TR2/3/3A TR3A - HOW MANY LIFT THE DOT PEGS ON CAR
houleyh
Iam trying to figure out how many Lift-The-Dot Pegs I need on the car. Can anyone help me? How many with Nuts and how many with Metal screw end?
Thanks
Don Elliott
It depends on your TS number. There are fewer pegs with the tapered screw threads on the later post 60000 TR3As because S-T eliminated the wood. My early TR3A has wood-screw threads that go along the top of the dashboard. Later TRs are straight threads here.
martx-5
From what I understand, the pre 60,000 cars had the sheet metal (wood screw) type on the dash capping and the doors, and the machine screw w/nuts around the rest of the car. On the post 60,000 cars, they used the machine screw type on the doors also, therefore the only place that had the sheet metal type is on the dash capping. I also believe that originally, the two pegs that go through the hood (top) webbing piece were longer then the other machine screw pegs. IIRC, the ones I used were all of the longer length.
Geo Hahn
FWIW -- You may find that your local Ace hardware carries these in the 'nuts & bolts" area -- in those little cardboard trays.
Getting them that way means you can get a bunch of both types and take back any you don't need.
Oops, I see you're in CA -- not sure if you have Ace hardware up there.
vivdownunder
On a pre TS60000 car -
Sheetmetal type pegs- 8 across the dash capping, 4 on each door and 1 each side on the panel just behind the door, for the tonneau cover. Total 18 items.
Metal thread pegs- 11 for around the rear of the cockpit. On later cars I think the spacings were closed up, so 12 would be needed.
Be careful with the sheetmetal type when fitting, as they can easily take a chip out of new duco. Clean the holes of any undercoat/duco build up first.
Viv.
Bremer TR2/3/3A How many ground straps on a TR3A? Triumph 4
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
D TR2/3/3A tr3a occasional seat padding Triumph 10
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
Hamish Racing TR2/3/3A Greenville TR3a V8 ? Triumph 8
T TR2/3/3A Would like a paper pattern for TR3A hood stick cover Triumph 0
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
T TR2/3/3A TR3A Windshield Question Triumph 4
Hamish Racing TR2/3/3A Anglesey (Wales) TR3a track videos Triumph 3
RonC TR2/3/3A TR3A Hardtop Seals Triumph 7
T TR2/3/3A TR3A Disk Brake Question Triumph 10
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
Hamish Racing TR2/3/3A TR3a British Hill Climb Shelsley Walsh Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T For Sale TR3A Original Radiator Triumph Classifieds 3
Hamish Racing TR2/3/3A TR3a Faster Lap Times than a Ferrari F430 ?? Triumph 1
Hamish Racing UK hill climb TR3a Racing 0
Hamish Racing TR2/3/3A TR3a UK hill climb video Triumph 4
Hamish Racing TR2/3/3A 3 sisters fun in a TR3a ! Triumph 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M TR2/3/3A 1960 TR3A--intake manifold-to-SUH6 carbs studs Triumph 3
Hamish Racing General TR TR3a and TR7V8 Shelsley Walsh Hill climb action Triumph 0
Hamish Racing TR2/3/3A Fast and wet TR3a Triumph 0
Hamish Racing TR2/3/3A TR3a video Triumph 3
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
angelfj1 TR2/3/3A TR3A Stone Guards Triumph 3
