MGA MGA w/ Seized Engine
Geo Hahn
I hear that May 7th is 'Drive your MGA Day' -- but I have a friend who would be delighted if it could just be 'crank your MGA day' cause his has a seized engine.
BTW - the seizing is a result of sitting idle for a long period of time -- prior to that it ran fine.
He's been soaking the cylinders (head still on) with some of the usual concoctions but so far to no avail.
My question -- is there a good way to safely introduce some sudden force to the effort?
For example -- Can an impact wrench get at the crank bolt thru the hole for the hand crank? Is some thumping on the top of the pistons using a wood block & heavy hammer likely to work or just break something?
Any suggestions welcome -- we've got a couple of weeks before we attempt this (really, just happens to be planned for 5/7) if your suggestion require time. Thanks!
bob67bgt
Check that the starter drive is not jambed into the ring gear. Always look at the simple and cheapest potential problems first. If you have already confirmed that its a stuck engine then good luck with whatever you try next! Bob
aeronca65t
Yes, check the starter. That's pretty common. But if starter is not stuck, it doesn't sound good.
One thing to try (but I can't guarantee it will work), is to pull the plugs and fill cylinders with kerosene. Then let it sit for a few days. Then put car is 4th gear and gently push the car by hand "rocking" it back and forth (clutch out) to see it that will break the engine loose.
Platinum
No sudden impact as that would REALLY break rings and other assorted bits.
If it were mine, I'd be for dumping the well shaken 50/50 ATF-acetone concoction down the holes. Otherwise the same thing Nial suggests about fourth gear and rocking it back-and-forth after a few days.
Geo Hahn
Geo Hahn
Thanks for the starter suggestion -- that is a common problem on TRs but I did not know whether MGs also suffered that fate. Easy enough to deal with as they usually pop loose with no more than a bit of rocking backwards in 4th gear. We'll try that first.
One other "trick" I've read about is to find which cylinder is closest to the top, release the valve train so both valves are closed, adapt a grease gun fitting to fit the spark plug hole, and pump grease into the cylinder. Because liquids - grease - can't compress, the piston must move. This much the same principle that elevators and car lifts work from. A little pressure from the grease can create significant force on the piston. I may not have all the facts just right but you get the general idea. I'm sure smarter minds than mine will correct me if needed. :laugh:
Jacmo
Member
I had the same problem with an A I bought. Used Acetone/tranny fluid in all bores, let sit for a week. Then used a breaker bar and socket on the crank to rock it back and forth until it broke free (the radiator was out). I then ran the car for about 30 miles but it was way down on power. Checked compression and found it to be almost non-existent on #1, and down on #4. After pulling the head, it turned out to have been seized in the #1 cylinder due to rusted rings. Apparently there was a tiny casting leak in the intake tract that allowed coolant to go into the bore and rusted up badly while it sat for a year.
The amazing part is that the rust area in the bore took a huge amount of metal out of the cylinder wall. There's a round depression in the cylinder wall that must be at least 1/8th to 3/16" deep, about 1/4" in total height. I doubt it can even be sleeved it's so deep.
I cannot see how the engine even ran, and that it didn't smoke, or over heat.
I've never seen or heard of anything like this before.
Good luck with yours!
--Jack
Editor_Reid General MG GT-49, national annual meeting of the North American MGA Register MG 0
C For Sale MGA MG Classifieds 0
Editor_Reid MGA Seeking Items for MGA 1600 Mark II Tool Kit MG 0
TomMull MGA Rumble seat MGA MG 3
P For Sale MGA factory hardtop for sale. MG Classifieds 0
PAUL161 T-Series MGA pressure plate verses MGTF pressure plate? MG 6
T MGA MGA MG 6
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
M MGA MGA Engine Rattle MG 10
DocDup1 MGA Wire Wheel Hubs For MGA MG 6
T Wanted Wanted : MGA rear deck cover MG Classifieds 0
M MGA RHD MGA dash finisher MG 0
BritFullHouse For Sale 56 MGA engine parts for free!! MG Classifieds 2
R MGA MGA Headrest fairing for R/H side MG 0
D MGA with T9 gearbox on a tow dolly MG 9
C MGA MGA Thoughts MG 20
C For Sale MGA wiring harness MG Classifieds 3
S For Sale MGA Factory Workshop Manuals on CD/ROM - All Models 1955 - 1962 MG Classifieds 0
Rut MGA MGA in Tuscaloosa, AL MG 3
P mga mint decklid 55to 63 MG Classifieds 1
K MGA 1960 MGA Vin MG 3
B MGA Mystery MGA chassis part MG 3
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
HealeyRick MGA Interesting MGA Fastback MG 9
H MGA MGA engine weight? MG 3
D MGA MGA turn signals MG 3
doc50 MGA Decipher MGA engine Code MG 4
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
Alfred E. Neuman Red MGA MkII Spotted 1
JPSmit MGA - on a journey Spotted 9
A MGA MGA valance fastener MG 2
3798j MGA Coupe Spotted 1
glemon MGA MGA extravaganza MG 4
AngliaGT MGA Coupe Spotted 1
DrEntropy For Sale MGA carbs: AUC 784 MG Classifieds 0
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
oxford Healey vs MGA Austin Healey 31
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
NutmegCT MGA MGA front grilles MG 4
NutmegCT MGA MGA opinions? MG 23
AngliaGT MGA Anyone Looking for an MGA Project? MG 8
Alfred E. Neuman MGA Question for the MGA coupe owners - will I fit? MG 8
S MGA 1956 MGA negative ground, True Spark Ignition distributor MG 3
S MGA 56 - early mga 1500drum brake car MG 5
S MGA MGA Wiring diagram MG 1
R MGA Experience buying an MGA from a US Vendor - Vendor Review forum? MG 8
RickB MGA Looks like a nice MGA grille, $50 on Seattle Craigslist MG 1
S MGA mga top and side curtains MG 4
M MGA MGA Swivel Pin Replacement MG 7
M MGA MGA Deluxe / Twin Cam brakes MG 2
