3A Question on TR3A hood lift assembly Triumph 2
trrdster2000 Garage lift, which direction?? Triumph 40
stretchit2 New Lift/Hoist for my Hardtop Austin Healey 11
martx-5 Lift for the Garage Triumph 28
Lin 4-post lift hydraulic fluid Austin Healey 5
T building a single tower Sprite storage lift? Spridgets 21
mcguijo TR2/3/3A TR3 Hood Lift Assembly Triumph 1
M Tennax and Lift A Dot? Spridgets 2
GBRandy Wedge TR8 Headlamp lift motor repair Triumph 17
M Lift-the-dot peg Triumph 3
bighealeysource Anyone use a EZ Car Lift brand on your Healey ? Austin Healey 6
Tinkerman TR2/3/3A TR 3A Lift The Dot Studs Triumph 3
J New lift tool for my garden tractor Restoration & Tools 0
RAC68 Rear Spring Lift Austin Healey 9
DNK Lift THoughts Restoration & Tools 14
M Removing Lift-the-Dot Fasteners Triumph 8
SCguy TR6 Tr6/Scissor lift? Triumph 4
M Raising the car without a lift Triumph 14
luke44 TR2/3/3A TR3 Lift the Dot Studs - 2 styles? Triumph 4
bigjones Door panel face lift Spridgets 8
Johnny Tenax and "Lift-the-dot" fasteners, plus Austin Healey 4
