TR2/3/3A Lift the Dot question
TR-3rg
Hi,
Should a TR-3a (post 60K) have two different length Lot the Dot studs? The studs in the door and the forward capping stick out a 1/2" from the body. The studs around the rear capping, stick out 3/4". Is this correct? Its really hard to get the tonneau cover on, shorter studs would probably help.
Thanks, Roy
M_Pied_Lourd
Roy,
I am by no means an expert but I can tell you that on both of mine, the only longer stud is at the top of the b post where the double thickness of the tonneau cover snaps on. The other studs are too short for this purpose. I am sure the others will chime in.
Cheers
Tush
Vila
Roy
I am a TR4 guy, but have you checked the TR3 Top section of Moss online. Their online info seems to have more detail then the paper catalogue.
They are good at showing exactly what goes where or even better would be the original Triumph TR3 parts manual.
My original Triumph 20 TR4 manual shows exactly which length pegs go where for the TR4.
Crankshaft
I would agree with Tush. On mine, when we installed a new cover, the upholsterer that installed the LTD fasteners into the cover questioned whether there should be a longer peg on the B post. We went with the short peg and it accomadates the two thicknesses of material just fine.
S TR2/3/3A Question on the lift dot fastener, Triumph 3
Vila TR4/4A TR4 carpet Lift-The-Dot question Triumph 0
jfarris TR2/3/3A Loose Lift the Dot Stud Triumph 7
A TR2/3/3A Lift-a-dot studs [for wood] Triumph 5
M TR6 Tonneau cover strap lift-the-dot stud location Triumph 8
jfarris TR2/3/3A Problem with lift-the-dot fastener on door Triumph 4
K TR2/3/3A Repair ripped tonneau cover at a Lift-a-Dot? Triumph 3
M Tennax and Lift A Dot? Spridgets 2
M Lift-the-dot peg Triumph 3
Tinkerman TR2/3/3A TR 3A Lift The Dot Studs Triumph 3
M Removing Lift-the-Dot Fasteners Triumph 8
luke44 TR2/3/3A TR3 Lift the Dot Studs - 2 styles? Triumph 4
Johnny Tenax and "Lift-the-dot" fasteners, plus Austin Healey 4
C "Lift-a-dot" studs Austin Healey 9
ekamm lift-a-dot studs Triumph 8
H TR2/3/3A TR3A - HOW MANY LIFT THE DOT PEGS ON CAR Triumph 4
Brooklands Lift the dot fasteners Restoration & Tools 8
Harry_Ward Lift the dot stud type for tonneau cover? Triumph 13
T Does a car lift exist that could be placed against a wall, and the car rolled sideways onto it? Spridgets 16
drooartz Bugeye fits on the lift! Spridgets 14
K For Sale TR3 Engine Lift Bracket...hard to find! Triumph Classifieds 0
Bob_Spidell Lift for Healeys Austin Healey 40
HighAltitudeTR3 Wanted TR3 Hood Lift Assembly Triumph Classifieds 2
I General TR Hydraulic lift opinions/info needed Triumph 34
rr64 Wanted Reproduction of the Shelley brand lift jack decal shown Other British Classifieds 19
NutmegCT TR2/3/3A SU-H "lift button" Triumph 12
R General Tech Car Lift Triumph 5
R Car Lift Austin Healey 10
Rut HF lift Spridgets 1
Rut TR4/4A Shop with lift ideas Triumph 21
T TR6 TR-6 Wheels Wobble & Lift Triumph 4
N TR6 Lift Question Triumph 4
GTP1960 TR2/3/3A Ranger Quickjack lift for TR3A Triumph 5
Popeye TR4/4A TR4A rear engine lift point - photos? Triumph 14
F Any Experience with BendPak MD-6XP Scissor Lift? Austin Healey 8
CJD TR2/3/3A Stock Valve Lift Triumph 3
angelfj1 NORTHERN TOOL - Ranger QuickJack Portable Lift Restoration & Tools 3
J TR2/3/3A Hood lift to front apron, what size are the screws that go from bottom up? Triumph 10
60TR3A Looking for Recommendations for Garage Lift Austin Healey 9
T TR2/3/3A tr3a hood lift spring assembly Triumph 11
T TR2/3/3A Question on TR3A hood lift assembly Triumph 2
trrdster2000 Garage lift, which direction?? Triumph 40
stretchit2 New Lift/Hoist for my Hardtop Austin Healey 11
martx-5 Lift for the Garage Triumph 28
Lin 4-post lift hydraulic fluid Austin Healey 5
T building a single tower Sprite storage lift? Spridgets 21
mcguijo TR2/3/3A TR3 Hood Lift Assembly Triumph 1
GBRandy Wedge TR8 Headlamp lift motor repair Triumph 17
bighealeysource Anyone use a EZ Car Lift brand on your Healey ? Austin Healey 6
J New lift tool for my garden tractor Restoration & Tools 0
