Spin-oil filter, which filters?
AUSMHLY
[FONT=&quot]I have a spin-on oil filter adaptor from Moss, part #635-840[/FONT]
[FONT=&quot]I’ve been using the K&N HP-2009 filter.[/FONT]
[FONT=&quot]What filters are others using, and why that over the K&N or vice versa.[/FONT]
You're paying too much (when I bought that 'kit' from Moss, they sent a Fram; I needed it so I knew what to X-ref).
Wix 51516:
https://www.ebay.com/itm/Wix-51516M...d416fef560419d8551a7196cfe94f0&frcectupt=true
ps. I bought a case--lifetime supply for 2 Healeys; just installed one today--a few years ago for a bit less.
pps. There's something about having a stack of filters and cases of oil on the shelf that makes an oil change so much less tedious. Plus, this stuff doesn't get cheaper.
steveg
WIX / FRAM for me.
There are a lot of recent comparison videos on YouTube showing Frams to be the same inferior quality as they were years ago. Search for "oil filter comparison".
WIXs are top-flight.
Addendum: Fram comment only for cheaper orange filter. Fram Pro Synthetic (green canister) is comparable to Wix & K&N. See: https://youtu.be/kx-NT1DEtlU
Deleted member 19315
Yep Fram Orange. But I usually buy Wix cos I've got a DW account.
John Turney
I use the top Fram filter. The one I have to buy online; they don't sell it in your auto part store. Costs less than K&N with comparable performance.
Michael Oritt
I use K & N's. The 1 inch "nut" on the end of the filter is handy and the construction is superior. IMO an oil filter is not a good place to cheap out.
Ah, the ol' "if something costs more it's gotta be better" argument. Wix--aka "Napa Gold" and probably others--is hardly a 'cheap'--in the quality sense--filter. DWR sells a Wix 'racing' filter for their spin-on adapters, but if you do a little research the racing type are built for greater flow at the expense of less filtering (you can't have it both ways; if a filter filters smaller particles it has to have a denser media and will restrict fluid flow, and vice versa--it's simple physics):
https://www.wixfilters.com/Speciality/WIX Filters Racing Catalog.pdf
Truth be told, for a typical street-driven--a few hundred miles a year--Healey even the crappy, cheapest Frams are adequate (I think they have a burst pressure of 300psi and, supposedly they have burst on occasion but your pressure relief valve should prevent this). My dad used the cheap Frams on everything and we never had a problem with them. The important thing, IMO, is that the anti-drainback valve seals well so you don't get a completely dry start (since the spin-ons are mounted horizontally, it still takes a second or two to fill the filter). On both my Healeys with the Wix filter I get oil pressure in 3-4 seconds on cold start which isn't bad because the gauge pick-up is at the tail end of the oiling system. On my old (2008) Mustang I used Ford-recommended Motorcraft filters I got for less than $5ea at WalMart, and that engine ran perfectly and used little oil at 135K miles. The people who've done 'studies' deconstructing oil filters have generally lauded Wix, K&N, Purolator and even the higher-end Fram filters.
AUSMHLY, does your car have a brake servo? On my BJ8 I can just barely get a Wix on and off without butting up against the Girling servo; if the K&N cans are the same size as the Wix cans the nut on the end would prevent getting the filter on/off without unbolting the servo.
AUSMHLY
AUSMHLY
Yes, I have the brake servo. The K&N nut does not hinder the on/off process. Been using it for years, as it was highly recommended back then. I'm just wondering if it's worth the money with similar high quality filters costing less.
Michael Oritt
TH--
I put the word nut in quotes for that very reason. Because it is made from a pressing the edges are not square but if you use a six-point socket it does work.
RDKeysor
Bronze
My BN7 came with a NAPA Gold 1516. I didn't know the origin of the filter conversion, so I chose to use a filter I knew worked with that unit.
That's the same filter as the Wix 51516 I linked to (equivalent to Fram PH3600). Napa may have slightly different specs; no one knows for sure.
Legal Bill
I run the K&Ns with a brake servo and have no problem getting the filter on and off. I'm not sure where you guys are finding those two different part numbers. I don't see either on the page that Bob linked above. After reading the Wix link the no warranty warning gave me pause.
bob hughes
I use what ever Bill Rawles has in stock,
Why - well I bought the original adapter kit from him and I am too lazy to look around.
