Slight front end shimmy @ 52 mph any ideas?
gubba
Hey gang..well I have another question for you all. I just finished the switch over from generator to alternator and found a tr7 fan blade to install on my 1963 tr3b. As I had some other front end issues I wanted to attack I went threw the front end. As I always had a shimmy at 52mph I replaced the sterring nuckel ( it was worn out) and put new grease boots on everywhere and checked all the ball joints all is good. Okay went for a test drive..nothing fell off or blew up and the shimmy was much less but still there. Any ideas? I am running whire wheels with nockoffs.
Mickey Richaud
Swap the tires front to rear (one at a time) and see if anything changes. If so, probably a tire/wheel issue.
NutmegCT
One thing to check (among others) -
Put the car on a lift, or, one at a time, raise each wheel off the ground. Spin the wheel and see if the high part of the wheel "wobbles" in and out (left and right when you face the front of the car). A bent wheel can cause a wobble at a certain speed, then seem to smooth out above and below that speed.
I had a "45-55mph wobble", even tho' the wheels had new lead weights from a spin balancer test. I braced my arm and held a pencil pointing toward the side of the tire. Spun the wheel, and saw the rubber (and the wheel itself) move toward and away from the pencil point. Not good. Found out I had 3 bent wheels. Got new wheels - problem solved. Probably happened over many years of owners hitting chuck holes, curbs, etc.
It's not a bent *lip* of a rim - it's an actual bend in the center of the wheel itself at the hub that causes the problem. Most times it can't be straightened without weakening the steel.
Tom
Edit: Oops - I'm describing my steel wheels - not wires.
TR3driver
Great Pumpkin - R.I.P
I'll disagree, when they are wire wheels. A wire wheels needs to be 'tuned' occasionally throughout its lifetime, which includes making sure the rim runs true to the hub. Far from weakening them, proper tuning actually makes the wheels stronger because it ensures that the spokes share the load evenly and don't get shocked when a loose spoke suddenly becomes tight at each revolution.
https://www.mgaguru.com/mgtech/wheels/wl109.htm
Brooklands
On my 3B, when the previous owner switched to a Rack and Pinion steering box, he mounted it on a bracket of his own design, and then bent the steering column and tie rods to match. The steering box was remounted in the proper position and that seems to have fixed things on my shimmy around 50 or 55 (still have not gotten the speedometer corrected so I use the tach to approximate speed). We also went through the five wheels, found the best four and mounted new tires and put the best old tire on the spare. Spokes were tightened as needed and everything seems pretty good now. I had expected the wheels to be the whole problem until we found the butchered update by Pedro's friend who had owned my car previously... :laugh:
TR3driver
Not that it's necessarily relevant; but I recall many years ago my Dad bought a Chevy wagon that had a fairly serious shimmy only at a specific speed. He thought at first it was tires, so installed carefully balanced new ones, but the shimmy remained. Then he changed the shocks & ball joints, same story. At higher and lower speeds it was OK, so he just avoided driving the wrong speed.
Then a few years later, the tires were replaced again (first new set wore out). The shimmy disappeared! Apparently, it had been ball joints, etc.; but the tires had taken a set so the problem actually switched from being suspension to being tires!
I also had a severe shimmy in my motorhome, that happened only sometimes at certain speeds. Believe it or not, a friend of mine (who ran a tire shop) solved the problem by doing a static balance on the front wheels, instead of dynamic balance. It never happened again.
prb51
When I got my TR3 I had shimmy and major scuttle shake so:
Found out the steel wheels could not be properly balanced (out of whack seriously) replaced with new dayton 60 spoke wires.
This reduced the major scuttle shake..still shimmy
Rebuilt the front end completely, all rubber to poly, all new ends/bushes etc.
This reduced the scuttle shake to one RPM range as you have
Replaced the steering box w/new Rack and Pinion
No shimmy, steers w/ one finger, tracks true.
Between the front end wheel/rubber bushings/ multiple tie rod ends/ silent block bushes etc. and finally play in the steering box there are numerous places for slack to allow shimmy. Locating it can be just about luck without an all out look about.
NickMorgan
There seem to be three common reasons for wheel shimmy at around that speed.
The usual suspect is wheel balance.
The next is incorrect wheel alignment.
The third is one or more wheels out of true.
I have had four bent steel wheels in three TRs and these have been the cause of the shimmy each time.
martx-5
TR3driver said:
... Believe it or not, a friend of mine (who ran a tire shop) solved the problem by doing a static balance on the front wheels, instead of dynamic balance. It never happened again.
Living on Long Island all my life, back in the '60s I used to frequent Bridgehampton race track. Everything was always laid back, and you could always wander around the pits. I can still rememeber watching the Goodyear tire guy installing new rubber of the racers and using a <span style="font-weight: bold">static</span> balancer. Seemed to work just fine for all those race cars. I used to own one, but in one of my house moves it got lost. :cryin:
NutmegCT
Thanks Randall. I was describing my experience with steel wheels (not wires) but forgot to say so. Sorry 'bout that.
Tom
prb51
My steel wheels were/are warped in the lug nut area....no way to fix without spending way to much money...if it can be done at all safely
TR3driver
Nope, for steel wheels I agree entirely with Tom. Even if you can find someone that agrees to try, don't do it. They are weak and known to crack in the center section anyway; trying to straighten them is just asking for trouble IMO.
Which is a shame, because I've got a couple of nice looking wheels that are bent in the center.
GilsTR
After fighting the "Shimmy-Shimmy-Co-Co-Puff" for way too long
found it was my wire wheels. Had them "trued" several times.
Hung tight...and found a good sale on TRF and BINGO...
Shimmy all gone! Gil
pjsmetana
I find it strange that no one mentioned that he should check his alignment... granted the problem usually gets worse with higher speed, but depending on your wheels, tires, and the road, thats not always the case.
EDIT;
So never mind me haha!
M Slight bind in front brakes Spridgets 7
K TR2/3/3A Slight surging at Idle? Triumph 11
71TR6 TR2/3/3A Slight tweak to Martx-5's dogleg covering method Triumph 9
S TR2/3/3A Slight clunk in the rear assembly somewhere. Triumph 3
HighAltitudeTR3 TR2/3/3A I have a tick, or maybe a slight tock... valves? Springs? What? Triumph 11
Jim_Gruber Dilema - Take it back apart or not - Slight and I mean really slight LF Wobble Spridgets 3
Martinld123 A slight hesitation stumble at speed Austin Healey 13
busybrit MGB Slight starter motor noise MG 5
JPSmit Slight Vauxhall Latest - and a question Other British Cars 57
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
JPSmit Slight rant Other British Cars 9
V 1275 slight miss, what's the cause??? Spridgets 20
Anthony_S TR2/3/3A TR3a slight shake at 60-65 mph Triumph 8
bigjones Slight timing problem Spridgets 3
longbridgehealey very slight miss Austin Healey 3
T GT6 slight vibration in GT6, with power Triumph 4
bigjones HS4 - 1500 - slight problem Spridgets 24
bigjones Slight wheel alignment problem Triumph 9
JPSmit slight rant - solenoid Spridgets 3
J Spitfire Slight intermitant 78 Spitfire Triumph 14
kodanja Slight changes Triumph 16
Woodie hs2's slight hesitation under load Spridgets 40
P Slight engine hesitation Spridgets 7
P Slight loss of brake assist until pumped once Triumph 4
Sherlock Suggestion for "slight" name change Rover / Land Rover 1
S slight clicking/tapping noise after a head rebuild Spridgets 4
Basil Slight problem with rear hubs [EType] Jaguar 7
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
