The Cone of Silence
Member
1967 Healey 3000 Mk III BJ8
I had an issue with throttle/ fuel/ carbs which I could use some help and experience on.
Symptoms noticed:
Hot day on the NSW Central Coast. I drove to the hardware store for 30 minutes, after a warming up and the fuel mix was, as usual, a little rich....with a fuel odour coming from the exhaust. This is pretty normal.....I struggle with carb balancing because I'm a mechanical novice.,
Got to the hardware store then parked in the hot sunshine, 38 degrees C for 30 minutes.
Got back in the car to drive home and noticed the throttle response was very odd. Even though I kept my foot steady on the pedal, the car would stutter repeatedly. This wasn’t so noticeable at low speed but it was happening throughout the rev range and felt uncomfortable.
Here's the kicker though, when I accelerated hard to investigate the throttle issue more, the car repeatedly backfired, which I thought was an issue with an overly lean mixture? Going from rich to lean that quickly seems odd given I didn't tinker with anything under the hood.
Any ideas, chaps?
Bobby
Symptoms noticed:
Any ideas, chaps?
Bobby
