Seized Clutch
Joe Schlosser
Started car and Just let it roll to the other side of the driveway. Pushed in clutch and it would not go into gear, just a lot of gear noises.
As the car had not been driven in a month I figured clutch was stuck to PP. Tried to start car in gear with clutch in with no success.
Got car back inside and checked cutch slave. it looked like it was working properly
I had only has tis happen once before with my FP car and we managed to free it with a in gear start.
I pulled the motor and split the trans of. Suspicion confirmed clutch well stuck on PP. See pics
Could old the P horizontal and clutch stayed firm. Actually needed to "pry it" off th ePP.
Actually see the marks on the PP where clutch was stuck
Any one have any thoughts. Car never sees rain. I thought there was a thread on this last winter but I cannot find it.
Deleted member 8987
Seen a fair amount of these over the decades. Often it is a new clutch, then car stored. Metal facings have not polished off yet.
Heated garage helps, running the car at least once a month and moving it (slipping the clutch a bit) helps.
Joe Schlosser
Joe Schlosser
Thanks
The clutch had about 1000 miles on it. Second winter storage with no issue. Drove car 4-5 times since spring. Raining for most of July so did not drive.
I have a spare clutch disk, thoughts on using the existing or installing the spare.
Should the PP have any have any particular finish?
Deleted member 8987
Thanks
Pp finish..yes and no. You see all sorts of finish on new or rebuilt ones. If it's just rusty, sand it off with oh, 220 then 500 on a block.
I've done so much of that stuff..sanding off rust, throwing a vehicle back together, and by gum, it works!
If you didn't damage the disc facings, they should work fine.
Get it running and slip the clutch a bit to smooth off what you missed.
Joe Schlosser
Joe Schlosser
Yoda; Thanks for the input. I already did the 22 sanding I will hit the face with some 400 next.
I am not big on slipping the clutch except to get started. I will have to practice a little
This is the first time I have this happened in having this car for almost 50 years. Aside from tearing it apart does anyone have any thoughts on freeing up the clutch if it occurs again. Trying to start it in gear with pedal depressed did not work.
How about trying to hit the Assy through the access hole to break it loose?
dklawson
I have experienced this on a few of my cars but not the British ones. I have not resorted to pulling the gearbox to free the parts.
The method I have used is to put the car in neutral and warm the engine up. Once warm I roll the car down to the street and get it pointed where you want to go. You will need at least 100 yards. With the car in position, put the car in first gear and hold down the clutch pedal. Start the engine. The car will immediately start moving. HOLD the clutch pedal to the floor the whole time. Floor the accelerator, then punch the brake. Do that over and over until you either a) run out of road, or b) you hear a loud "bang" indicating the friction disk has broken free. If a) happens, turn the key off, stop, turn the car around and try again.
Once you have the friction disk broken free, drive for a while making sure to let the clutch slip a bit to remove rust and disk material from the flywheel and pressure plate.
On one of my old German cars that was only driven a couple of times a year this became a chronic problem. I resorted to pushing the clutch pedal down and wedging the release bearing lever arm so there was no pressure on the friction disk while in storage. I left myself notes on the dash to remind me to "remove clutch lever chock".
pdplot
When the weather is bad - my TR6 has never seen rain - I go into the garage, start the engine, put in the clutch and run through the gears several times. I also hit the brakes many times, operate the wipers and the heater. Never had a problem with any of the above in 21 years (yet?) I'm doing the same now with the Alfa - which has had gearbox issues).
Joe Schlosser
Joe Schlosser
All back together and road tested several times. I polished the flywheel and pressure plate a bit and have been slipping the clutch a little to seat everything in.
First time in 50 years of having the car that I had this issue.
However, I do have a question. I am using a Aluminum flywheel with the stock pressure plate/clutch. The assembly is 1/4 inch shorter than with the stock iron flywheel.
I am using the stock 2 11/16 inch clutch slave rod. Everything is working fine.
Has anyone needed to use a slightly longer clutch slave rod (1/4") to compensate for the longer travel distance when using an aluminum flywheel??
Just curious
dklawson
With a hydraulic clutch you don't need to worry about using a cylinder with a longer rod... as long as the piston isn't about to pop out of the cylinder when the pedal is fully depressed.
Dscarson
My solution to this problem was to push start the car in forth gear. Once it got going push in the clutch and hit the brakes. That usually freed up the clutch.
Patrick67BJ8
When mine stuck I just warmed up the engine in neutral and then shut if off. I then put it in second gear and started the car, without using the clutch, and then drive it a little bit accelerating and letting off the gas doing this a few times and then trying the clutch. Worked every time for me.
Celtic 77 MGB Seized air pump issue MG 25
5 TR2/3/3A Seized rear brakes Triumph 9
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
aeronca65t Seized Landies Rover / Land Rover 13
JPSmit Viva GT question [seized engine] Other British Cars 5
B TR2/3/3A TR3B Handbrake bolt seized Triumph 5
Geo Hahn MGA MGA w/ Seized Engine MG 6
K TR2/3/3A TR3 rear brake adjuster seized? Triumph 10
theleisure Seized 1275cc, What the...? Spridgets 22
R stuck/seized distributor--please help! MG 21
B MGB 72 mgb speedo drive seized.....easy fix? MG 11
B seized my engine???!!!! Spridgets 60
ahpook what's a 79 midget with a seized engine worth? Spridgets 2
John Moore Un-seized! Spridgets 7
T TR4/4A TR4 Seized [?] Engine Triumph 12
kindofblue Front Dust Caps Problem & Seized fuel Sending Unit Triumph 9
L Seized Pistons MG 16
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
3 100 Clutch Freeplay Austin Healey 7
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
D Clutch Fork Pin Removal Austin Healey 4
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
Michael Oritt Clutch Linkage Austin Healey 19
M 1275 Race Clutch Racing 5
G MGB 1978 MGB clutch is out..! MG 39
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
B Spridget with a Tilton Race Clutch Racing 1
AUSMHLY Clutch Pilot Bush: NOS vs Aftermarket Austin Healey 8