Note - I use a rare earth magnet from a microwave oven, slapped on the end of the filter, as far as I know it works a treat ??? :chuncky:
:cheers:
How many here cut their used oil filters open, at least occasionally, to inspect the construction of the filter and see what's accumulating on the media and elsewhere? Note this should be done so as not to introduce any filings from the cutting process.
Wix part number is top right of image, in bold ('MP' stands for Master--i.e. 12--Pack). My adapter, when I bought it from Moss, came with a Fram PH3600, which I x-ref'd to these:
Edit: A good thing about this 'Master Pack;'--i.e. a case--is that the filters are individually shrink-wrapped. I just threw away a new but old Mastercraft filter my dad had on the shelf, in the box, for years because there was rust on the bare steel on the business end.
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
nevets Spin-On Oil Filter Adaptor Austin Healey 12
A TR6 spin on oil filter for tr6 Triumph 4
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
R TR2/3/3A Spin-On Oil Filter 1954 TR-2 Triumph 8
Jim_Gruber Braided Line for Spin Off Oil Filter Adapter Spridgets 13
TEM666666 Spin on oil filter conversion compatibility? Spridgets 9
H Spin-on oil filter for BJ8 Austin Healey 26
L 100 spin on oil filter part number, no oil pressure after replacement Austin Healey 8
F Which spin-off oil filter adapter for my BT7? Advice please Austin Healey 7
Bugeyze Noisy spin on oil filter Austin Healey 9
NutmegCT TR2/3/3A spin on oil filter adapter? Triumph 2
B Spin on oil filter position Austin Healey 1
Trevor Jessie WTB a spin on oil filter head. Spridgets 2
D Stock oil filter vs spin on filter Austin Healey 17
D spin on oil filter conversion kit Spridgets 33
T S2 E-Type Oil Filter [original not spin-on] Jaguar 3
I 1275 spin on oil filter unit and pipe for sale? Spridgets 8
I spin on oil filter adapter recommendations? Spridgets 4
S Oil cooler and spin on filter adapter Triumph 10
scoutll Spin on Oil Filter conversion on a 1098 Spridgets 11
mgedit TR2/3/3A TR3 Spin-on Oil Filter Triumph 7
K TR2/3/3A What was best Spin Oil Filter for TR3 & 4 Engines? Triumph 9
T Question Regarding Old Spin On Oil Filter Design Austin Healey 1
bugedd Spin On oil filter adaptor wanted Spridgets 8
hymodyne GT6 spin-on oil filter adapter w/ oil cooler GT6 Triumph 12
Pythias Spin On Oil Filter: Survey Says? Spridgets 20
Mike_Roe Spin-on Oil FIlter O-rings? Triumph 1
doughairfield TR4/4A Spin on oil filter for TR4 Triumph 12
HEALEYJAG e-type spin on oil filter adapter Jaguar 5
jmwuva05 Low oil pressure after spin on filter Spridgets 13
martx-5 Spin On Oil Filter Adaptor Triumph 6
N Spin on oil filter adapters O-rings? Triumph 3
CinneaghTR Spin-on oil filter conversion for TRactor motor Triumph 7
T TR4/4A Oil filter of choice for the TR3/TR4 spin-on adaptor Triumph 18
G spin on oil filter--oil not being filtered Austin Healey 21
RedTR3 TR2/3/3A TR3 Spin-on oil filter adapter question Triumph 10
AUSMHLY Upright spin on oil filter Austin Healey 8
bcbennett Best oil filter for spin-on? Triumph 24
SCguy TR4/4A Tr4 Spin-on Oil filter Problem Triumph 2
bobh The New 2 Piece Spin on Oil FIlter Adapter Triumph 0
SherpaPilot Spin-On Oil Filter Triumph 3
A What spin-on oil filter do I use??? Triumph 6
jlaird Question, spin on oil filter Spridgets 8
mabbott TR6 TR-6 Spin-on oil filter p/n??? Triumph 4
drooartz Spin-on oil filter adaptor for 948 Spridgets 0
H Spin on Oil Filter Adaptor Austin Healey 3
Exotexs re: Spin-on oil filter adapters Jaguar 3
bobh Spin On Oil Filter Adapter Question Triumph 15
R Oil Filter BJ8 Spin on Austin Healey 16
