TR2/3/3A Hood lift to front apron, what size are the screws that go from bottom up?
Jerry
I forgot to test the screw holes and don't want to take the apron off again. Can someone tell me the sheet metal screws that come up from the bottom to help hold the hood lift?
thanks
Jerry
TR3A
tinman58
Jerry
I think they are #12 sheet metal screws.
John_Progess
Jerry,
Mine are about a #6 or #8 button head Phillips sheet metal screw. The head style doesn't really matter as you will never see them. I am also not sure that is what was installed at the factory.
John
J
Jerry
Ah, the winners go to size 8. I tried a few and the 8s worked best. I thought they might be tapped at first but once you guys said sheet metal screws, the search was easier.
Thanks
Jerry
doc50
Hello all, I am just finishing up the resto of my 59 TR3...and cannot for the life of me figure out what the
"...screws coming from the bottom to help hold the hood lift..." means?
Are we talking abut the "British hood" (soft top) frame...or the hood over the engine?
Thanks, Thom W
TS34909L (now O)
CJD
I think they are talking about the bracket with the spring and plunger, that pops the bonnet up an inch or so. It is also has the slot for the bonnet prop rod...
doc50
Thanx, John. Today I got ahold of a shot of the area....and suddenly realized my car was lacking the two brackets that y'all are talking about!
I didn't miss them....till now. May have to (re-re-re)move the apron to fab up a couple.
BTW: the paint color on your pic is the same as mine was when I started it. (Not original on mine though). Went 'Dove Grey'.
Thom
CJD
It's just a single bracket, with the large spring, a plunger, and some washers. I know Geo and others have posted some great pictures in the past of the parts envolved if you do a search. You should not have to remove the apron to remove or install the assembly...so that's good news!
John_Progess
Thom,
I made up a couple of those brackets before I found my original ones. You are welcome to them if you want. No need to remove the apron to install them. I believe they are just stiffeners and obviously the bonnet latch will operate without them. Thanks and have a good day!
John
HighAltitudeTR3 Wanted TR3 Hood Lift Assembly Triumph Classifieds 2
T TR2/3/3A tr3a hood lift spring assembly Triumph 11
T TR2/3/3A Question on TR3A hood lift assembly Triumph 2
mcguijo TR2/3/3A TR3 Hood Lift Assembly Triumph 1
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
S TR2/3/3A 59 TR 3 hood emblem Triumph 2
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
R New Hood for BJ7 Austin Healey 3
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
S TR2/3/3A Hood Stick Cover Triumph 3
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
B BJ8 Hood Bow and Seal Austin Healey 5
B Hood Woodwork Austin Healey 2
Papajack TR2/3/3A TR3 Hood and Sidescreen Colors Triumph 6
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
R TR6 Stronger hood release? Triumph 4
MGTF1250Dave T-Series Hood Sticks MG 4
TomMull Wanted Herald Hood Frame Triumph Classifieds 9
TomMull Convertible hood frame Other British Cars 3
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
S Forward opening hood / bonnet Spridgets 10
D BJ7 Hood frame mounting plate Austin Healey 7
S TR2/3/3A Tr2 hood Triumph 8
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
steveg TR6 Hood release pictures needed Triumph 22
HealeyPassion Hood scope chrome gap fix ... Austin Healey 0
Gliderman8 TR6 It finally HAPPENED... Hood cable broke but HAPPY ending. Triumph 44
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
S Pre-War my hood problem got worse! Triumph 6
S TR2/3/3A The chrome beading is rubbing on the hood Triumph 5
G Wanted WTB TR3 Hood Hardware Triumph Classifieds 0
B TR6 TR6 Hood Release Cable Triumph 7
A TR2/3/3A how do i fix this hood line? Triumph 5
Z For Sale 1956 Austin Healey BN2 Factory hood Austin Healey Classifieds 0
L TR2/3/3A Hood / bonnet plinths Triumph 12
TomMull Wanted Triumph Herald Hood Finishers Triumph Classifieds 3
D TR2/3/3A Fitting the hood. Soft top. Triumph 6
J TR2/3/3A Hood oilcanning Triumph 6
anarchy99 Bonnet / hood fit question... Spridgets 2
anarchy99 Wanted WTB: 64-66 sprite hood in decent shape. Spridgets Classified 2
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
K TR2/3/3A Location of Hood[Bonnet] Louvres on a TR3A? Triumph 1
L Wanted 100/6 Longbridge hood parts Austin Healey Classifieds 3
L 100/6 Hood parts Austin Healey 11
britlover Wanted TR4 Hood long bubble Triumph Classifieds 0
4tecdog Windscreen rail to hood seal Austin Healey 11
