TR2/3/3A tr3a hood lift spring assembly
TFB
Does the hood/bonnet lift spring assembly use two cupped washers on each end of the spring or only one on the top of spring.Thanks Tom
TR3driver
Great Pumpkin - R.I.P
What he said.
T
TFB
Thanks Marv and Randall.Looks like I need to make or order a washer.
Randall,what parts book did those numbers come from?I have the 4th edition that you pointed me to the download,but its limited or me with a post 60k.Suprised TRF doesn't link to a parts book for the factory numbers(unless I just didn't see it) since it seems that's the way a lot of the parts not in their catalogs are listed.Thanks again,Tom
TR3driver
Page 87 of the same one I linked to. The lift assembly is one of the few things that didn't change (AFAIK) at 60k.
You're exactly right about TRF not listing a lot of parts in their "catalogs" (which for the TR3 are really more like popular parts listings, not a comprehensive catalog at all). However, they want to sell you a paper reprint rather than give away a PDF. Years ago, Charles promised to do a full TR3 catalog (similar to the blue & green TR6 catalogs) but never did. And at this point, I think it unlikely that he ever will. They don't even pass out the TR6 catalogs any more.
T
TFB
Thanks Randall.I will take another look.I saw the small mouth pic with what appeared to be a different setup.So the later catalog is not available to download?Thanks Tom
luke44
I'm not sure if you'll find just a washer - it's kind of a one-off cup kinda' piece. FWIW, VB are the only supplier I know of that carries the entire assembly as a new piece. Part #12-5722
TR3driver
As far as I know, the 4th edition (with accumulative amendment 3 dated June 1962 plus supplemental amendment 5 dated June 1964) is the last version that the factory ever issued. None of the drawings were ever updated, even when the later parts are listed (as is the case with the hood lift).
I do occasionally update my copy with more info (eg I added a plate with the generator mounting and some notes here and there), but not very often. There are way too many other interesting documents that I don't have scanned at all.
Tom,
If you can't find just the one cupped washer, use a big flat one that is close ( or bigger) than the cupped one on the top, it doesn't move as much as the upper one. It should work fine.
Marv
luke44
Coincidentally I was sorting through some old parts today.
I came across 2 spare washers in good shape - they need a quick clean up but otherwise are OK. PM me if you need want to go that way and need them.
T TR2/3/3A Question on TR3A hood lift assembly Triumph 2
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
K TR2/3/3A Location of Hood[Bonnet] Louvres on a TR3A? Triumph 1
Tinkerman TR2/3/3A Hood stick assembly 1960 tr3a Triumph 7
angelfj1 TR2/3/3A TR3A - front hood attachment snaps Triumph 10
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Hamish Racing General TR TR3a and TR7V8 Shelsley Walsh Hill climb action Triumph 0
Hamish Racing TR2/3/3A Fast and wet TR3a Triumph 0
